Home » Modeling » Epsilon » Looking for MDD case studies
Looking for MDD case studies [message #1404446] Fri, 01 August 2014 13:14 Go to next message
Bernhard Hoisl is currently offline Bernhard HoislFriend
Hello community,
I'm looking for publicly available MDD-related case studies to evaluate a research prototype. In particular, the case studies should include MMs (at best defined in Ecore), instance models, and M2T generator templates (at best defined via EGL)---the targeted host language does not matter (e.g., Java, C#, Ruby or even non-executable text etc.). I have found some examples and case studies, but they are all too small because I would need M2T templates with (at best) several hundreds of LoC. Comparatively large MMs are also a benefit.
It wouldn't be much of a problem if MMs are not based on Ecore, or if instance models are not existent, or even if M2T transformations are not specified via EGL but with any other technology employing generation templates (such as Acceleo, Xpand etc.).
Any hints are greatly appreciated.
Thanks and best regards,
Bernhard
[Updated on: Fri, 01 August 2014 13:28]
Report message to a moderator
Re: Looking for MDD case studies [message #1404447 is a reply to message #1404446] Fri, 01 August 2014 13:17 Go to previous messageGo to next message
[message content deleted because obsolete]
[Updated on: Fri, 01 August 2014 15:26]
Re: Looking for MDD case studies [message #1404484 is a reply to message #1404447] Fri, 01 August 2014 18:40 Go to previous messageGo to next message
Arunkumar Ramaswamy is currently offline Arunkumar RamaswamyFriend
Member
This is a MDD based toolchain for robotics software development
http://wiki.ros.org/bride/
Re: Looking for MDD case studies [message #1419994 is a reply to message #1404484] Tue, 09 September 2014 10:59 Go to previous message
Maarten Bezemer is currently offline Maarten BezemerFriend
A bit late, so I do not know whether you are still looking...
TERRA is an MDD tool-suite aiding the development software for cyber-physical systems. It uses (ecore) meta-models extensively and EGL M2T code generation (to C++ code for example).
Our publications/papers on TERRA can be found at http://www.ce.utwente.nl/ECSSoftware/documentation.php
Previous Topic:[EOL/ECL] 'add()' method not known for type 'Set'?
Next Topic:Assigning Literals of an Enum
Current Time: Fri Feb 23 22:38:20 GMT 2018
Powered by FUDForum. Page generated in 0.02220 seconds
