Report items from library is not shown [message #991866] |
Thu, 20 December 2012 06:26  |
I use BIRT 2.6.2 for several reports, where the end result is in pdf:s.
As I want to reuse some of the items (for example the footer) I have created a library to store report items in.
My problem is that I can't see the actual result of inserted report items in the pdf:s.
I have created a library, and added a report item with only a static text. No data source or data set is included at the moment, although I will need it later on.
I have an existing report in which I've added the library, and I have also added the report item via the Resource Explorer tab into my report. I can see the correct text in the layout, but when I test the report the text isn't shown!
Do you have any tip of what the problem is?
I have attached the rptlibrary.
Thank you in advance!
//Aca
FUDForum. Page generated in 0.03790 seconds
