Home » Eclipse Projects » EGit / JGit » Problems Installing EGit
Problems Installing EGit [message #994636] Thu, 27 December 2012 17:20 Go to next message
I'm trying to get EGit installed on Eclipse Juno, but for some reason the installation doesn't take.
I'm installing from this P2 repository:
EGit http://download.eclipse.org/egit/updates/ Enabled
I've got these feature groups allegedly installed:
Eclipse EGit 2.2.0.201212191850-r org.eclipse.egit.feature.group
Eclipse JGit 2.2.0.201212191850-r org.eclipse.jgit.feature.group
However, I don't have any of the plugins that should have been deployed with those feature groups:
org.eclipse.egit
org.eclipse.egit.core
org.eclipse.egit.ui
org.eclipse.jgit
Why would the installer not actually deploy the plugins?
Andrew
Re: Problems Installing EGit [message #998239 is a reply to message #994636] Wed, 09 January 2013 11:24 Go to previous messageGo to next message
Could you please describe in more detail which steps you take and where you look for the plugins? Is there any error message or warning during installation?
Re: Problems Installing EGit [message #998333 is a reply to message #998239] Wed, 09 January 2013 15:28 Go to previous messageGo to next message
we need more details of your installation:
- operating system
- which Juno package did you install (Classic, Java, J2EE ...) ?
- is it Juno or Juno SR1 ?
- check the error log for related error messages
In order to check if the bundles are installed successfully click "About Eclipse > Installation Details"
Under "Features" you should find at least the following features (depending on your selection during installation):
- org.eclipse.jgit
- org.eclipse.egit
under "Plug-ins" you should find at least the following plug-ins
- org.eclipse.jgit
- org.eclipse.egit.core
- org.eclipse.egit.ui
under "Installation History" you should find a corresponding entry for the time when you installed EGit.
Select this history entry and check if JGit and EGit are listed underneath.
Re: Problems Installing EGit [message #998840 is a reply to message #998333] Thu, 10 January 2013 14:56 Go to previous messageGo to next message
I seem to have the same problem as the OP, and to answer the questions:
When I try to create a new project Git is not an option.
OS: Linux (opensuse 12.2)
Package: Juno SR1 J2EE,
Didn't see related error messages. Nothing about git or team providers
I have the mentioned features and plugins
This is a fresh install (~1h ago) of eclipse because of exactly this problem.
To get there I installed/unpacked
- Eclipse J2ee in an empty directory
- Added CDT repo and installed it
- Added Php support via market
- Added Maven support via Market
- Added Maven git and svn provider -> this works
- Added Mercurial support via Market (new project from mercurial works)
- Added EGit/JGit via market
- Added SVN support via market (new project from svn works)
- Added ADT support via market
- Went to Add New Software, All available sites, search for git, show only latest, applicable to target. When I also select Hide installed, git team provider vanishes.
I found a dialog where it said the EGit plugin was in state "Starting".
Re: Problems Installing EGit [message #1008970 is a reply to message #998840] Thu, 14 February 2013 03:24 Go to previous message
Are there any suspicious errors in the error log ?
Previous Topic:ArchiveCommand
Next Topic:Tracking of Audio Files
Current Time: Sat Jul 19 21:27:57 EDT 2025
Powered by FUDForum. Page generated in 0.05068 seconds
