Re: how to add a library to my web application? [message #318876 is a reply to message #318871] |
Wed, 08 August 2007 13:09 |
Originally posted by: andreas.grabner.gmail.com
hi there,
maybe i'm wrong but you could/should refresh the folder you copied your
libs into in eclipse (right click the folder in eclipse and "refresh").
when you expand the folder in eclipse you should see the libs then.
after that try to add them to the build path.
hth,
Andi
Steffen schrieb:
> eclipse is driving me mad. Since friday I am trying make my web app and
> eclipse work again properly. Something is very corrupt.
> I reinstalled eclipse 3.2 and 3.3 both with the same negative result. I
> installed some plugins for developing web apps: the WTP web tools platform
> In my workspace there is a folder Web-INF/libs containing the libs the web
> application needs. I copied the libs I need into this folder.
> Then I tried to update the BUILD PATH. When I try to update the WEB APP
> LIBRARIES I do not see the file when try to add a jar.
> I can add them only as an external jar. But this is not what I want.
> What is going wrong? Any ideas?
> Steffen
FUDForum. Page generated in 0.03419 seconds
