Home » Archived » XML Schema Definition (XSD) » generating sample xml from xsd
generating sample xml from xsd [message #31164] |
Wed, 01 October 2003 22:17 |
Originally posted by: cipher8000.yahoo.com
Is there any util classes to generate sample xml from an xsd file? i know we
can use EMF to generate sample xml but it works with only eclipse UI...i am
looking for a stand-alone library to generate sample xml.
thanks
-muruga
Re: generating sample xml from xsd [message #31199 is a reply to message #31164] |
Wed, 01 October 2003 22:50 |
Muruga,
Generating XML instances would be a very cool stand-alone application for the
XSD model, but we haven't done that yet. It's an interesting and somewhat
open-ended problem. Are you considering building one using XSD or are you just
looking for one that already works?
Muruga Chinnananchi wrote:
> thanks
> -muruga
Re: generating sample xml from xsd [message #31232 is a reply to message #31199] |
Thu, 02 October 2003 05:53 |
Hi Ed,
Thanks the quick reply. Yes i was looking for a util class which already
works with XSD?
I thought i could use EMF model to generate xml but EMF works only inside
eclipse. I want something stand-alone.
If you have some ideas on implementing this, please let me know..i can go
ahead and implement it for XSD project.
-muruga
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3F7B5A4C.F4733786@ca.ibm.com...
Muruga,
the
just
we
am
> thanks
> -muruga
Re: generating sample xml from xsd [message #31268 is a reply to message #31232] |
Thu, 02 October 2003 09:29 |
Muruga,
I'm not sure what you mean by "EMF works only inside Eclipse". EMF is layered
so that may of its parts, including models and even EMF.Edit, work standalone
without any other Eclipse jars on the classpath. The problem of generating
model instances from an Ecore model, is a very similar problem to generating
XML instances from an XML Schema model, though I think it's a significantly
simpler problem, since XML Schema is about 5-10 times more complicated than
Ecore (even though they have roughly the same expressive power).
I don't have a lot of detailed thoughts on how to proceed. For a given schema
you'd consider all the global element declarations,
XSDSchema.getElementDeclarations, as candidates for the root element of an
instance. Then given the type definition of the root element, which is either
simple or complex, you'd use that information to generate either simple
content, or attribute and element content based on the complex type. You'd
have to guard against infinite recursion and you'd have to analyze carefully
the particle structure of a complex type to ensure you create a valid instance.
> Hi Ed,
> works with XSD?
> -muruga
> Muruga,
> the
> just
> > Hi,
> we
> am
> > thanks
> > -muruga
Re: generating sample xml from xsd [message #31377 is a reply to message #31268] |
Mon, 06 October 2003 11:26 |
Originally posted by: rob.tice.k-int.com
I have written a set of utility classes which generate an xml instance from
a schema using xsd. It x-references to find possible roots and it will
populate the instance from values within the relevant enumerations if
necessary. It resolves imports, redefines etc..
I have written it as a small part of an eductional metadata project that we
are working on in the UK. It is currently in testing and it will be a GPL
piece of code when it is released (as will the whole of the project, and
indeed as is all of our software). If this could be useful to the xsd
project even as a starting point just let me know and I will send the
relevant info to the list when it is tested.
Rob Tice
Technical Director
Knowledge Integration Ltd
news:3F7BEFED.11A1EBE0@ca.ibm.com...
> Muruga,
layered
standalone
generating
generating
significantly
than
schema
either
You'd
carefully
instance.
> > Hi Ed,
already
> > works with XSD?
inside
go
> > -muruga
> > Muruga,
for
> > the
somewhat
you
> > just
> > > Hi,
know
> > we
UI...i
> > am
> > > thanks
> > > -muruga
Re: generating sample xml from xsd [message #31433 is a reply to message #31377] |
Tue, 07 October 2003 10:18 |
Rob,
This sounds interesting. I'd like to have a look when it's available.
> Regards
> Rob Tice
> Technical Director
> > Muruga,
> layered
> standalone
> generating
> generating
> significantly
> than
> schema
> either
> You'd
> carefully
> instance.
> > > Hi Ed,
> already
> > > works with XSD?
> inside
> go
> > > -muruga
> > > Muruga,
> for
> > > the
> somewhat
> you
> > > just
> > > > Hi,
> know
> > > we
> UI...i
> > > am
> > > > thanks
> > > > -muruga
Re: generating sample xml from xsd [message #33740 is a reply to message #31433] |
Fri, 28 November 2003 08:41 |
Originally posted by: stefantura.poczta.onet.pl
I also works on some sort of XSD validator (generator) for simlpe XML files
on my student project - so if you could send some info, I will be greateful.
Anyway which method do you use for XML to XSD validation ?
best regards
Stefan Turalski
Uzytkownik "Ed Merks" <merks@ca.ibm.com> napisal w wiadomosci
news:3F8292D9.622CAF02@ca.ibm.com...
> Rob,
from
we
GPL
> > Regards
> > Rob Tice
> > Technical Director
> > > Muruga,
> > layered
> > standalone
> > generating
> > generating
> > significantly
> > than
given
> > schema
of an
is
> > either
simple
> > You'd
> > carefully
> > instance.
