Home » Modeling » TMF (Xtext) » Noobie Q: Problem to run the Generated IDE Plug-in of my DSL (Xtext) with Eclipse Juno. (For my termpaper !! deadline end of January ! = PLEASE HELP --- Im about to model a simple library grammar with Xtext. The Xtext language generator is probably not even generating sucessfully. Result)
Noobie Q: Problem to run the Generated IDE Plug-in of my DSL (Xtext) with Eclipse Juno. [message #997357] |
Sun, 06 January 2013 17:50  |
Hello you -(are u my savior?)! PLEASE HELP me getting this project done! Im even open for private (Email/Online) paid tutoring! Just contact me!
I have the following grammar of a little simple library,which im desperatly trying to test. Its not working. I started working with normal Eclipse, but then it didnt worked properly (it hasnt had Xtext or i didn't knew how to start it..), so i downloaded Eclipse juno. Now im stuck!
Here the grammar: (translated from German)
grammar ...
generate library ".xtext.org/example/mydsl2/library"
Medien:
'New User, Name und Number:'
(Borower+=Borower+) '{'
(Aktion+=Aktion+) '}' ;
Borower:
'Name:' name=STRING
'Number:' number=ID;
Aktion:
Borowing | Return ;
Borowing: 'Borowing' (Medium+=Medium+) ;
Return: 'Return' (Medium+=Medium+) ;
Medium:
Book | CD | DVD ;
Buch:
'Booktitle:' booktitle=STRING
'Booknr:' nummer=ID
'Due:' weeknr=INT 'Weeks';
CD: 'CDtitel:' cdtitel=STRING
'CDnumber' nummer=ID
DVD: 'DVDtitel:' dvdtitel=STRING
'DVDnumber' nummer=ID
The problem is that, if i run this grammar from eclipses context menu, i choose
Run As -> Generate Xtext Artifacts. (The Xtext tutorial which im using says that i need to click on: Run As -> MWE2 Workflow. but there is nothing like that here as option. )
So i click on Generate Xtext Artifacts. That triggers the Xtext language generator and the console is showing several messages. for example its showing:
*ATTENTION*
It is recommended to use the ANTLR 3 parser generator (BSD licence - ...antlr.org/license.html).
Do you agree to download it (size 1MB) from '..download.itemis.com/antlr-generator-3.2.0.jar'? (type 'y' or 'n' and hit enter)y
..... I hit enter and its saying in the end:
23135 [main] INFO text.generator.junit.Junit4Fragment - generating Compare Framework infrastructure
23352 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
----------- In between the lines of the console there are errors which says: ----
22050 [main] INFO or.validation.JavaValidatorFragment - generating Java-based EValidator API
warning(200): ../org.xtext.example.Buchausleihe.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: Decision can match input such as "'Ausleihe' 'DVDtitel:' RULE_STRING 'DVDausleihnummer' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
warning(200): ../org.xtext.example.Buchausleihe.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: Decision can match input such as "'Ausleihe' 'CDtitel:' RULE_STRING 'CDausleihnummer' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
warning(200): ../org.xtext.example.Buchausleihe.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: Decision can match input such as "'Ausleihe' 'Buchtitel:' RULE_STRING 'Buchausleihnummer:' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
error(201): ../org.xtext.example.Buchausleihe.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: The following alternatives can never be matched: 2
And after it is done. The Project manager on the left side of eclipse is showing me errors within the project itself.
In the folder: src-gen / parser and src-gen/ AbstractLibraryRuntimeModule
After this problems it doesnt suprises me, that if i click on Run As -> Launch Runtime Eclipse ... it opens a new workbench, but nothing else is happening. Im not even sure how to successfully create a File in the new Project on the new workbench, which is generated from the DSL.
Also there is a Window opening which is saying:
EGit does not require Git to function, but there may be important settings in the installation directory that EGit needs to know about in order to be compatible with Git. The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in the etc directory of the Git installation. The directory of the Git installation. The directory can be configured in Preferences under Team > Git.
I tried to fix that with the help of this forum, but seems that it doesnt worked. I did all what is said here in the forum.
Anyway, do i really need to fix that? Shouldn't it work just as it is?
What shall I do?
I just wanna run the grammar to test if it works. Nothing else.
I would be greatful for your help! Im willing to pay, if necessary, but please contact me if you think you could help me.
