Home » Eclipse Projects » EclipseLink » Unabled to set derived IDs(I can't set derived ids in a classic Master Detail pattern)
Unabled to set derived IDs [message #1670990] Fri, 13 March 2015 08:19 Go to next message
Hello I'm trying to make an example of persistence of a OneToMany relationship in which I get the following error:
Exception Description: Invalid composite primary key specification. The names of the primary key fields or properties in the primary key class [entitys.OrderItemPK] and those of the entity bean class [class entitys.OrderItem] must correspond and their types must be the same. Also, ensure that you have specified ID elements for the corresponding attributes in XML and/or an @Id on the corresponding fields or properties of the entity class.
Note: I'm using EclipseLink and MySQL DB
index.php/fa/21177/0/
  • Attachment: bd.png
    (Size: 36.69KB, Downloaded 407 times)
[Updated on: Fri, 13 March 2015 09:57] by Moderator
Re: Unabled to set derived IDs [message #1671197 is a reply to message #1670990] Fri, 13 March 2015 09:58 Go to previous message
Well i managed to solve the problem by removing idClass annotation and adding the @MapId
heres the final code:
@Entity
@Table(name = "Orders")
public class CustomerOrder implements Serializable {
  private static final long serialVersionUID = 1L;
  @Id
  @GeneratedValue(strategy = GenerationType.IDENTITY)
  @Basic(optional = false)
  @Column(name = "idOrder")
  private Integer idOrder;
  @Column(name = "orderText")
  private String orderText;
 @OneToMany(mappedBy = "customerOrder", cascade = CascadeType.ALL)
 private Collection<OrderItem> orderItemCollection;
 public CustomerOrder() {
@Entity
@Table(name = "OrdersItems")
public class OrderItem implements Serializable {
  @EmbeddedId
  protected OrderItemPK orderItemPK;
  @Column(name = "itemDesc")
  private String itemDesc;
  @MapsId("idOrder")
  @ManyToOne(optional = false)
  @JoinColumn(name = "idOrder", referencedColumnName = "idOrder", nullable = false)
  private CustomerOrder customerOrder;
  public OrderItem() {
    this.orderItemPK = new OrderItemPK();
@Embeddable
public class OrderItemPK implements Serializable {
  private int idOrder;
  @Column(name = "itemNumber")
  private int itemNumber;
  public OrderItemPK() {
    factory = Persistence.createEntityManagerFactory(PERSISTENCE_UNIT_NAME);
    EntityManager em = factory.createEntityManager();
    em.getTransaction().begin();
    // Fill the order item
    OrderItem item = new OrderItem();
    item.getOrderItemPK().setItemNumber(1);
    item.setItemDesc("Product Name");
    // Fill the order
    CustomerOrder order = new CustomerOrder();
    order.setOrderText("Testing");
    // Create relationship
    order.getOrderItemCollection().add(item);
    item.setCustomerOrder(order);
    // Persist
    em.persist(order);
    em.getTransaction().commit();
Previous Topic:java.lang.IncompatibleClassChangeError: org/eclipse/persistence/internal/jpa/metadata/accessors/obje
Next Topic:@MappedSuperClass with InheritanceType.JOINED nullPointerException
Current Time: Sun Apr 20 09:22:45 EDT 2025
Powered by FUDForum. Page generated in 0.03005 seconds