> > > > Hi Ed,
> > already
> > > > works with XSD?
> > inside
can
> > go
> > > > -muruga
> > > > Muruga,
application
> > for
> > > > the
> > somewhat
are
> > you
> > > > just
> > > > > Hi,
i
> > know
> > > > we
> > UI...i
> > > > am
> > > > > thanks
> > > > > -muruga
Re: generating sample xml from xsd [message #33774 is a reply to message #33740] |
Fri, 28 November 2003 10:54 |
Stefan,
I don't have any information on generating XML from XSD. As for validation,
there's XSDSimpleTypeDefinition.assess which can be used to validate a simple
value against a simple type, but there isn't such a method for validating a
complex value against a complex type because there's no support for that (yet).
Stfean Turalski wrote:
> best regards
> Stefan Turalski
> > Rob,
> from
> we
> GPL
> > > Regards
> > > Rob Tice
> > > Technical Director
> > > > Muruga,
> > > layered
> > > standalone
> > > generating
> > > generating
> > > significantly
> > > than
> given
> > > schema
> of an
> is
> > > either
> simple
> > > You'd
> > > carefully
> > > instance.
> > > > > Hi Ed,
> > > already
> > > > > works with XSD?
> > > inside
> can
> > > go
> > > > > -muruga
> > > > > Muruga,
> application
> > > for
> > > > > the
> > > somewhat
> are
> > > you
> > > > > just
> > > > > > Hi,
> i
> > > know
> > > > > we
> > > UI...i
> > > > > am
> > > > > > thanks
> > > > > > -muruga
Re: generating sample xml from xsd [message #579315 is a reply to message #31164] |
Ed Merks Messages: 33137 Registered: July 2009 |
Muruga,
> thanks
> -muruga
Ed Merks
Re: generating sample xml from xsd [message #579351 is a reply to message #31199] |
Hi Ed,
works with XSD?
-muruga
Muruga,
the
just
we
am
> thanks
> -muruga
Re: generating sample xml from xsd [message #579386 is a reply to message #31232] |
Muruga,
> Hi Ed,
> works with XSD?
> -muruga
> Muruga,
> the
> just
> > Hi,
> we
> am
> > thanks
> > -muruga
Ed Merks
Re: generating sample xml from xsd [message #579511 is a reply to message #31268] |
Rob Tice
Technical Director
> Muruga,
layered
standalone
generating
generating
significantly
than
schema
either
You'd
carefully
instance.
> > Hi Ed,
already
> > works with XSD?
inside
go
> > -muruga
> > Muruga,
for
> > the
somewhat
you
> > just
> > > Hi,
know
> > we
UI...i
> > am
> > > thanks
> > > -muruga
Re: generating sample xml from xsd [message #579546 is a reply to message #31377] |
Rob,
> Regards
> Rob Tice
> Technical Director
> > Muruga,
> layered
> standalone
> generating
> generating
> significantly
> than
> schema
> either
> You'd
> carefully
> instance.
> > > Hi Ed,
> already
> > > works with XSD?
> inside
> go
> > > -muruga
> > > Muruga,
> for
> > > the
> somewhat
> you
> > > just
> > > > Hi,
> know
> > > we
> UI...i
> > > am
> > > > thanks
> > > > -muruga
Ed Merks
Re: generating sample xml from xsd [message #581206 is a reply to message #31433] |
best regards
Stefan Turalski
> Rob,
from
we
GPL
> > Regards
> > Rob Tice
> > Technical Director
> > > Muruga,
> > layered
> > standalone
> > generating
> > generating
> > significantly
> > than
given
> > schema
of an
is
> > either
simple
> > You'd
> > carefully
> > instance.
> > > > Hi Ed,
> > already
> > > > works with XSD?
> > inside
can
> > go
> > > > -muruga
> > > > Muruga,
application
> > for
> > > > the
> > somewhat
are
> > you
> > > > just
> > > > > Hi,
i
> > know
> > > > we
> > UI...i
> > > > am
> > > > > thanks
> > > > > -muruga
Re: generating sample xml from xsd [message #581222 is a reply to message #33740] |
Stefan,
> best regards
> Stefan Turalski
> > Rob,
> from
> we
> GPL
> > > Regards
> > > Rob Tice
> > > Technical Director
> > > > Muruga,
> > > layered
> > > standalone
> > > generating
> > > generating
> > > significantly
> > > than
> given
> > > schema
> of an
> is
> > > either
> simple
> > > You'd
> > > carefully
> > > instance.
> > > > > Hi Ed,
> > > already
> > > > > works with XSD?
> > > inside
> can
> > > go
> > > > > -muruga
> > > > > Muruga,
> application
> > > for
> > > > > the
> > > somewhat
> are
> > > you
> > > > > just
> > > > > > Hi,
> i
> > > know
> > > > > we
> > > UI...i
> > > > > am
> > > > > > thanks
> > > > > > -muruga
Ed Merks
Current Time: Fri Apr 19 11:38:31 GMT 2024
Powered by FUDForum. Page generated in 0.04257 seconds