Have a nice day anyway, and thanks for reading =)
Anna
Re: Noobie Q: Problem to run the Generated IDE Plug-in of my DSL (Xtext) with Eclipse Juno. [message #997614 is a reply to message #997357] |
Sun, 06 January 2013 19:35   |
Not sure about the mwe vs "generate xtext artifacts" mis-match, maybe
that is something that has recently changed. It used to be that you ran
a mwe workflow (that was generated as a standard workflow when the xtext
project was created). Typically one needs to edit this workflow to suite
the needs of the language being implemented; but the auto generated
should be fine to start with.
Not surprising that you can not run anything; the generator(s) that
tried to produce things from your grammar failed (it reported errors).
You need to first get your grammar error free (and warning free, as
those warnings are telling you things you want to address).
You can't get to the next stage of actually running / doing anything
until you got those fixed.
Suggest that you start with a simple example (a grammar known to be
working) - this to make sure you have everything installed as you should.
Also, to get help on a grammar, you need to post the entire grammar
including the terminals. (Matching the shown errors with the grammar
translated into English is difficult - it is possible to guess (I know a
bit of German), but... hard to see what would cause the errors you are
getting without there being issues in the terminals.
Think it would work better if you post the original German grammar.
(after all .. the Itemis people are mostly from Germany anyway :)).
If you are in a hurry, just contact Itemis and have them help you for a fee.
Best Regards
- henrik
> stuck!
> grammar ...
> Medien:
> Borower:
> 'Name:' name=STRING
> Aktion: Borowing | Return ;
> Medium:
> Book | CD | DVD ;
> Buch:
> 'Booktitle:' booktitle=STRING 'Booknr:' nummer=ID
> CD: 'CDtitel:' cdtitel=STRING 'CDnumber' nummer=ID
> DVD: 'DVDtitel:' dvdtitel=STRING 'DVDnumber' nummer=ID
> choose
> showing:
> *ATTENTION*
> hit enter)y
> says: ----
> warning(200):
> warning(200):
> warning(200):
> error(201):
> showing me errors within the project itself. In the folder: src-gen /
> > Git.
> What shall I do? I just wanna run the grammar to test if it works.
> Nothing else.
> Have a nice day anyway, and thanks for reading =) Anna
Re: Noobie Q: Problem to run the Generated IDE Plug-in of my DSL (Xtext) with Eclipse Juno. [message #998265 is a reply to message #997366] |
Wed, 09 January 2013 12:31   |
Hello you two! And thanks to both of you for the quick reply!!! THANK YOU SO MUCH!
It didn't really help though.
Alexander, i tried both a and b and it didnt changed the problem, that i couldn't start the grammar.
Henrik, you're right - my grammar seems to be wrong. So im gonna post the original grammar below.
The thing is im a noobie in this field. So im making also noobie-mistakes!!! For example i've got a test gramma working and realised that i did the start process wrong: here is how it seems to be right.
So first i click on the grammar itself and say, run as..-> generate XText Artifacts. Then in the same folder there is a file called Generate(MyfileName).mwe2. I click with the right mouse on it and say run as.. -> MWE2 Workflow. Only then i click on the project and run it as a Eclipse application. In the new window im making a new project with a new file and the file extention, i choose in the beginning. THIS PROCEDURE worked for the standard "Hello" Project. It actually showed me hello!
THis is the right way? RIGHT? ?
SO IT NEEDS TO BE A PROBLEM WITH THE GRAMMAR. I hope someone can help me with finding the failure. What does the Errors tells you?
