Home » Archived » BIRT » How to Colour in Weekends on BIRT Gantt Chart?
How to Colour in Weekends on BIRT Gantt Chart? [message #1638826] Fri, 27 February 2015 05:08 Go to next message
I have a BIRT Gantt chart.
It shows 16 weeks of data. Weeks are delimited by bold vertical lines, days by grey gridlines. I need to colour the background of the weekend cells to make it easier for a user to see if an event crosses a weekend.
Re: How to Colour in Weekends on BIRT Gantt Chart? [message #1639157 is a reply to message #1638826] Fri, 27 February 2015 08:40 Go to previous messageGo to next message
There is a forum dedicated to BIRT. I'll move this topic there but in the future you should ask directly on that forum.
Re: How to Colour in Weekends on BIRT Gantt Chart? [message #1652491 is a reply to message #1639157] Thu, 05 March 2015 17:31 Go to previous messageGo to next message
Sorry for the delay. Posts with a response sometimes get skipped over, so when Eric moves one and comments in it, it might look like someone responded. What is your BIRT version? I'll try to get an example set up for you.
Re: How to Colour in Weekends on BIRT Gantt Chart? [message #1661362 is a reply to message #1652491] Mon, 09 March 2015 11:47 Go to previous messageGo to next message
Thanks, it's version 2.5.2 v20100209
Re: How to Colour in Weekends on BIRT Gantt Chart? [message #1663955 is a reply to message #1652491] Tue, 10 March 2015 13:21 Go to previous messageGo to next message
Re: How to Colour in Weekends on BIRT Gantt Chart? [message #1682224 is a reply to message #1638826] Tue, 17 March 2015 12:51 Go to previous message
Attached is a sample that will show one way of doing it in script. The script can probably be cleaned up some. You also might consider setting the scale min and max based on your dataSet values vs just assuming as I did (I noted this in the code comments).
What I did was use afterDataSetFilled to find the min and max of the date series. From there, I extended the range on each side to account for BIRT padding the chart scale by a day on each side. I added a dummy marker range to my chart that I could copy and change the date values of to add to the chart. Finally, I loop through the dates represented in the chart and add a marker range for each weekend using the cloned dummy range. The dummy range is dropped from the chart.
Hope this helps.
Previous Topic:Report Birt Viewer 4.4.1 - WebLogic 10.3.6
Next Topic:Style - background image
Current Time: Thu Apr 24 07:18:59 EDT 2025
Powered by FUDForum. Page generated in 0.04747 seconds
