Running OSGi Console [message #1632465] |
Tue, 24 February 2015 09:40  |
Hi there,
In my deployed efxclipse product, the osgi console simply doesn't show up on product startup. The "-console" argument is added. The plugins:
org.eclipse.equinox.console
org.apache.felix.gogo.command
org.apache.felix.gogo.runtime
org.apache.felix.gogo.shell
are existant in plugins-folder of the exported product. The default console doesn't show up too, although the argument "-consoleLog" is added.
I'm running the appplication on win 7 with java 1.8_20. Targetplatform is Luna with efxclipse 1.2 .
Any hints on this issue ?
Kind regards
Re: Running OSGi Console [message #1632765 is a reply to message #1632758] |
Tue, 24 February 2015 13:16   |
It is. As well as:
Has anyone tried to run a deployed efxclipse product with an osgi console, yet ?
Re: Running OSGi Console [message #1633041 is a reply to message #1632765] |
Tue, 24 February 2015 16:43   |
How are you launching the exported product? Did you use the
javafx-packager?
Please note that to pass a on command parameters you need to make the
javafx-packager aware of them.
Tom
On 24.02.15 14:16, Christian Ora wrote:
> It is. As well as:
> console, yet ?
Re: Running OSGi Console [message #1634556 is a reply to message #1634305] |
Wed, 25 February 2015 10:28   |
Thank you for pointing me to this reference. I always felt that i was missing something.
Since "-console" and "-consoleLog" are program/application arguments. I assume the build.xml should look like this
<fx:application id="fxApplication" name="sandbox" mainClass="org.eclipse.equinox.launcher.Main" toolkit="swing">
<param name = "consoleLog"/>
<param name = "console"/>
</fx:application>
I tried several variations of this with "-console" & "-consoleLog" also tried the fx:argument and argument tag (basically the same i guess?). Neither brought the console to show up.
Btw. the eclipse.ini of the exported product looks like this
-nosplash
-consoleLog
-console
-vmargs
-Dosgi.framework.extensions=org.eclipse.fx.osgi
Re: Running OSGi Console [message #1634574 is a reply to message #1634556] |
Wed, 25 February 2015 10:36   |
> missing something.
> </fx:application>
> -nosplash
> -consoleLog
> -console
> -vmargs
Noone is looking at this file, only the eclipse launcher would have but
the exe you see is generated by the javafx packager. Dod you try jvmArgs
I can remember having seen them working.
Tom
Re: Running OSGi Console [message #1634926 is a reply to message #1634574] |
Wed, 25 February 2015 14:26   |
I added
<fx:platform>
<fx:jvmarg value="-Xms0m"/>
<fx:jvmarg value="-Xmx0m"/>
</fx:platform>
which should produce an Error(Couldn't create Java Virtual Machine),
but after deploying via build.xml the applications starts as usual.
I also tried to monitor the jvm of the deployed product via jps, to see if jvm args(with proper values) are passed, but it said that the process information was unavailable.
Also , when i call Platform.getCommandlineArgs() or Application.getParameters(), the List is empty. Do you think it is possible that there might be a bug ?
[Updated on: Wed, 25 February 2015 14:26] by Moderator Report message to a moderator
Re: Running OSGi Console [message #1634953 is a reply to message #1634926] |
Wed, 25 February 2015 14:43   |
At least I know I used this on OS-X if I remember correctly. I'll give
it a try on os-x to see if it works.
Naturally you are most likely better of testing this with a simple
JavaFX application and once you are confident it works there as
advertised you then try applying this to e4+javafx.
Tom
On 25.02.15 15:26, Christian Ora wrote:
> I added <fx:platform>
> </fx:platform>
> if jvm args are passed, but it said that the process information was
> unavailable.
Re: Running OSGi Console [message #1634962 is a reply to message #1634926] |
Wed, 25 February 2015 14:49   |
I think I only tried:
<fx:platform>
<property name="purpose" value="sample value"/>
</fx:platform>
So you should be able to check them with
System.getProperties().getProperty("purpose").
Tom
> </fx:platform>
> unavailable.
Re: Running OSGi Console [message #1667950 is a reply to message #1634962] |
Thu, 12 March 2015 09:05   |
A small update: It is possible to pass at least VM-Arguments by modifying the package.cfg file in the deployed product:
app.mainjar=plugins\org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
app.version=1.0
app.id=fxApplication
app.preferences.id=fxApplication
app.mainclass=org/eclipse/equinox/launcher/Main
jvmarg.1= -vmargument
app.classpath=
It took me quite long to figure that out, so i though it might be helpful to mention it here.
[Updated on: Thu, 12 March 2015 10:10] by Moderator Report message to a moderator
Re: Running OSGi Console [message #1668381 is a reply to message #1667950] |
Thu, 12 March 2015 13:06   |
Thanks - from my understanding that's what the ant statements should
have produced, not?
Tom
> app.version=1.0
> app.classpath=
> helpful to mention it here,
Re: Running OSGi Console [message #1678496 is a reply to message #1668381] |
Mon, 16 March 2015 08:06  |
At least my attempts to modify the ant script did fail, no matter if i used property, param, argument or jvmarg.
pckage.cfg stayed:
app.version=1.0
app.classpath=
But since i'm not familiar with ant, it might be possible that i put the statements/tags in wrong places, allthough tha ant script didn't complain.
FUDForum. Page generated in 0.04241 seconds
