Home » Modeling » Papyrus » NPE on right click of a diagram in Papyrus diagram editor (On right click of a diagram in Papyrus diagram editor I face a NPE. This is reproduced only after closing and reopening a Papyrus diagram editor and doing a right click on it)
NPE on right click of a diagram in Papyrus diagram editor [message #1665388] Wed, 11 March 2015 07:53 Go to next message
Sumit Israni is currently offline Sumit IsraniFriend
On right click of a diagram in Papyrus diagram editor I face a NPE. This is reproduced only after closing and reopening a Papyrus diagram editor and doing a right click on it. There is a customized popup menu that comes up after doing the right click. The popup menu is configured as a extension (in the plugin.xml) with an object contribution from org.eclipse.ui.popupMenus plugin.
Could anyone help point out what could be wrong Or is it a bug?
My configuration :-
- Version of Papyrus plugin is 1.0.1
- Eclipse Luna Standard Luna SR1 (4.4.1) Build id: M20140925-0400
- JDK 1.7
	at org.eclipse.ui.internal.ObjectPluginAction.setActivePart(ObjectPluginAction.java:134)
	at org.eclipse.ui.internal.ObjectActionContributor$1.run(ObjectActionContributor.java:161)
	at org.eclipse.ui.internal.ObjectActionContributor.contributeObjectActions(ObjectActionContributor.java:165)
	at org.eclipse.ui.internal.ObjectActionContributorManager.contributeObjectActions(ObjectActionContributorManager.java:104)
	at org.eclipse.ui.internal.PopupMenuExtender.addObjectActions(PopupMenuExtender.java:328)
	at org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(PopupMenuExtender.java:405)
	at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:352)
	at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:492)
	at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:487)
	at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:519)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:255)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
	at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:4963)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4639)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1626)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5023)
	at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
	at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:256)
	at org.eclipse.swt.widgets.Display.runPopups(Display.java:4213)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3755)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Thanks a lot in advance.
Best Regards.
Sumit Israni
Re: NPE on right click of a diagram in Papyrus diagram editor [message #1666054 is a reply to message #1665388] Wed, 11 March 2015 14:16 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
By the definition of a RuntimeException, it's a bug. But in which
component is the question.
Looking at line 134 of ObjectPluginAction.java, it appears that either
(a) the 'target' part does not yet have its part-site or has forgotten it, or
(b) the 'target' part's site does not yet know its page or has
forgotten it (less likely)
I don't know what could cause a pop-up menu to operate on a part that
is not yet initialized or has been destroyed, so at first blush this
looks like a bug in Eclipse Platform. But it could also be caused by
something that the Papyrus editor part is doing wrong in its
initialization.
If you can provide steps to reproduce this, then please raise a
bugzilla so that it may be debugged and fixed.
Christian
> Could anyone help point out what could be wrong Or is it a bug? My
> configuration :-
> - JDK 1.7
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> Best Regards.
> Sumit Israni
Re: NPE on right click of a diagram in Papyrus diagram editor [message #1666141 is a reply to message #1666054] Wed, 11 March 2015 15:03 Go to previous message
Camille Letavernier is currently offline Camille LetavernierFriend
That's a different manifestation of Bug 403755 [1], and it is a Papyrus bug (The same exception simply occurs later, with a different trace, but something in Papyrus is not disposed properly)
[1] 403755: NPE in MultiPageEditorSite.getPage()
https://bugs.eclipse.org/bugs/show_bug.cgi?id=403755
Camille
Camille Letavernier
Previous Topic:Building sources - configuring Eclipse
Next Topic:Error exporting Diagram as image
Current Time: Sat Feb 27 22:59:40 GMT 2021
Powered by FUDForum. Page generated in 0.02617 seconds
