Home » Language IDEs » Eclipse Web Tools Platform Project (WTP) » Unable to start Tomcat server 8(Getting error : Failed to destroy end point associated with ProtocolHandler ["ajp-nio-8009"])
Unable to start Tomcat server 8 [message #1633385] Tue, 24 February 2015 21:07
jawann jefferson is currently offline jawann jeffersonFriend
Hi all,
I am having a bit of an issue running Tomcat in eclipse. I am new to RESTful Web services so i was trying to follow a tutorial online. It was something really simple. Then i ran into the issue of my server not being able to start.
I get the error you see above when i try to start it. I had some errors before this one but took care of those. I am using attempting to use Jersey in a Dynamic Web Project. I ended up trying this because I am also trying to create a (what i thought) was a simple Android app. Anyways what i ended up doing was removing all my Jersey jar files in my lib directory. The server was then able to start up. Only issue was that now the code i had written that depended on that class were now in error. So i copied over the one class (javax.ws.rs-api-2.0.1.jar) to correct that error then when starting the server i received a "Servlet container" error. So then i copied over the Jersey-container-servlet-core.jar file into the lib directory. The server started. Now when i try to access my web services via the url i get this error:
type Exception report
message org/glassfish/jersey/server/spi/Container
description The server encountered an internal error that prevented it from fulfilling this request.
exception
java.lang.NoClassDefFoundError: org/glassfish/jersey/server/spi/Container
java.lang.ClassLoader.defineClass1(Native Method)
java.lang.ClassLoader.defineClass(Unknown Source)
java.security.SecureClassLoader.defineClass(Unknown Source)
org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2472)
org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:854)
org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1274)
org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1157)
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:489)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:516)
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1086)
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:659)
org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223)
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1558)
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1515)
java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
java.lang.Thread.run(Unknown Source)
root cause
java.lang.ClassNotFoundException: org.glassfish.jersey.server.spi.Container
org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1305)
I checked the logs but for some reason this was not logged. I saw logs from previous errors today but not this one.
I then added the jersey-server.jar file to the library and got this error. Also the server failed to start:
Feb 24, 2015 3:07:00 PM org.apache.coyote.AbstractProtocol destroy
INFO: Destroying ProtocolHandler ["ajp-nio-8009"]
SEVERE: Failed to destroy end point associated with ProtocolHandler ["ajp-nio-8009"]
at org.apache.tomcat.util.net.NioEndpoint.releaseCaches(NioEndpoint.java:307)
at org.apache.tomcat.util.net.NioEndpoint.unbind(NioEndpoint.java:482)
at org.apache.tomcat.util.net.AbstractEndpoint.destroy(AbstractEndpoint.java:795)
at org.apache.coyote.AbstractProtocol.destroy(AbstractProtocol.java:532)
at org.apache.catalina.connector.Connector.destroyInternal(Connector.java:1023)
at org.apache.catalina.util.LifecycleBase.destroy(LifecycleBase.java:305)
at org.apache.catalina.core.StandardService.destroyInternal(StandardService.java:588)
at org.apache.catalina.core.StandardServer.destroyInternal(StandardServer.java:859)
at org.apache.catalina.startup.Catalina.start(Catalina.java:629)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:351)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:485)
Any help would be appreciated.
EDIT: I also already have updated my web.xml file for Jersey 2.xx
<web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://java.sun.com/xml/ns/javaee" xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_3_0.xsd" id="WebApp_ID" version="3.0">
<display-name>RESTfulWebServices</display-name>
<welcome-file-list>
<welcome-file>index.html</welcome-file>
<welcome-file>index.htm</welcome-file>
<welcome-file>index.jsp</welcome-file>
<welcome-file>default.html</welcome-file>
<welcome-file>default.htm</welcome-file>
<welcome-file>default.jsp</welcome-file>
</welcome-file-list>
<servlet>
<servlet-name>Jersey</servlet-name>
<servlet-class>org.glassfish.jersey.servlet.ServletContainer</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/backend/*</url-pattern>
</servlet-mapping>
</web-app>
[Updated on: Tue, 24 February 2015 21:10]
Report message to a moderator
Previous Topic:Eclipse Luna not showing faces configuration on project explorer on linux
Next Topic:m2e project deployment to tcServer (tomcat) dependencies
Current Time: Tue Oct 20 07:10:19 GMT 2020
Powered by FUDForum. Page generated in 0.02163 seconds
