Synchronous HD Items and Values [message #1631599] |
Mon, 23 February 2015 17:01  |
I have a scenario where we need to get the hd item tags and values synchronously rather using the listeners?
1. Are listeners the "only" way to get the data? If not, can you please provide the class or a sample that can be achieved synchronously. Any already existing tests would be grateful.
2. I am following your HMI HD Client and trying to see if you already have something like this.
Thanks for the great project!!!
krishna
Re: Synchronous HD Items and Values [message #1635040 is a reply to message #1634597] |
Wed, 25 February 2015 10:39  |
Jen,
Sorry, I meant HD items. Here is the code that am referring to:
import org.eclipse.scada.hd.ItemListListener;
import org.eclipse.scada.hd.client.Connection;
import org.eclipse.scada.hd.data.HistoricalItemInformation;
public class ItemListObserver implements ItemListListener
private final Map<String, HistoricalItemInformation> items = new HashMap<String, HistoricalItemInformation> ();
public ItemListObserver ( final Connection connection)
synchronized ( this )
connection.addListListener ( this );
public void listChanged ( final Set<HistoricalItemInformation> addedOrModified, final Set<String> removed, final boolean full )
handleUpdate ( addedOrModified, removed, full );
Is there a way for me to find if the retrieval is complete in the ItemListListener or should I be using a different approach?
Appreciate your help,
Krishna
FUDForum. Page generated in 0.29137 seconds
