Home » Eclipse Projects » Eclipse Platform » Eclipse 3.3 Solaris Motif build
Eclipse 3.3 Solaris Motif build [message #321462] Wed, 17 October 2007 17:06 Go to next message
Originally posted by: daniel.m.ormond.lmco.com
I am trying to build Eclipse 3.3.1 for solaris 8 using motif. I built
Eclipse 3.3.1 from eclipse-sourceBuild-srcIncluded-3.3.1.zip using the
command:
build -os solaris -ws motif -arch sparc
The build went fine but when I tried running Eclipse I got an error about
finding libgtk-x11-2.0.so.0. This told me that the launcher for Eclipse
is the gtk version instead of the motif version. So I tried to copy all
the files from
features/org.eclipse.equinox.exectuable/bin/motif/solaris/sp arc into my
built Eclpise and I get the error:
"The Eclipse executable launcher was unable to locate its companion shared
library"
Copying the launcher is basically a workaround for the build not working
properly. Does anyone have a fix to either one of these issues?
Dann
Re: Eclipse 3.3 Solaris Motif build [message #321465 is a reply to message #321462] Wed, 17 October 2007 18:25 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
I don't know why the source build gave you a gtk launcher.
But the companion shared library is in the
org.eclipse.equinox.launcher.motif.solaris.sparc fragment, make sure that
fragment is included.
-Andrew
> command:
> about finding libgtk-x11-2.0.so.0. This told me that the launcher for
> Eclipse is the gtk version instead of the motif version. So I tried to
> copy all the files from
> shared library"
> Dann
Re: Eclipse 3.3 Solaris Motif build [message #321466 is a reply to message #321465] Wed, 17 October 2007 18:46 Go to previous messageGo to next message
It looks like the Equinox launchers no longer have a build for
solaris/motif/sparc. I will have to see if I can build my own.
Dann
> -Andrew
>> command:
>> shared library"
>> Thanks,
>> Dann
Re: Eclipse 3.3 Solaris Motif build [message #321487 is a reply to message #321466] Thu, 18 October 2007 11:35 Go to previous messageGo to next message
They binaries are compiled, but the fragment itself isn't built.
Look in cvs for the fragment:
dev.eclipse.org:/cvsroot/eclipse/org.eclipse.equinox.launche r/fragments/org.eclipse.equinox.launcher.motif.solaris.sparc
The fragment is there with the compiled shared library. You just need to build
the fragment itself like any other bundle gets built.
-Andrew
> Dann
>> that fragment is included.
>> -Andrew
>>> the command:
>>> for Eclipse is the gtk version instead of the motif version. So I
>>> tried to copy all the files from
>>> my built Eclpise and I get the error:
>>> shared library"
>>> working properly. Does anyone have a fix to either one of these issues?
>>> Thanks,
>>> Dann
Re: Eclipse 3.3 Solaris Motif build [message #321504 is a reply to message #321487] Thu, 18 October 2007 14:49 Go to previous messageGo to next message
I don't see how to build the fragment. I am still learning how Eclipse is
built and the only direction I have currently is the main isntructions for
build all of eclipse. How do I build the individual fragment?
Dann
build
> -Andrew
>> Dann
>>> -Andrew
>>>> the command:
>>>> shared library"
>>>> Thanks,
>>>> Dann
Re: Eclipse 3.3 Solaris Motif build [message #321513 is a reply to message #321487] Thu, 18 October 2007 19:20 Go to previous messageGo to next message
The build I have for Solaris, motif, sparc is now working. I had to make
a few changes to the ant build files to make it all work for me but in the
end it works. I will post what I did to make it work so anyone else can
use the same (as if anyone uses Solaris with motif anymore :-) ).
Thanks for you help Andrew. It is much appreciated.
Dann
build
> -Andrew
>> Dann
>>> -Andrew
>>>> the command:
>>>> shared library"
>>>> Thanks,
>>>> Dann
Re: Eclipse 3.3 Solaris Motif build [message #324289 is a reply to message #321513] Tue, 22 January 2008 11:06 Go to previous messageGo to next message
Originally posted by: cortmorgan.yahoo.com
Trying to do the same here. ( Motif on Solaris 9 ). Did you post the steps anywhere? If not, could you please? Would save me a lot of time!
regards,
John
> so anyone else can
> anymore :-) ).
> Dann
> isn't built.
> auncher/fragments/org.eclipse.equinox.launcher.motif.s
> olaris.sparc
> build
> built.
> > -Andrew
> a build for
> build my own.
> >> Dann
> launcher.
> fragment, make sure
> >>> -Andrew
> >>>> Eclipse 3.3.1 from
> >>>> the command:
> that the launcher
> motif version. So I
> ris/sparc into
> >>>> shared library"
> for the build not
> >>>> Thanks,
> >>>> Dann
icon14.gif  Re: Eclipse 3.3 Solaris Motif build [message #504683 is a reply to message #324289] Tue, 22 December 2009 07:11 Go to previous message
Anup Puranik is currently offline Anup PuranikFriend
I've been trying the same but for 3.5.1 version. I've been successful at making this work. I've written down the steps on my blog :
http://anuppuranik.blogspot.com/2009/12/eclipse-351-on-solar is-10-with-motif.html
Check it out. Don't forget to leave your comments.
Previous Topic:Displaying HTML content with HREFs to documentation plug-in???
Next Topic:Errors during installing new features for Galileo
Current Time: Sun Apr 18 07:07:47 GMT 2021
Powered by FUDForum. Page generated in 0.02332 seconds
