Home » Archived » Jubula » Automating iOS AUT using Jubula in a Mac(Jubula iOS automation)
Automating iOS AUT using Jubula in a Mac [message #1660700] Mon, 09 March 2015 05:49 Go to next message
I'm trying to automate an iOS application using Jubula in Mac. While creating the AUT configuration, I gave the iOS Device Port as 11022 which is the default number specified in the Jubula documentation. (see attachment)
I connected to the "Embedded AUT Agent", Then clicked on "Start AUT" button. But I always get the error code "5009: AUT Start failed. Please check AUT Configuration."
I tried Googling it and didn't get any valid solution for the iOS AUT. Since I am new to Jubula, please help me in moving forward. Confused
Thanks in advance.
Balaram.
[Updated on: Tue, 10 March 2015 00:38] by Moderator
Re: Automating iOS AUT using Jubula in a Mac [message #1664027 is a reply to message #1660700] Tue, 10 March 2015 14:02 Go to previous messageGo to next message
Hi Balaram,
Have you taken the steps as described in the user manual on setting up your iOS AUT for testing? What version of iOS are you using?
Alex
Re: Automating iOS AUT using Jubula in a Mac [message #1665019 is a reply to message #1664027] Wed, 11 March 2015 00:09 Go to previous messageGo to next message
Hi Alexandra. I have followed the steps as described in the Jubula User manual for setting up the iOS AUT for testing. I have tried with iOS 7.1 and 8.1...
Re: Automating iOS AUT using Jubula in a Mac [message #1666507 is a reply to message #1665019] Wed, 11 March 2015 14:35 Go to previous messageGo to next message
Thanks for the information! Can you add the rc_ios log (which you can find in your home/.jubula directory)?
Alex
Re: Automating iOS AUT using Jubula in a Mac [message #1667634 is a reply to message #1666507] Thu, 12 March 2015 01:56 Go to previous messageGo to next message
Thanks for your quick reply! The log file you had asked is attached herewith. Smile
  • Attachment: rc_ios.log
    (Size: 25.94KB, Downloaded 139 times)
Re: Automating iOS AUT using Jubula in a Mac [message #1692083 is a reply to message #1667634] Mon, 13 April 2015 06:14 Go to previous messageGo to next message
Is anyone available to help me out in this issue?????? Sad
Re: Automating iOS AUT using Jubula in a Mac [message #1692160 is a reply to message #1692083] Tue, 14 April 2015 01:32 Go to previous messageGo to next message
Hi Balaram,
Sorry for the delay. I'll forward this on to see if the rest of the team can help.
Alex
Re: Automating iOS AUT using Jubula in a Mac [message #1692178 is a reply to message #1660700] Tue, 14 April 2015 03:47 Go to previous messageGo to next message
Hi Balaram,
after reading the log, it seems to me that either the Port is occupied or the device is in another Network. Could you check that?
Marcel
Re: Automating iOS AUT using Jubula in a Mac [message #1692221 is a reply to message #1692160] Tue, 14 April 2015 07:38 Go to previous messageGo to next message
Hi Balaram,
here is an answer from one of the team members:
after reading the log, it seems to me that the port is occupied and/or your device is not in the same network. Could you check that?
Alex
Re: Automating iOS AUT using Jubula in a Mac [message #1692626 is a reply to message #1692221] Fri, 17 April 2015 01:05 Go to previous messageGo to next message
Thanks, Alexandra and Marcel, I will check the same and get back to you... Smile
The thing is, I am using the USB cable of the device to connect with my Mac. So is the network really significant here? Or does the connection work only by using the WiFI network?
Thanks.
Balaram.
[Updated on: Fri, 17 April 2015 01:08] by Moderator
Re: Automating iOS AUT using Jubula in a Mac [message #1692837 is a reply to message #1692626] Mon, 20 April 2015 03:15 Go to previous messageGo to next message
Hi Alexandra and Marcel!
I connected my Mac to the same WiFi network as in the iPhone that I use for testing and the issue was solved!!
Thanks for you valuable inputs!!! Smile Very Happy
Best Regards,
Balaram.
Re: Automating iOS AUT using Jubula in a Mac [message #1692839 is a reply to message #1692837] Mon, 20 April 2015 03:23 Go to previous message
Glad to hear that Balaram! Thanks for updating us.
Previous Topic:How to check value of "Spinner" UI element?
Next Topic:How to create my own functions
Current Time: Fri Apr 18 04:05:50 EDT 2025
Powered by FUDForum. Page generated in 0.05992 seconds
