Home » Eclipse Projects » Riena » How to close Application correctly
How to close Application correctly [message #1630707] Mon, 23 February 2015 10:46 Go to next message
Andreas Kowalski is currently offline Andreas KowalskiFriend
I build an application using Riena 5.0 on RAP, e3
I started with the example at: wiki.eclipse.org/Riena/Navigation
To see if the application exits correctly, e.g. when the browser reload-button is invoked, I put a breakpoint into the finalize methode of the SWTApplication class.
I wonder that the gc never calls the finalize. Hitting the browser-reload-button serveral times does invoke new Applications without garbage collecting them.
When i analysed the problem, I found that the
SWTApplication is referenced from AdvisorHelper,
AdvisorHelper is referenced from ApplicationAdvisor and ApplicationViewAdvisor
ApplicationAdvisor is referenced from Workbench
What is the correct way to close the session?
thx in advance!
Andreas
Re: How to close Application correctly [message #1631036 is a reply to message #1630707] Mon, 23 February 2015 14:53 Go to previous message
Christian Campo is currently offline Christian CampoFriend
Hi Andreas,
which version of RAP are you using ?
There is a Riena 6.0 Release out there from June 2014. Why dont you use that current release ? It has much better RAP support. Are you using RAP 2.3 or 2.3.1 which is from the same release train (Luna)
- christian
Previous Topic:Riena 5.0.0: No More Handles
Next Topic:riena.core deadlocks itself?
Current Time: Thu Aug 06 01:46:27 GMT 2020
Powered by FUDForum. Page generated in 0.02387 seconds
