Xtext 2.8.0 and Xtext Maven Plugin to generate the model artifacts [message #1663523] |
Tue, 10 March 2015 13:15 |
Adrian Pollak Messages: 27 Registered: August 2013 |
after todays automatic OSGI build update to Xtext 2.8.0 my maven build is not working any more.
The maven build that creates the DSL plugin (DSL+UI) works fine.
I have a problem, when I use the xtext-maven-plugin and try to generate the model artifacts (see the pom.xml extract).
My build throws the exception that can be found beneath.
Although the new libraries are received and stored in the maven repository in the p2 directory the xtend maven plugin (2.7.3) uses the libraries from C:\Applications\maven-repository_xy2\org\eclipse\xtext\org.eclipse.xtext.xbase\2.7.3 that do not have the needed class "org.eclipse.xtext.xbase.DefaultXbaseRuntimeModule".
Under http://mvnrepository.com/artifact/org.eclipse.xtend/xtend-maven-plugin there is no Xtend Maven Plugin of version 2.8.0.
Is there a way (workaround) to fix the build problem.
pom.xml:
<plugin>
<groupId>org.eclipse.xtext</groupId>
<artifactId>xtext-maven-plugin</artifactId>
<version>2.7.3</version>
<executions>
<execution>
<id>generate-model-artifacts</id>
<phase>generate-sources</phase>
<goals>
<goal>generate</goal>
</goals>
</execution>
</executions>
<configuration>
<compilerSourceLevel>${compilerSourceLevel.version}</compilerSourceLevel>
<compilerTargetLevel>${compilerTargetLevel.version}</compilerTargetLevel>
<languages>
<language>
<setup>com.my.dsl.RamDslStandaloneSetup</setup>
<outputConfigurations>
<outputConfiguration>
<outputDirectory>../com.my.ram/src-gen/</outputDirectory>
<createOutputDirectory>true</createOutputDirectory>
<overrideExistingResources>true</overrideExistingResources>
<cleanUpDerivedResources>true</cleanUpDerivedResources>
</outputConfiguration>
</outputConfigurations>
</language>
</languages>
</configuration>
<dependencies>
<dependency>
<groupId>com.my</groupId>
<artifactId>com.my.dsl</artifactId>
<version>1.0.0</version>
</dependency>
<dependency>
<artifactId>com.my.interfaces</artifactId>
</dependency>
</dependencies>
</plugin>
Exception:
[INFO] ------------------------------------------------------------------------
[INFO] Building RAM Module 1.0.0
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ com.my.ram ---
[INFO]
[INFO] --- tycho-packaging-plugin:0.22.0:build-qualifier (default-build-qualifier) @ com.my.ram ---
[INFO] The project's OSGi version is 1.0.0
[INFO]
[INFO] --- tycho-packaging-plugin:0.22.0:validate-id (default-validate-id) @ com.my.ram ---
[INFO]
[INFO] --- tycho-packaging-plugin:0.22.0:validate-version (default-validate-version) @ com.my.ram ---
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:add-source (add-source-xtext) @ com.my.ram ---
[INFO] Source directory: C:\workspaces\head\com.my.ram\target\target\xtext-temp added.
