Home » Modeling » Papyrus » Oomph setup --> lots of compiler issues
Oomph setup --> lots of compiler issues [message #1653868] |
Fri, 06 March 2015 12:24 |
Johan Van Noten Messages: 87 Registered: July 2009 |
Member |
Short description:
When I use the Oomph setup to create a Luna development environment, everything goes smoothly.
After a restart of the environment, a rebuild is triggered and results in >600.000 errors.
The only way I found to fix it, is a reload of the target platform.
After the next restart, the scenario repeats itself.
My guess was that Oomph results in a fully functional development environment.
So, either I do something wrong or the Papyrus Setup model for Oomph shows some hiccups.
Longer description: (reproduction scenario)
(I first deleted my bundle pool c:\users\myname\.p2 to avoid 'bad history')
* Download the Oomph installer (I use version 1.1.0 Build 941 on Win x64)
* Select "Eclipse Standard" (I also tried "Eclipse Modeling Tools" to no avail.)
* Fill variables:
- Product version "Latest Release (Luna)" 64-bit
- VM: ... jdk8 (a 64-bit version)
* Next
* Select Papyrus | Main | all subprojects
* Verify that all are on the stream "streams/1.0-maintenance (Luna/1.0.x)"
* Next
* Fill variables (show all variables):
- Installation location = d:\Prog\OomphLuna
- Workspace location = d:\Local\Dev\OomphLuna
- Target Platform = Luna
- Eclipse UserID etc (Authenticate returns that my password is invalid, but I can perfectly signon with these credentials on https://dev.eclipse.org/site_login/)
* Next
* All Bootstrap tasks are ticked.
* Additionally, only "Mirrors" at the bottom is ticked.
* Finish
* After some time, without any issues, Eclipse launches
* Finish the bootstrap.
* Close the new Eclipse's Welcome screen
* Click the two revolving arrows in front of "Executing Startup Tasks" to show progress
* Wait... wait a bit more...
* This completes without errors. Click Finish.
* The active Eclipse starts building the workspace.
* You now hit bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=461492, causing 1 error.
Fix it by putting the following in the affected manifest.mf file:
Bundle-ManifestVersion: 2
Bundle-Name: Facet Custom Editor
Bundle-SymbolicName: org.eclipse.papyrus.emf.facet.custom.metamodel.editor.doc;singleton:=true
Bundle-Version: 1.0.2.qualifier
Require-Bundle: org.eclipse.help
Bundle-Vendor: Eclipse Modeling Project
* Build now completely succeeds
* Restart the current session (File | Restart)
* Some activities start automatically: Setup check , Removing lots of projects from "Xtext index", Building workspace
* Finally, end up with 611.302 errors (and quite some warnings)
* Optional: Clean all workspace projects - rebuild starts - same result
* Go to Window | Preferences | Plug-in development | target platform
* Currently "Modular Target" is listed as active.
* Select it, Reload, Ok
* Message box appears:
"You have selected a target with a newer version than your current Eclipse installation. This can cause unexpected behaviour in PDE. Please use a newer version of Eclipse."
* Press ok
* Rebuild starts
* No more build errors
* Do File | Restart and you are back to 611.302 errors after a rebuild.
Re: Oomph setup --> lots of compiler issues [message #1653962 is a reply to message #1653868] |
Fri, 06 March 2015 13:17 |
Hi, Johan,
Thanks for taking an interest in getting involved with Papyrus and the
setup model.
I have copied the Oomph newsgroup on my reply to see whether the
experts there can be of help. Find other responses in-line, below.
HTH,
Christian
On 2015-03-06 12:24:13 +0000, Johan Van Noten said:
> Short description:
> everything goes smoothly. After a restart of the environment, a rebuild
Re-load in what way? Run the Targlet configuration task again, or just
hit the "Reload" button in the PDE Target preference page?
It does seem to work for most of us, but I'm not sure how up-to-date we
are Oomph-wise. I suppose you're on the very latest public build of
Oomph?
> shows some hiccups.
Is that even safe to do? I've never tried doing that.
> no avail.)
Either of these should provide a good basis for a Papyrus development
environment (I usually take the standard package, myself, because then
I only get what I really need for Papyrus).
> * Fill variables:
> * Next
All good.
> * Next
Not C: drive? My Windows experience is so long ago now that I vaguely
recall some tools behave strangely on assumptions of paths being in the
C: drive, but I wouldn't expect Oomph to exhibit any such trouble.
Yep.
> * Next
> * Finish
> to show progress
> causing 1 error.
This all sounds peachy.
I don't see how anything in the setup model could cause this. It
shouldn't be possible even for a misconfigured setup model to break the
PDE. Hopefully somebody in the Oomph forum recognizes this problem and
can help!
