Home » Eclipse Projects » Sirius » unrecognized variable 'container' in drop descripton
unrecognized variable 'container' in drop descripton [message #1636871] Thu, 26 February 2015 12:17
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I'm creating a container drop tool. Such tool provides a precondition that determines whether the tool is elligable for execution. According to the context sensitive help, I should be able to determine use 'container' as the semantic element representing the target where I drop my source element.
However, using that variable results in the following error:
!ENTRY org.eclipse.acceleo.parser 4 0 2015-02-26 13:11:29.146
!MESSAGE Compilation error for expression [self.oclIsKindOf(Type) and self.eContainer(DomainModel) = container/] : Unrecognized variable: (container)
How do I retrieve the semantic element representing the target in drop tool description?
Greetings,
Wilbert.
Previous Topic:Split programmatically the main representation into several representations
Next Topic:Defining Relation-based Edge for Xtext Domainmodel
Current Time: Sat Jun 06 04:55:07 GMT 2020
Powered by FUDForum. Page generated in 0.06859 seconds