[INFO]
[INFO] --- xtext-maven-plugin:2.7.3:generate (generate-model-artifacts) @ com.my.ram ---
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.builder.standalone/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.builder.standalone/maven-metadata.xml (732 B at 2.4 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.xbase/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.xbase/maven-metadata.xml (688 B at 3.0 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext/maven-metadata.xml (682 B at 3.2 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.util/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.util/maven-metadata.xml (439 B at 2.6 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/com/google/guava/guava/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/com/google/guava/guava/maven-metadata.xml (2 KB at 8.8 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.ecore/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.ecore/maven-metadata.xml (794 B at 4.0 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.common/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.common/maven-metadata.xml (795 B at 3.6 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.dependencies/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.dependencies/maven-metadata.xml (695 B at 3.3 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.xbase.lib/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.xbase.lib/maven-metadata.xml (785 B at 4.0 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.ecore.xmi/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.ecore.xmi/maven-metadata.xml (798 B at 5.1 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/antlr/antlr-runtime/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/antlr/antlr-runtime/maven-metadata.xml (900 B at 5.1 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtend/org.eclipse.xtend.lib/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtend/org.eclipse.xtend.lib/maven-metadata.xml (779 B at 5.6 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.common.types/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.common.types/maven-metadata.xml (695 B at 4.7 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.codegen/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.codegen/maven-metadata.xml (658 B at 4.1 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.xtext/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/xtext/org.eclipse.xtext.xtext/maven-metadata.xml (688 B at 4.8 KB/sec)
Downloading: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.codegen.ecore/maven-metadata.xml
Downloaded: http://nexmach.net:8084/nexus/content/groups/public/org/eclipse/emf/org.eclipse.emf.codegen.ecore/maven-metadata.xml (664 B at 4.2 KB/sec)
[INFO] BUILD FAILURE
[INFO] Total time: 18.348s
[INFO] Finished at: Tue Mar 10 13:43:29 CET 2015
[INFO] Final Memory: 69M/308M
[ERROR] Failed to execute goal org.eclipse.xtext:xtext-maven-plugin:2.7.3:generate (generate-model-artifacts) on project com.my.ram: Execution generate-model-artifacts of goal org.eclipse.xtext:xtext-maven-plugin:2.7.3:generate failed: A required class was missing while executing org.eclipse.xtext:xtext-maven-plugin:2.7.3:generate
: org/eclipse/xtext/xbase/DefaultXbaseRuntimeModule
[ERROR] -----------------------------------------------------
[ERROR] realm = plugin>org.eclipse.xtext:xtext-maven-plugin:2.7.3
[ERROR] strategy = org.codehaus.plexus.classworlds.strategy.SelfFirstStrategy
[ERROR] urls[0] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/xtext-maven-plugin/2.7.3/xtext-maven-plugin-2.7.3.jar
[ERROR] urls[1] = file:/C:/applications/maven-repository_xy2/com/my/com.my.dsl/1.0.0/com.my.dsl-1.0.0.jar
