Home » Modeling » OCL » [OCL Console] Access Package of model
[OCL Console] Access Package of model [message #999186] Fri, 11 January 2013 09:34 Go to next message
I try to derive annotations which I attached to the root package of my ecore model. To do so I navigate from the root model element of my model to the instance of the package by using .eContainer(). From this I want to get the meta model class to retrieve the annotations from. For this I use .eClass(). This command, however, throws an Exception. How can I get around this problem.
Ralph
	at org.eclipse.ocl.AbstractEvaluationEnvironment.callOperation(AbstractEvaluationEnvironment.java:205)
	at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperation(EcoreEvaluationEnvironment.java:165)
	at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.callOperation(EcoreEvaluationEnvironment.java:1)
	at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:261)
	at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(OperationCallExpImpl.java:390)
	at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(AbstractEvaluationVisitor.java:248)
	at org.eclipse.ocl.OCL.evaluate(OCL.java:456)
	at org.eclipse.ocl.examples.interpreter.console.OCLConsolePage.evaluate(OCLConsolePage.java:468)
	at org.eclipse.ocl.examples.interpreter.console.OCLConsolePage$InputKeyListener.keyPressed(OCLConsolePage.java:646)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:167)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
	at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1521)
	at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4640)
	at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:345)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4528)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: [OCL Console] Access Package of model [message #999205 is a reply to message #999186] Fri, 11 January 2013 09:59 Go to previous messageGo to next message
Without any form of repro it is very difficult to know why the
invocation of a Java Method bombs. I can just guess that you are using
an inappropriate data type, argument list or multiplicity.
You could try using the Xtext OCL Console instead, where the problem
will almost certainly be at least a little different and might have a
better diagnostic.
Ed Willoink
On 11/01/2013 14:34, Ralph Gerbig wrote:
> Ralph
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
Re: [OCL Console] Access Package of model [message #999211 is a reply to message #999205] Fri, 11 January 2013 10:10 Go to previous messageGo to next message
Hi Ed,
thanks for your reply. The statement I use on Interactive Console is
self.oclAsType(ecore::EObject).eContainer().eClass()
the XText console is already breaking when doing
self.oclAsType(ecore::EObject) with the message
Evaluating:
Results:
Incompatible argument type 'ecore::EObject'
Do you know how I can cast to EObject with the XText console?
Ralph
Re: [OCL Console] Access Package of model [message #999532 is a reply to message #999211] Sat, 12 January 2013 05:58 Go to previous messageGo to next message
With the Interactive OCL Console you need to specify that your objects
extend EObject. You can do this interactively using the
Window->Preferences->OCL->Ecore and UML bindings option. The final
preference is the "Static instance for the implicit-root class option".
Select EObject rather than None from the pull-down menu.
With the Interactive Xtext OCL Console you can use prototypes for new
OCL functions.
self.oclContainer().oclType()
You can only cast to EObject if EObject is declared in your metamodel as
a supertype. If so you can do
self.oclAsType(_'http://www.eclipse.org/emf/2002/Ecore'::EObject).eContainer()
or if 'ecore' is declared
Ed Willink
On 11/01/2013 15:10, Ralph Gerbig wrote:
> Hi Ed,
> Quote:
>> Evaluating:
>> Results:
> Ralph
Re: [OCL Console] Access Package of model [message #999921 is a reply to message #999532] Sun, 13 January 2013 07:38 Go to previous messageGo to next message
Hi Ed,
thanks for your reply. I solved the problem by doing
self.oclAsType(ecore::EObject).eClass().ePackage
About interactive console:
The "Static instance for the implicit-root class option" entry is null and not EObject in my case but I can still do the cast. Is this intended or shall I open a bug on this?
About XText Console:
The code completition does not show functions like oclContainer. Where can I find an overvier of all these functions. Is there a meta-model where I can see these functions?
a supertype.
I always thought EObject would be the implicit super type of all EMF Objects but this seems to not apply to OCL. What could I do to get all EMF operations available without introducing things like EObject into my meta model? Will all eXXX() functions become a oclXXX counterpart in future?
Ralph
Re: [OCL Console] Access Package of model [message #999927 is a reply to message #999921] Sun, 13 January 2013 07:56 Go to previous message
You 'can' cast to EObject but you get a run-time failure without the
implicit root option. Perhaps therew should be a validation warning.
The library functions are all in the documentation! Help->Contents->OCL
Documentation->OCL Standard Library.
If you are using a Kepler milestone release, please raise a Bugzilla
about oclContainer() completion.
EObject stopped being the modeled ancestor of all EObjects in EMF at
Helios M4. Nothing to do with OCL. It was a side effect of the
introduction of eInvoke support for which it was considered that
imposing a full set of EObject EOperation literals on every class of
every model was undesirable. Actually modeling-wise this was a bug fix,
since EObject should never have been visible when not present in the
user's model.
Ed Willink
On 13/01/2013 12:38, Ralph Gerbig wrote:
> Hi Ed,
> self.oclAsType(ecore::EObject).eClass().ePackage.
> Quote:
>> as a supertype.
> in future?
> Ralph
Previous Topic:[OCLinEcore] eReference eKeys eOpposite
Next Topic:[Announce] Eclipse OCL 4.0.2 (Juno) SR2 RC1 is now available
Current Time: Sun Jul 20 16:13:10 EDT 2025
Powered by FUDForum. Page generated in 0.03777 seconds
