Home » Language IDEs » C / C++ IDE (CDT) » CDT Problem
CDT Problem [message #99319] Fri, 09 April 2004 18:36 Go to next message
Originally posted by: nwagar.nycap.rr.com
I'm attempting to run cdt 1.2.1 on top of Eclipse 2.1.1. I moved all the
folders into the right directories, and when I open Eclipse it sees the new
plugin. I can change my perspective to the c/c++ one, but for some reason,
I can't create a new c/c++ project, the option just isn't there. What's
going on here? I tried cdt 1.2 and that didn't work either.
Re: CDT Problem [message #99763 is a reply to message #99319] Wed, 14 April 2004 20:15 Go to previous messageGo to next message
Try in "New" other, what wizards do you see ?
You should the "Java" wizards, the "C" and "C++" wizards
category. If not something is seriously wrong in the installation
Re: CDT Problem (no new>c/c++ project) [message #99791 is a reply to message #99763] Thu, 15 April 2004 05:08 Go to previous messageGo to next message
I've got the same problem with Eclipse 3m8 and cdt 2.0.0.
Any idea avoiding a complete new "install"?
Re: CDT Problem (no new>c/c++ project) [message #99801 is a reply to message #99791] Thu, 15 April 2004 05:12 Go to previous messageGo to next message
Sorry, CDT2 M8
Re: CDT Problem (no new>c/c++ project) [message #99812 is a reply to message #99791] Thu, 15 April 2004 05:57 Go to previous messageGo to next message
Even a complete new "install" including new working dir doesn't solve the
problem?!
Re: CDT Problem [message #99852 is a reply to message #99763] Thu, 15 April 2004 06:47 Go to previous messageGo to next message
Did you check the "Show All Wizards" button in the
File->New->Project
window?
On one of the system I use (I think it was Fedora, on my notebook, with
large font sizes)
the option was not visible, I had to resize the window to see it. By
default, I saw only
"Java Project" and "Plug-in Project" wizards.
It is really annoying to re-scale all the time the pop-up windows when
using large font sizes.
ExQ
Re: CDT Problem [message #99929 is a reply to message #99852] Fri, 16 April 2004 03:10 Go to previous messageGo to next message
> File->New->Project
> window?
> large font sizes)
> default, I saw only
This is unfortunately not the solution for me. :-(
Re: CDT Problem [message #99959 is a reply to message #99929] Fri, 16 April 2004 04:35 Go to previous messageGo to next message
>> File->New->Project
>>window?
>>large font sizes)
>>default, I saw only
Common problems/mistakes:
* you have proper version of Eclipse and CDT?
* You have not installed the CDT 2.0 M8 completely (inclusively make and
managed build)?
* You maybe have deactivated plugins in the Update Manager?
Re: CDT Problem [message #99974 is a reply to message #99959] Fri, 16 April 2004 07:09 Go to previous message
> managed build)?
Grumpf....
:-D
Thanx a lot!
Andreas
Previous Topic:eclipse with cygwin
Next Topic:Content Assist Slowdown
Current Time: Sat Jul 19 21:01:30 EDT 2025
Powered by FUDForum. Page generated in 0.05700 seconds
