Eclipse 3.3 Solaris Motif build [message #321462] |
Wed, 17 October 2007 17:06  |
Originally posted by: daniel.m.ormond.lmco.com
I am trying to build Eclipse 3.3.1 for solaris 8 using motif. I built
Eclipse 3.3.1 from eclipse-sourceBuild-srcIncluded-3.3.1.zip using the
command:
build -os solaris -ws motif -arch sparc
The build went fine but when I tried running Eclipse I got an error about
finding libgtk-x11-2.0.so.0. This told me that the launcher for Eclipse
is the gtk version instead of the motif version. So I tried to copy all
the files from
features/org.eclipse.equinox.exectuable/bin/motif/solaris/sp arc into my
built Eclpise and I get the error:
"The Eclipse executable launcher was unable to locate its companion shared
library"
Copying the launcher is basically a workaround for the build not working
properly. Does anyone have a fix to either one of these issues?
Dann
Re: Eclipse 3.3 Solaris Motif build [message #321466 is a reply to message #321465] |
Wed, 17 October 2007 18:46   |
It looks like the Equinox launchers no longer have a build for
solaris/motif/sparc. I will have to see if I can build my own.
Dann
Andrew Niefer wrote:
> I don't know why the source build gave you a gtk launcher.
> But the companion shared library is in the
> org.eclipse.equinox.launcher.motif.solaris.sparc fragment, make sure that
> fragment is included.
> -Andrew
>> command:
>> about finding libgtk-x11-2.0.so.0. This told me that the launcher for
>> Eclipse is the gtk version instead of the motif version. So I tried to
>> copy all the files from
>> shared library"
>> Thanks,
>> Dann
Re: Eclipse 3.3 Solaris Motif build [message #321504 is a reply to message #321487] |
Thu, 18 October 2007 14:49   |
I don't see how to build the fragment. I am still learning how Eclipse is
built and the only direction I have currently is the main isntructions for
build all of eclipse. How do I build the individual fragment?
Dann
> They binaries are compiled, but the fragment itself isn't built.
> Look in cvs for the fragment:
dev.eclipse.org:/cvsroot/eclipse/org.eclipse.equinox.launche r/fragments/org.eclipse.equinox.launcher.motif.solaris.sparc
> The fragment is there with the compiled shared library. You just need to
build
> the fragment itself like any other bundle gets built.
> -Andrew
>> Dann
>>> that fragment is included.
>>> -Andrew
>>>> the command:
>>>> for Eclipse is the gtk version instead of the motif version. So I
>>>> tried to copy all the files from
>>>> my built Eclpise and I get the error:
>>>> shared library"
>>>> working properly. Does anyone have a fix to either one of these issues?
>>>> Thanks,
>>>> Dann
Re: Eclipse 3.3 Solaris Motif build [message #321513 is a reply to message #321487] |
Thu, 18 October 2007 19:20   |
The build I have for Solaris, motif, sparc is now working. I had to make
a few changes to the ant build files to make it all work for me but in the
end it works. I will post what I did to make it work so anyone else can
use the same (as if anyone uses Solaris with motif anymore :-) ).
Thanks for you help Andrew. It is much appreciated.
Dann
build
> -Andrew
>> Dann
>>> -Andrew
>>>> the command:
>>>> shared library"
>>>> Thanks,
>>>> Dann
Re: Eclipse 3.3 Solaris Motif build [message #324289 is a reply to message #321513] |
Tue, 22 January 2008 11:06   |
Originally posted by: cortmorgan.yahoo.com
Trying to do the same here. ( Motif on Solaris 9 ). Did you post the steps anywhere? If not, could you please? Would save me a lot of time!
regards,
John
> so anyone else can
> anymore :-) ).
> Dann
> isn't built.
> auncher/fragments/org.eclipse.equinox.launcher.motif.s
> olaris.sparc
> build
> built.
> > -Andrew
> a build for
> build my own.
> >> Dann
> launcher.
> fragment, make sure
> >>> -Andrew
> >>>> Eclipse 3.3.1 from
> >>>> the command:
> that the launcher
> motif version. So I
> ris/sparc into
> >>>> shared library"
> for the build not
> >>>> Thanks,
> >>>> Dann
FUDForum. Page generated in 1.02273 seconds
