Home » Newcomers » Newcomers » Eclipse Hangs(While using any editor)
Eclipse Hangs [message #506792] Sun, 10 January 2010 08:59 Go to next message
Sambi is currently offline SambiFriend
Eclipse is working fine as long as i don't open an editor but once I open any editor it keeps hanging and comes back for a second and hangs again.
I am using Windows 7 and eclipse galileo.
Can anyone help me.
Sambi
LOG
!ENTRY org.eclipse.ui 4 4 2010-01-10 02:36:22.324
!MESSAGE Invalid preference page path: HTML Syntax
!SESSION 2010-01-10 02:36:28.105 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.6.0_13
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.601
!MESSAGE NLS unused message: missingOneOfTwoAttributes in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.607
!MESSAGE NLS unused message: categoryNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.649
!MESSAGE NLS unused message: actionNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.654
!MESSAGE NLS unused message: actionAlreadyDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.660
!MESSAGE NLS unused message: presetNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.665
!MESSAGE NLS unused message: templateNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.670
!MESSAGE NLS unused message: invalidActionType in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.675
!MESSAGE NLS unused message: invalidEventHandlerType in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.680
!MESSAGE NLS unused message: invalidRequiresConstraint in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.686
!MESSAGE NLS unused message: invalidConflictsConstraint in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.693
!MESSAGE NLS unused message: deprecatedRuntimeChangedAction in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.698
!MESSAGE NLS unused message: tracingActionSorting in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.703
!MESSAGE NLS unused message: tracingFrameworkActivationStarting in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.708
!MESSAGE NLS unused message: tracingFrameworkActivationFinished in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.713
!MESSAGE NLS missing message: problemCaseNotRecognized in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.osgi 2 1 2010-01-10 02:36:38.965
!MESSAGE NLS missing message: runtimeComponentTypeNotDefined in: org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectFrameworkImpl
!ENTRY org.eclipse.wst.common.project.facet.core 4 0 2010-01-10 02:36:38.973
!MESSAGE Project facet jst.web has not been defined. It is used in plugin org.eclipse.wst.jsdt.web.core.
[Updated on: Sun, 10 January 2010 09:03]
Report message to a moderator
Re: Eclipse Hangs [message #506878 is a reply to message #506792] Mon, 11 January 2010 04:06 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
bsambireddy@gmail.com wrote:
> again.
> I am using Windows 7.
> Can anyone help me.
Please post a stack dump.
Dani
> Sambi
Re: Eclipse Hangs [message #507235 is a reply to message #506792] Tue, 12 January 2010 15:09 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
On 1/10/10 3:59 AM, bsambireddy@gmail.com wrote:
> again.
> Can anyone help me.
That is not nearly enough information for anyone to provide help.
Please see http://catb.org/~esr/faqs/smart-questions.html
Eric
Re: Eclipse Hangs [message #536663 is a reply to message #507235] Sat, 29 May 2010 13:45 Go to previous messageGo to next message
MrJay is currently offline MrJayFriend
I have the exact same problem. I'm running windows7 64bit with jdk1.6.0_20.
Eclipse runs fine but as soon as you open/edit a java file it hangs and restarts then hangs again.
Could someone help or advise on what I need to do? I can't find any log messages anywhere. The only log I found is in the workspace and frankly it's useless.
I'm a beginner at eclipse and so far it's not been a smooth ride.
Thanks in advance.
[Updated on: Sun, 30 May 2010 02:42]
Re: Eclipse Hangs [message #537135 is a reply to message #536663] Tue, 01 June 2010 12:41 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> Eclipse runs fine but as soon as you open/edit a java file with hangs
> Could someone help or advise on what I need to do? I can't find any logs
> messages anywhere. The only log i found is in the workspace and frankly
> it's useless.
> Thanks in advance.
Are you certain you're not mixing 64-bit Eclipse with 32-bit JDK or a
64-bit JDK with a 32-bit Eclipse?
Re: Eclipse Hangs [message #537394 is a reply to message #537135] Wed, 02 June 2010 10:01 Go to previous messageGo to next message
Russell Bateman wrote on Tue, 01 June 2010 08:41
> it's useless.
> Thanks in advance.
I've tried both versions and still same result. Seems like a UI issue as when I switch between applications, then back to eclipse it updates. But a second later it hangs again.
I've downloaded 3.6 (helios) and that seems to work fine. So i'll use that for now.
Thanks anyway.
Re: Eclipse Hangs [message #537678 is a reply to message #537394] Thu, 03 June 2010 11:14 Go to previous messageGo to next message
MrJay wrote on Wed, 02 June 2010 06:01
Thanks anyway.
Ok this is happening again and it seems related to my graphics card which is a nvidia 280 GTX. I did update to the latest drivers. Does anyone else have this problem?
Re: Eclipse Hangs [message #541401 is a reply to message #506792] Sun, 20 June 2010 22:32 Go to previous messageGo to next message
Andrew Tonner is currently offline Andrew TonnerFriend
I can easily trigger this problem by opening Windows 7's On-Screen Keyboard accessory. When On-Screen Keyboard is running, even when it is minimized and I've only used the regular keyboard with Eclipse, Eclipse becomes unresponsive every few seconds when an editor is open. Closing On-Screen Keyboard makes the problem go away.
Note that the On-Screen Keyboard accessory has unusual focusing behaviour to accomodate using it with other applications.
Obviously some people absolutely must have something like On-Screen Keyboard for accessibility reasons; however there are many similar programs available for free online that work fine with Eclipse.
Installation details:
  • My Eclipse Galileo (3.5) installation claims to be build 20100218-1602.
  • I'm using RSE/TM, Mylyn, Subclipse 1.6, and Pydev 1.5.7.
  • I'm using 32-bit Sun Java 6 SE runtime 1.6.0_20-b02.
  • I'm running on Windows 7 Ultimate 64-bit on a Core 2 Quad with 8GB of RAM.
  • I'm using NVIDIA GeForce 9800 GT and GeForce 8800 GS graphics cards. Device manager tells me that I'm using driver version 8.16.11.9107 of 27/09/2009.
Re: Eclipse Hangs [message #541410 is a reply to message #506792] Mon, 21 June 2010 04:23 Go to previous message
I've filed a bug for this as https://bugs.eclipse.org/bugs/show_bug.cgi?id=317390
Previous Topic:Trying to configure/add junit test in eclipse
Next Topic:Missing WYSIWYG JSP Palette
Current Time: Fri Sep 01 05:40:33 GMT 2023
Powered by FUDForum. Page generated in 0.04593 seconds
