Home » Language IDEs » C / C++ IDE (CDT) » Dynamic and Static libraries(Working to compile an external library)
Dynamic and Static libraries [message #1827737] Fri, 22 May 2020 07:01 Go to next message
Keyara Edwards is currently offline Keyara EdwardsFriend
So I've tried adding both a static and dynamic libraries in eclipse using the MinGw linker and gcc++ compiler with limited success would anybody be able to clearly explain how to correctly do so. The errors i've run into area:
- the file type was not supported
-file could not be found
and then this wonderful error message as well:
-C:/Program Files (x86)/mingw-w64/i686-8.1.0-posix-dwarf-rt_v6-rev0/mingw32/bin/../lib/gcc/i686-w64-mingw32/8.1.0/../../../../i686-w64-mingw32/bin/ld.exe: cannot find -lD:\workspace\Libraries\C++\SDL2-2.0.12-win32-x64\SDL2.dll
Which after labeling clearly where everything was in the project manager has made me want to smash my pc, please help if possible.
Side note: I have added path in the path&symbols and in the tools under build with correct path to library.
Side note to side note: I might have not done it correctly but there are no compile errors like previous about file not found till the above one.
Re: Dynamic and Static libraries [message #1827740 is a reply to message #1827737] Fri, 22 May 2020 09:17 Go to previous message
David VavraFriend
FWIW: I haven't used MinGW in a long time
but I don't think you can include a path in the -l (small L) option.
It's meant to be a shorthand notation of libXXX.a (or a Windows equivalent)
For MinGW, it's a bit more complicated.
https://stackoverflow.com/questions/15852677/static-and-dynamic-shared-linking-with-mingw/15853231#15853231
Are you telling the linker to use a DLL?
You can't use a Windows DLL with MinGW that was generated with MSVC++
http://www.mingw.org/wiki/MSVC_and_MinGW_DLLs
https://stackoverflow.com/questions/2472924/linking-to-msvc-dll-from-mingw/2473242
Some additional reading:
http://www.mingw.org/wiki/HOWTO_Specify_the_Location_of_Libraries_for_use_with_MinGW
https://docs.microsoft.com/en-us/windows/win32/dlls/dynamic-link-library-search-order
http://www.mingw.org/wiki/specify_the_libraries_for_the_linker_to_use
http://www.mingw.org/wiki/sampleDLL
This forum is for addressing issues with CDT.
Issues involving using external tools are generally off-topic.
While CDT allows you to specify options so that it can generate makefile recipes,
it is assumed you know what those options mean and how to apply them.
Previous Topic:make: *** [Hello_World.elf] Error 1 Nios II Eclipse
Next Topic:Eclipse Locking Up
Current Time: Tue May 26 14:10:31 GMT 2020
Powered by FUDForum. Page generated in 0.02062 seconds