Thanks in advance for any further comment!!!!!! =)
Here the Grammar in German:
grammar org.xtext.example.mydsl2.Buchausleihe with org.eclipse.xtext.common.Terminals
generate buchausleihe "ww.xtext.org/example/mydsl2/Buchausleihe"
Medienausleihe:
'Neuer User, Name und Nutzernummer:'
(Ausleiher+=Ausleiher+) '{'
Ausleiher:
'Name:' name=STRING
'Ausweisnummer:' ausweisnummer=ID;
Aktion:
Ausleihe | Rueckgabe ;
Ausleihe: 'Ausleihe' (Medium+=Medium+) ;
Rueckgabe: 'Ausleihe' (Medium+=Medium+) ;
Medium:
Buch | CD | DVD ;
Buch:
'Buchtitel:' buchtitel=STRING
'Buchausleihnummer:' nummer=ID
'Ausleihdauer:' wochenanzahl=INT 'Wochen';
'CDausleihnummer' nummer=ID
'DVDausleihnummer' nummer=ID
------- Here is what the console say, when i click on Generate Xtext Artifacts --------------------
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri 'D:\Benutzer\Anna\workspace'
2093 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
2312 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'ww.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
2328 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'ww.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
2328 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'ww.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
2328 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
2812 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning D:\Benutzer\Anna\workspace\org.xtext.example.mydsl5\..\org.xtext.example.mydsl5\src-gen
2844 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning D:\Benutzer\Anna\workspace\org.xtext.example.mydsl5\..\org.xtext.example.mydsl5.ui\src-gen
2984 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for org.xtext.example.mydsl2.Buchausleihe with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, SerializerFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, GeneratorFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, Junit4Fragment, RefactorElementNameFragment, TypesGeneratorFragment, XbaseGeneratorFragment, CodetemplatesGeneratorFragment, CompareFragment
4606 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'www.xtext.org/example/mydsl2/Buchausleihe' from 'platform:/resource/org.xtext.example.mydsl5/src-gen/org/xtext/example/mydsl2/Buchausleihe.genmodel'
warning(200): ../org.xtext.example.mydsl5/src-gen/org/xtext/example/mydsl2/parser/antlr/internal/InternalBuchausleihe.g:214:1: Decision can match input such as "'Ausleihe' 'CDtitel:' RULE_STRING 'CDausleihnummer' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
warning(200): ../org.xtext.example.mydsl5/src-gen/org/xtext/example/mydsl2/parser/antlr/internal/InternalBuchausleihe.g:214:1: Decision can match input such as "'Ausleihe' 'Buchtitel:' RULE_STRING 'Buchausleihnummer:' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
warning(200): ../org.xtext.example.mydsl5/src-gen/org/xtext/example/mydsl2/parser/antlr/internal/InternalBuchausleihe.g:214:1: Decision can match input such as "'Ausleihe' 'DVDtitel:' RULE_STRING 'DVDausleihnummer' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
error(201): ../org.xtext.example.mydsl5/src-gen/org/xtext/example/mydsl2/parser/antlr/internal/InternalBuchausleihe.g:214:1: The following alternatives can never be matched: 2
6935 [main] ERROR enerator.CompositeGeneratorFragment - java.io.FileNotFoundException: ..\org.xtext.example.mydsl5\src-gen\org\xtext\example\mydsl2\parser\antlr\internal\InternalBuchausleiheLexer.java (Das System kann die angegebene Datei nicht finden)
org.eclipse.emf.common.util.WrappedException: java.io.FileNotFoundException: ..\org.xtext.example.mydsl5\src-gen\org\xtext\example\mydsl2\parser\antlr\internal\InternalBuchausleiheLexer.java (Das System kann die angegebene Datei nicht finden)
at org.eclipse.xtext.util.Files.readFileIntoString(Files.java:129)
at org.eclipse.xtext.generator.parser.antlr.AbstractAntlrGeneratorFragment.suppressWarningsImpl(AbstractAntlrGeneratorFragment.java:132)
at org.eclipse.xtext.generator.parser.antlr.AbstractAntlrGeneratorFragment.suppressWarnings(AbstractAntlrGeneratorFragment.java:142)
at org.eclipse.xtext.generator.parser.antlr.AbstractAntlrGeneratorFragment.suppressWarnings(AbstractAntlrGeneratorFragment.java:138)
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment.generate(XtextAntlrGeneratorFragment.java:49)
at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:92)
at org.eclipse.xtext.generator.LanguageConfig.generate(LanguageConfig.java:113)
at org.eclipse.xtext.generator.Generator.generate(Generator.java:361)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:128)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: java.io.FileNotFoundException: ..\org.xtext.example.mydsl5\src-gen\org\xtext\example\mydsl2\parser\antlr\internal\InternalBuchausleiheLexer.java (Das System kann die angegebene Datei nicht finden)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at org.eclipse.xtext.util.Files.readFileIntoString(Files.java:126)
