Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem using © character
Problem using © character [message #32224] Wed, 12 November 2008 16:37 Go to next message
Originally posted by: jmordax.terra.es
Hi, I have used this character © in a Feature Descriptor at Provider field.
Problem is that when I go to Help -> About, and I check the details of
my Feature, that character appears like ©.
I have tested such character in a SWT table successfully, so I suspect
the problem is how the Feature Descriptor is managed later.
Have you seen this behavior before? Is it related to PDE? Should I
comment in other group (I don't know who is in charge of get and show
that info in About window)?
Thanks in advance,
Chemi.
Re: Problem using © character [message #32365 is a reply to message #32224] Thu, 13 November 2008 12:21 Go to previous messageGo to next message
Benjamin Cabé is currently offline Benjamin CabéFriend
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255036 has been filed.
Cheers
Benjamin
> Thanks in advance,
> Chemi.
Re: Problem using © character [message #37138 is a reply to message #32365] Thu, 11 December 2008 21:03 Go to previous message
As workaround I have found that you can export that string to
plugin.properties file and then it is shown correctly. Problem happens
when such character is used directly in MANIFEST.MF or plugin.xml files.
Chemi.
Re: Problem using © character [message #584886 is a reply to message #32224] Thu, 13 November 2008 12:21 Go to previous message
Cheers
Benjamin
> Thanks in advance,
> Chemi.
Re: Problem using © character [message #586961 is a reply to message #32365] Thu, 11 December 2008 21:03 Go to previous message
Chemi is currently offline ChemiFriend
Chemi.
Previous Topic:Alternatives to update sites for plugin distribution?
Next Topic:Finding the Parent Feature of a Plugin
Current Time: Mon Sep 27 14:11:19 GMT 2021
Powered by FUDForum. Page generated in 0.01518 seconds
