[JET] Resource-tags related exceptions when running "headless" transform [message #31226] |
Wed, 15 August 2007 21:53 |
Florian Georg Messages: 27 Registered: July 2009 |
I need to run a JET tarnsformation "headless", e.g. without the eclipse
UI popping up.
Therefore, I have defined a org.eclipse.core.runtime.applications
extension as a simple main entry point:
public class TransformationPlatformRunnable implements IPlatformRunnable {
public Object run(Object args) throws Exception {
TransformationRunner runner = new TransformationRunner();
runner.executeTransform();
return EXIT_OK;
The code is using the transformation API from the Rational Software
Architect, which internally delegates to a final JET transform.
Because of this, I'm not directly starting the JET transformation:
IPath path = new Path(filePath); // some RSA transformation config file
IFile file = ResourcesPlugin.getWorkspace().getRoot()
.getFileForLocation(path);
try {
ITransformConfig config = TransformConfigUtil
.loadConfiguration(file);
// This internally delegates to the JET transform
IStatus status = controller.execute(config, null, false, true, null);
} catch (Exception e) {
System.out.println("Failed transform execution");
The JET transformation itself goes over the intermediate model and calls
a bunch of ws:project and ws:file tags:
<c:iterate select="$eJB/serviceinterface" var="serviceinterface">
<%-- actions for $serviceinterface --%>
<%-- Begin: custom actions for $serviceinterface (1) --%>
<%-- End: custom actions for $serviceinterface (1) --%>
<ws:project name="{$serviceinterface/@name}"/>
<ws:folder path="{$serviceinterface/@name}/bin"/>
<ws:folder path="{$serviceinterface/@name}/src"/>
<ws:file path="{$serviceinterface/@name}/.classpath" replace="true"
template="templates/eJB/classpath.jet"/>
<ws:file path="{$serviceinterface/@name}/.project" replace="true"
template="templates/eJB/project.jet"/>
<ws:file
path=" {$serviceinterface/@srcBasePath}/{$serviceinterface/@shortNa meItf}.java "
replace="true" template="templates/serviceInterface/ServiceItf.java.jet"/ >
The transformation works fine from the runtime workbench UI, but since I
try to invoke it "headless" using the above mentioned application entry
point, there are these exceptions logged (in the .log file), and no
output files are generated:
!MESSAGE org.eclipse.core.internal.resources.ResourceException: The
project description file (.project) for CIF_Detail_1_0 is missing. This
file contains important information about the project. The project will
not function properly until this file is restored.
!STACK 0
org.eclipse.jet.taglib.JET2TagException:
org.eclipse.core.internal.resources.ResourceException: The project
description file (.project) for CIF_Detail_1_0 is missing. This file
contains important information about the project. The project will not
at
org.eclipse.jet.taglib.workspace.ActionsUtil.createProject(A ctionsUtil.java:519)
at
org.eclipse.jet.internal.taglib.workspace.WsProjectAction.pe rformAction(WsProjectAction.java:91)
at
org.eclipse.jet.taglib.workspace.WorkspaceContextExtender$3. run(WorkspaceContextExtender.java:238)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
Caused by: org.eclipse.core.internal.resources.ResourceException: The
at
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:656)
at
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:765)
at
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:672)
at org.eclipse.core.internal.resources.Project.open(Project.jav a:845)
at org.eclipse.core.internal.resources.Project.open(Project.jav a:883)
at
org.eclipse.jet.taglib.workspace.ActionsUtil.createProject(A ctionsUtil.java:505)
!SUBENTRY 1 com.csg.prototype.rsa.m2m.jet 4 1 2007-08-15 23:34:32.093
!MESSAGE Resource /CIF_Detail_1_0 is not open.
!STACK 0
org.eclipse.jet.taglib.JET2TagException: Resource /CIF_Detail_1_0 is not
open.
at
org.eclipse.jet.taglib.workspace.ActionsUtil.ensureFolderExi sts(ActionsUtil.java:244)
at
org.eclipse.jet.internal.taglib.workspace.WsFolderAction.per formAction(WsFolderAction.java:76)
at
at
org.eclipse.jet.taglib.workspace.WorkspaceContextExtender$2. run(WorkspaceContextExtender.java:227)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at
org.eclipse.jet.taglib.workspace.WorkspaceContextExtender$Co ntextData.commit(WorkspaceContextExtender.java:215)
at
org.eclipse.jet.transform.TransformContextExtender.commit(Tr ansformContextExtender.java:215)
at org.eclipse.jet.JET2Platform$4.run(JET2Platform.java:437)
at
org.eclipse.jet.internal.runtime.JETBundleManager.run(JETBun dleManager.java:336)
at org.eclipse.jet.JET2Platform.runTransform(JET2Platform.java: 398)
at org.eclipse.jet.JET2Platform.runTransformOnObject(JET2Platfo rm.java:501)
at com.ibm.xtools.transform.authoring.JETRule.createTarget(JETR ule.java:53)
at
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:145)
at
org.eclipse.core.internal.resources.Folder.assertCreateRequi rements(Folder.java:32)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:88)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:118)
at
org.eclipse.jet.taglib.workspace.ActionsUtil.ensureFolderExi sts(ActionsUtil.java:240)
... 50 more
Any ideas what is going wrong with the resources in that case?
Any help would be appreciated.... thanks in advance.
regards,
Florian
Re: [JET] Resource-tags related exceptions when running "headless" transform [message #31540 is a reply to message #31226] |
Mon, 27 August 2007 13:56 |
Paul Elder Messages: 849 Registered: July 2009 |
Florian:
The problem seems to come down to the project CIF_Detail_1_0 not being open.
Is this project created by the JET transform? Or did it exist before? The
JET ws:project tag does not attempt to open an existing project (perhaps it
should).
Paul
"Florian Georg" <florian.georg@ch.ibm.com> wrote in message
news:f9vshg$tc9$1@build.eclipse.org...
>I need to run a JET tarnsformation "headless", e.g. without the eclipse UI
>popping up.
> return EXIT_OK;
> [...] IPath path = new Path(filePath); // some RSA transformation config
> file
> try {
> <ws:file
> point, there are these exceptions logged (in the .log file), and no output
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> open.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: org.eclipse.core.internal.resources.ResourceException: Resource
> at
> at
> at
> ... 50 more
> regards,
> Florian
FUDForum. Page generated in 0.03166 seconds