... 18 more
6935 [main] INFO or.validation.JavaValidatorFragment - generating Java-based EValidator API
warning(200): ../org.xtext.example.mydsl5.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: Decision can match input such as "'Ausleihe' 'DVDtitel:' RULE_STRING 'DVDausleihnummer' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
warning(200): ../org.xtext.example.mydsl5.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: Decision can match input such as "'Ausleihe' 'CDtitel:' RULE_STRING 'CDausleihnummer' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
warning(200): ../org.xtext.example.mydsl5.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: Decision can match input such as "'Ausleihe' 'Buchtitel:' RULE_STRING 'Buchausleihnummer:' RULE_ID 'Ausleihdauer:' RULE_INT 'Wochen'" using multiple alternatives: 1, 2
error(201): ../org.xtext.example.mydsl5.ui/src-gen/org/xtext/example/mydsl2/ui/contentassist/antlr/internal/InternalBuchausleihe.g:316:1: The following alternatives can never be matched: 2
7373 [main] ERROR enerator.CompositeGeneratorFragment - java.io.FileNotFoundException: ..\org.xtext.example.mydsl5.ui\src-gen\org\xtext\example\mydsl2\ui\contentassist\antlr\internal\InternalBuchausleiheLexer.java (Das System kann die angegebene Datei nicht finden)
org.eclipse.emf.common.util.WrappedException: java.io.FileNotFoundException: ..\org.xtext.example.mydsl5.ui\src-gen\org\xtext\example\mydsl2\ui\contentassist\antlr\internal\InternalBuchausleiheLexer.java (Das System kann die angegebene Datei nicht finden)
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrUiGeneratorFragment.generate(XtextAntlrUiGeneratorFragment.java:53)
Caused by: java.io.FileNotFoundException: ..\org.xtext.example.mydsl5.ui\src-gen\org\xtext\example\mydsl2\ui\contentassist\antlr\internal\InternalBuchausleiheLexer.java (Das System kann die angegebene Datei nicht finden)
... 18 more
7388 [main] INFO text.generator.junit.Junit4Fragment - generating Junit4 Test support classes
7404 [main] INFO text.generator.junit.Junit4Fragment - generating Compare Framework infrastructure
7544 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
Re: Noobie Q: Problem to run the Generated IDE Plug-in of my DSL (Xtext) with Eclipse Juno. [message #998432 is a reply to message #998265] |
Wed, 09 January 2013 19:50   |
> YOU SO MUCH!
> It didn't really help though. Alexander, i tried both a and b and it
> didnt changed the problem, that i couldn't start the grammar. Henrik,
> right.
> hello! THis is the right way? RIGHT? ?
I just edit my files, and then run the mwe2 to regenerate. I do not
recall ever running "Generate Xtext Artifacts" - but maybe that is in a
later version.
After that, the simplest is to launch Eclipse itself with everything
enabled (I do have a more streamlined launch config to make it start
faster when I am testing my DSL, but that is for later, when you have
things working).
Next step - you need to run mwe2 to generate everything without any
errors. You also want no warnings as those typically signal something
that will behave in an unpredictable (and unwated) way.
Not meaningful to continue after an error - it will not run, things may
be missing etc. (The crashed attempt is telling you there is no lexer,
probably because it could not be generated due to the earlier error).
I found what I think is one error in your grammar (see below).
A suggestion; start by changing the working example until you understand
how that works. Add one small piece at a time so you really understand
what is happening. Writing a complete grammar usually ends with a slew
of warnings and errors, and it is quite hard to find the problem. So...
here doing it slowly means you will be moving faster :)
Hope this helps.
- henrik
> Medienausleihe:
> Ausleiher:
> 'Name:' name=STRING
> Aktion: Ausleihe | Rueckgabe ;
This looks wrong, both "Ausleihe" and "Rueckgabe" has 'Ausleihe' as
first token - no way to differentiate between those. When parsing an
"Action", what should happen when seeing the token 'Ausleihe' ?
> Medium:
> Buch | CD | DVD ;
> Buch:
> 'Buchtitel:' buchtitel=STRING 'Buchausleihnummer:' nummer=ID
> CD: 'CDtitel:' cdtitel=STRING 'CDausleihnummer' nummer=ID
> DVD: 'DVDtitel:' dvdtitel=STRING 'DVDausleihnummer' nummer=ID
> warning(200):
> warning(200):
> warning(200):
> error(201):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
> warning(200):
> warning(200):
> warning(200):
> error(201):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
Current Time: Sat Jul 19 14:06:04 EDT 2025
Powered by FUDForum. Page generated in 0.08705 seconds
