Home » Archived » Sapphire » Combining root-node style and normal property editors on one page
Combining root-node style and normal property editors on one page [message #1636062] Wed, 25 February 2015 22:11 Go to next message
I would like to be able to have a page with some simple properties at the top and then the root-node style for the bottom of the page. I don't see to be able to get this to work, and I can't find an example.
<form-editor-page>
        <id>MappingsPage</id>
        <page-name>Mappings</page-name>
        <page-header-text>Mappings</page-header-text>
        <initial-selection>Mappings</initial-selection>
        <element-type>GeneratorConfig</element-type>
        <content>
        	<section>
	        		<content>
	        			<property-editor>MappingType</property-editor>
	        		</content>
			</section>
			<section>
		        <root-node>
		            <node>
		                <label>Mappings</label>
		                <section>
		                    <content>
		                        <actuator>
		                            <action-id>Sapphire.Add</action-id>
		                            <label>New Mapping</label>
		                        </actuator>
		                    </content>
		                    <description>Use this editor to manage your mapping config.</description>
		                </section>
		                <node-factory>
		                    <property>Mappings</property>
		                    <case>
		                        <label>${ operationName == null ? "&lt;operation&gt;" : operationName }</label>
		                        <section>
		                            <label>Mapping</label>
		                            <content>
		                                <include>MappingForm</include>
		                            </content>
		                        </section>
		                    </case>
		                </node-factory>
		            </node>
		        </root-node>
			</section>
		</content>
    </form-editor-page>
[Updated on: Wed, 25 February 2015 22:24] by Moderator
Re: Combining root-node style and normal property editors on one page [message #1636070 is a reply to message #1636062] Wed, 25 February 2015 22:17 Go to previous messageGo to next message
No, you cannot embed a master-details tree as a section of a form editor page. Typically you would put general/simple properties as a section under the root node with more detailed content as you drill down.
PS: If you use the code format block in the forum editor toolbar, it will be easier to read your code snippets.
Re: Combining root-node style and normal property editors on one page [message #1636078 is a reply to message #1636070] Wed, 25 February 2015 22:23 Go to previous messageGo to next message
Konstantin Komissarchik wrote on Wed, 25 February 2015 22:17
Thanks and was wondering how to do that. Appreciate your responsiveness. This is my second day of playing with Sapphire.
Re: Combining root-node style and normal property editors on one page [message #1636142 is a reply to message #1636070] Wed, 25 February 2015 23:08 Go to previous message
I actually managed to get my simple properties in the node root:
<node>
                <label>Enumeration Mappings</label>
                <section>
                    <content>
		                <with>
		                    <path>EnumerationMappings</path>
		                    <case>
		                        <content>
		                            <property-editor>MappingStrategy</property-editor>
		                        </content>
		                    </case>
		                </with>
						<spacer></spacer>
                        <actuator>
                        </actuator>
                    </content>
                </section>
                <node-factory>
                    <property>EnumerationMappings/EnumerationMappings</property>
                    <case>
                        <label>${ Name == null ? "&lt;name&gt;" : Name }</label>
                        <section>
                            <content>
                                <include>EnumerationMappingForm</include>
                            </content>
                        </section>
                    </case>
                </node-factory>
            </node>
Works nicely.
Previous Topic:InitialValue vs DefaultValue and persistence
Next Topic:Default value recomputed but not refreshed in UI on Linux
Current Time: Wed Jul 09 12:49:14 EDT 2025
Powered by FUDForum. Page generated in 0.04844 seconds