Ah, that answers that.
That doesn't make sense. You've based your Oomph installation on Luna
and you've imported the Luna stream of the setup model, so everything
in your PDE Target should be Luna.
Perhaps this is the problem.
Can you confirm that your org.eclipse.core.resources and
org.eclipse.pde.core plug-ins in your install and in your PDE Target
are both the Luna version?
> * Press ok
> * Rebuild starts
Re: Oomph setup --> lots of compiler issues [message #1654022 is a reply to message #1653962] |
Fri, 06 March 2015 13:51 |
Member |
The answer to your remaining questions are below:
> Oomph?
Yep, the latest afaik: I use version 1.1.0 Build 941 on Win x64
Well, of course I only did this after running into the issue.
It clearly didn't solve the issue, but I don't see any (direct) negative impact either.
I guess that it would break any other Oomph installations that depend on the same bundle pool, but that's not my case.
I don't think this will be an issue. I'm using Eclipse all over my D: drive.
>> causing 1 error.
By the way: Camille just solved this bug.
> can help!
I help hoping...
If I open Help | About | Installation Details | Plug-ins, I get the following:
* org.eclipse core.resources: 3.9.1.v20140825-1431
* org.eclipse.pde.core: 3.10.1.v20140902-1534
If I open Window | Preferences | Target Platform, select "Modular Target" and go to the Contents tab, I get:
* org.eclipse core.resources: 3.9.1.v20140825-1431 (identical)
* org.eclipse.pde.core: 3.10.2.v20150127-1015 (newer)
Other bundles like the Papyrus ones are also clearly newer (1.0.1 in the installation as opposed to 1.0.2 in the target).
Does this answer your question?
Re: Oomph setup --> lots of compiler issues [message #1663551 is a reply to message #1654022] |
Tue, 10 March 2015 13:28 |
Yes, it does. I would have expected the Oomph setup to bring the same
version of PDE into both the installation and the PDE target: the p2
tasks in the setup model reference the same Luna repository as the
targlet tasks. This probably is why you're getting that message, and I
suppose it could be a trigger for the compilation problems, too.
If you use the p2 update UI in the Help menu to update your
installation to the latest PDE, does that resolve your compilation woes?
Christian
Re: Oomph setup --> lots of compiler issues [message #1671314 is a reply to message #1670956] |
Fri, 13 March 2015 14:55 |
Oo, that's not good. I haven't seen anything like that before.
I wonder whether that's a problem with the definition of the EPP, or
something in Oomph? I always base my Oomph installs on the smallest
possible EPP (classic/committers or whatever it is called) because any
other requirements of what I'm Oomph-installing should be found in the
referenced repositories automatically anyways. And, I haven't created
a new Oomph installation in ages, so I don't know whether perhaps Oomph
has regressed in its p2 automation.
I don't have any ideas what to do next, expect to inquire about this in
the Oomph newsgroup.
Christian
On 2015-03-13 12:02:26 +0000, Johan Van Noten said:
> Christian,
> Sorry for the delay, I didn't see your feedback until I came here to
> "ping" the message.
> When I try to use "Help | Check for updates" I get the message "Cannot
> complete the request. This installation has not been configured
> propertly for Software Updates. See the error log for details."
> And then doing what it proposed: check the error log:
> eclipse.buildId=4.4.1.M20140925-0400
> java.version=1.8.0_40
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=nl_BE
> Framework arguments: -product org.eclipse.epp.package.modeling.product
> Command-line arguments: -os win32 -ws win32 -arch x86_64 -product
> org.eclipse.equinox.p2.ui.sdk
> Warning
> Fri Mar 13 13:00:04 CET 2015
> Could not locate the running profile instance. The eclipse.p2.data.area
> and eclipse.p2.profile properties may not be set correctly in this
> application's config.ini file.
Re: Oomph setup --> lots of compiler issues [message #1679026 is a reply to message #1677277] |
Mon, 16 March 2015 12:40 |
Hi, Johan,
No, I don't think so. The modeling components installer is like the
Eclipse Marketplace Client. It isn't used by Oomph, which instead
loads software from the Luna simultaneous release repository.
Although, I should clarify that it is only software installed by p2
into your developer IDE that is obtained from the Luna repository. The
PDE target is assembled from the individual release repositories of
each project dependency to ensure the best version of each at any point
in the development process (which by now, for Luna, is largely done).
HTH,
Christian
On 2015-03-15 21:05:14 +0000, Johan Van Noten said:
> Hi Christian,
> Do you feel this could be related to the bug that I submitted?
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=462140
> Johan
Current Time: Thu Apr 25 04:55:33 GMT 2024
Powered by FUDForum. Page generated in 0.04993 seconds
