Re: Edge centering problem [message #1665618 is a reply to message #1665077] |
Wed, 11 March 2015 10:06 |
This option is not located on the Edge Mapping but on its style
sub-element. Go to the Advanced tab and you have the new parameter "Ends
Centering" with the radio button options: None / Both / Source / Target.
Steve
Le 11/03/2015 05:43, khanh tran a écrit :
> Hello all,
> As release note of Sirius 2.0, You can specify that an edge end will
> always be centered. And there are The Centered Source Mappings and the
> Centered Target Mappings within the edge style description advanced
> properties tab. But after I upgrade to sirius 2.0, I find no option like
> that in advanced properties tab.
> What should I do to get Edge Centering?
> Thanks in advance.
Steve Monnier - Obeo
Need professional services for Sirius?
Steve Monnier - Obeo Canada
Re: Edge centering problem [message #1671113 is a reply to message #1670449] |
Fri, 13 March 2015 13:15 |
I have to try to update from 1.0 to 2.0, because I do not see why this
feature would not be available for you. Can you tell me what exact
version you upgraded to? 2.0.4?
You just need to open you VSM (*.odesign), the migration is automatic.
Steve
Le 13/03/2015 08:41, khanh tran a écrit :
> Hi Steve,
> Currently I have a *.odesign file with sirius 1.0. Then I upgrade to
> sirius 2.0 by upgrade from update site.
> Some new features in sirius 2.0 like Snap to Shape or Outline
> (automatically moves the displayed zone of the diagram) are work fine.
> Is there anything else I need to migrate *.odesign file from 1.0 to 2.0?
> Thanks in advance.
Re: Edge centering problem [message #1682244 is a reply to message #1677988] |
Tue, 17 March 2015 17:02 |
How did you updated to Sirius 2.0? I have just updated a Sirius 1.0.0 to
Sirius 2.0 using the market place and it works fine. My VSM model now
display the "Ends Centering" option in the advanced tab of an Edge Mapping.
Steve
Le 16/03/2015 04:34, khanh tran a écrit :
> Hi Steve,
> The version that I upgraded is 2.0.0. Please see attachment files for more detail.
> Thank you very much.
FUDForum. Page generated in 0.03561 seconds