[ERROR] urls[2] = file:/C:/applications/maven-repository_xy2/org/springframework/spring-beans/3.2.4.RELEASE/spring-beans-3.2.4.RELEASE.jar
[ERROR] urls[3] = file:/C:/applications/maven-repository_xy2/org/springframework/spring-core/3.2.4.RELEASE/spring-core-3.2.4.RELEASE.jar
[ERROR] urls[4] = file:/C:/applications/maven-repository_xy2/org/springframework/spring-context/3.2.4.RELEASE/spring-context-3.2.4.RELEASE.jar
[ERROR] urls[5] = file:/C:/applications/maven-repository_xy2/org/springframework/spring-aop/3.2.4.RELEASE/spring-aop-3.2.4.RELEASE.jar
[ERROR] urls[6] = file:/C:/applications/maven-repository_xy2/org/springframework/spring-expression/3.2.4.RELEASE/spring-expression-3.2.4.RELEASE.jar
[ERROR] urls[7] = file:/C:/applications/maven-repository_xy2/com/my/com.my.interfaces/1.0.0/com.my.interfaces-1.0.0.jar
[ERROR] urls[8] = file:/C:/applications/maven-repository_xy2/org/eclipse/aether/aether-spi/0.9.0.M2/aether-spi-0.9.0.M2.jar
[ERROR] urls[9] = file:/C:/applications/maven-repository_xy2/org/eclipse/aether/aether-impl/0.9.0.M2/aether-impl-0.9.0.M2.jar
[ERROR] urls[10] = file:/C:/applications/maven-repository_xy2/org/eclipse/aether/aether-api/0.9.0.M2/aether-api-0.9.0.M2.jar
[ERROR] urls[11] = file:/C:/applications/maven-repository_xy2/org/eclipse/aether/aether-util/0.9.0.M2/aether-util-0.9.0.M2.jar
[ERROR] urls[12] = file:/C:/applications/maven-repository_xy2/org/eclipse/sisu/org.eclipse.sisu.plexus/0.0.0.M5/org.eclipse.sisu.plexus-0.0.0.M5.jar
[ERROR] urls[13] = file:/C:/applications/maven-repository_xy2/javax/enterprise/cdi-api/1.0/cdi-api-1.0.jar
[ERROR] urls[14] = file:/C:/applications/maven-repository_xy2/javax/annotation/jsr250-api/1.0/jsr250-api-1.0.jar
[ERROR] urls[15] = file:/C:/applications/maven-repository_xy2/org/sonatype/sisu/sisu-guice/3.1.0/sisu-guice-3.1.0-no_aop.jar
[ERROR] urls[16] = file:/C:/applications/maven-repository_xy2/org/eclipse/sisu/org.eclipse.sisu.inject/0.0.0.M5/org.eclipse.sisu.inject-0.0.0.M5.jar
[ERROR] urls[17] = file:/C:/applications/maven-repository_xy2/org/codehaus/plexus/plexus-interpolation/1.19/plexus-interpolation-1.19.jar
[ERROR] urls[18] = file:/C:/applications/maven-repository_xy2/org/codehaus/plexus/plexus-utils/3.0.17/plexus-utils-3.0.17.jar
[ERROR] urls[19] = file:/C:/applications/maven-repository_xy2/org/codehaus/plexus/plexus-component-annotations/1.5.5/plexus-component-annotations-1.5.5.jar
[ERROR] urls[20] = file:/C:/applications/maven-repository_xy2/org/sonatype/plexus/plexus-sec-dispatcher/1.3/plexus-sec-dispatcher-1.3.jar
[ERROR] urls[21] = file:/C:/applications/maven-repository_xy2/org/sonatype/plexus/plexus-cipher/1.4/plexus-cipher-1.4.jar
[ERROR] urls[22] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext.builder.standalone/2.7.3/org.eclipse.xtext.builder.standalone-2.7.3.jar
[ERROR] urls[23] = file:/C:/applications/maven-repository_xy2/org/eclipse/equinox/common/3.6.200-v20130402-1505/common-3.6.200-v20130402-1505.jar
[ERROR] urls[24] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext.xbase/2.7.3/org.eclipse.xtext.xbase-2.7.3.jar
[ERROR] urls[25] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtend/org.eclipse.xtend.lib/2.7.3/org.eclipse.xtend.lib-2.7.3.jar
[ERROR] urls[26] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtend/org.eclipse.xtend.lib.macro/2.7.3/org.eclipse.xtend.lib.macro-2.7.3.jar
[ERROR] urls[27] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext.xbase.lib/2.7.3/org.eclipse.xtext.xbase.lib-2.7.3.jar
[ERROR] urls[28] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext/2.7.3/org.eclipse.xtext-2.7.3.jar
[ERROR] urls[29] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext.dependencies/2.7.3/org.eclipse.xtext.dependencies-2.7.3.jar
