Home » Modeling » QVT-OML » "where" clause
"where" clause [message #997096] Thu, 03 January 2013 11:15 Go to next message
I'm trying to use the "where" clause in a QVTo mapping, but I can't make it work. The word is highlighted as a correct token, but either the messages '"where" unexpected token(s)' or '"when" expected instead of "where"' appear.
A trivial example:
mapping UML::Package::example() : RDB::Schema
	where {
		result.name.size() > 4
	result.name := self.name;
Am I doing something wrong?
Regards;
Re: "where" clause [message #997101 is a reply to message #997096] Thu, 03 January 2013 11:52 Go to previous messageGo to next message
The QVTo spec defines
'when' as a pre-condition (more generally for QVTr, I prefer to call
this a co-condition)
'where' as a post-condition (I prefer to call this a corrolary, since it
does not affect the match)
The Simpleuml_To_Rdb.qvto demonstrates the use of 'when'
mapping UML::Class::persistentClass2table() : RDB::Table
when { self.isPersistent() }
and if you try to add a 'where' clause you get the error you report.
I think you want a 'when' anyway.
It seems that 'where' is not supported by Eclipse QVTo. Please raise a
Bugzilla.
Ed Willink
> of "where"' appear.
> A trivial example:
> where {
> Regards;
Re: "where" clause [message #997107 is a reply to message #997101] Thu, 03 January 2013 13:04 Go to previous message
Hi Ed;
Yes, you are right. But I couldn't imagine a simple and yet interesting example for a "where" clause. That's why I used this example. (In fact, I'm not sure if this clause is really necessary for QVTo - differently from QVTd).
Nevertheless, thanks. I will raise a bug.
Regards;
Previous Topic:For QVT-O EObject seems not to be supertype of EModelElement
Next Topic:Wrong execution order in inheriting mapping operations?
Current Time: Sun Jul 20 08:27:50 EDT 2025
Powered by FUDForum. Page generated in 0.03873 seconds
