[databinding] Implementing PropertyChangeSupport [message #321814] |
Sun, 28 October 2007 15:50 |
Originally posted by: news.dankof.net
Hello!
I'm developing a Werbservice backed RCP Client-Server application. I'd like
to use the server data model
for the client where possible. As far as I know, JFace databinding requires
a JavaBean to implement PropertyChangeSupport.
Is there any non-intrusive possibility to implement that? The only thing I
discovered was to use aspects. Does
anyone know of alternatives or best practices?
Thanks in advance,
Fabian
Re: [databinding] Implementing PropertyChangeSupport [message #321844 is a reply to message #321815] |
Mon, 29 October 2007 18:53 |
Thanks for your suggestions. POJO Binding would in fact be what I was
looking for. But as you
mentioned CVS I guess that it is still under development, right?
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb:
> You need to have some notification system if you want to update from a
> model and from view. There's support in CVS for POJO-Binding. Another
> solution is to use EMF which has it's own and IMHO better notification
> system and it doesn't need Reflection which helps to make it work on many
> platforms.
> Tom
> Fabian Dankof schrieb:
>> Hello!
>> like to use the server data model
>> requires a JavaBean to implement PropertyChangeSupport.
>> I discovered was to use aspects. Does
>> Thanks in advance,
>> Fabian
> B e s t S o l u t i o n . at
> Tom Schindl JFace-Committer
FUDForum. Page generated in 0.04045 seconds