[ERROR] urls[30] = file:/C:/applications/maven-repository_xy2/org/antlr/antlr-runtime/3.2/antlr-runtime-3.2.jar
[ERROR] urls[31] = file:/C:/applications/maven-repository_xy2/org/eclipse/emf/org.eclipse.emf.common/2.11.0-v20150123-0347/org.eclipse.emf.common-2.11.0-v20150123-0347.jar
[ERROR] urls[32] = file:/C:/applications/maven-repository_xy2/org/eclipse/emf/org.eclipse.emf.ecore/2.11.0-v20150123-0347/org.eclipse.emf.ecore-2.11.0-v20150123-0347.jar
[ERROR] urls[33] = file:/C:/applications/maven-repository_xy2/org/eclipse/emf/org.eclipse.emf.codegen/2.10.0-v20150123-0452/org.eclipse.emf.codegen-2.10.0-v20150123-0452.jar
[ERROR] urls[34] = file:/C:/applications/maven-repository_xy2/com/google/inject/guice/3.0/guice-3.0.jar
[ERROR] urls[35] = file:/C:/applications/maven-repository_xy2/javax/inject/javax.inject/1/javax.inject-1.jar
[ERROR] urls[36] = file:/C:/applications/maven-repository_xy2/aopalliance/aopalliance/1.0/aopalliance-1.0.jar
[ERROR] urls[37] = file:/C:/applications/maven-repository_xy2/com/google/guava/guava/14.0.1/guava-14.0.1.jar
[ERROR] urls[38] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext.xtext/2.7.3/org.eclipse.xtext.xtext-2.7.3.jar
[ERROR] urls[39] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext.util/2.7.3/org.eclipse.xtext.util-2.7.3.jar
[ERROR] urls[40] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/org.eclipse.xtext.common.types/2.7.3/org.eclipse.xtext.common.types-2.7.3.jar
[ERROR] urls[41] = file:/C:/applications/maven-repository_xy2/org/ow2/asm/asm-commons/5.0.1/asm-commons-5.0.1.jar
[ERROR] urls[42] = file:/C:/applications/maven-repository_xy2/org/ow2/asm/asm-tree/5.0.1/asm-tree-5.0.1.jar
[ERROR] urls[43] = file:/C:/applications/maven-repository_xy2/org/ow2/asm/asm/5.0.1/asm-5.0.1.jar
[ERROR] urls[44] = file:/C:/applications/maven-repository_xy2/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.11.0-v20150123-0357/org.eclipse.emf.codegen.ecore-2.11.0-v20150123-0357.jar
[ERROR] urls[45] = file:/C:/applications/maven-repository_xy2/com/ibm/icu/icu4j/52.1/icu4j-52.1.jar
[ERROR] urls[46] = file:/C:/applications/maven-repository_xy2/commons-cli/commons-cli/1.2/commons-cli-1.2.jar
[ERROR] urls[47] = file:/C:/applications/maven-repository_xy2/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar
[ERROR] urls[48] = file:/C:/applications/maven-repository_xy2/org/eclipse/xtext/xtext-antlr-generator/2.1.1/xtext-antlr-generator-2.1.1.jar
[ERROR] urls[49] = file:/C:/applications/maven-repository_xy2/org/xtext/antlr-generator/3.2.1/antlr-generator-3.2.1.jar
[ERROR] urls[50] = file:/C:/applications/maven-repository_xy2/org/eclipse/emf/org.eclipse.emf.ecore.xmi/2.11.0-v20150123-0347/org.eclipse.emf.ecore.xmi-2.11.0-v20150123-0347.jar
[ERROR] urls[51] = file:/C:/applications/maven-repository_xy2/log4j/log4j/1.2.16/log4j-1.2.16.jar
[ERROR] Number of foreign imports: 1
[ERROR] import: Entry[import from realm ClassRealm[project>com.my:com.my.ram:1.0.0, parent: ClassRealm[maven.api, parent: null]]]
[ERROR]
[ERROR] -----------------------------------------------------: org.eclipse.xtext.xbase.DefaultXbaseRuntimeModule
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginContainerException
C:\workspaces\head\com.my.ram>
MANIFEST.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Ram Models
Bundle-SymbolicName: com.my.ram
Bundle-Version: 1.0.0
Bundle-Vendor: My Company
Require-Bundle: com.my.interfaces;bundle-version="1.0.0",
org.eclipse.xtext.xbase;bundle-version="2.8.0"
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Any help is appreciated.
Adrian
[Updated on: Wed, 11 March 2015 08:51] Report message to a moderator
FUDForum. Page generated in 0.03761 seconds
