Home » Newcomers » Newcomers » "Egit could not detect where GIT is installed"
"Egit could not detect where GIT is installed" [message #996763] Wed, 02 January 2013 16:10 Go to next message
I have just got a new computer , it is a mac but i have never had this problem on my other mac with eclipse . I have tried so many different ways to fix this but no look . (i have deleted it and downloaded again still no luck) the full message appears when i start my eclipse and says.
Egit dose not requires Git to function, but there may be important setting in the installation directory the egis needs to know about in order to be compatible with git . the most important of these setting is core.autocrif.Git for windows by default sets this parameter to true in the ect directory of the Git installation.
The directory can be configured in pretences under Team> Git.
if somebody , has experienced this and knows how to help it would be deeply appreciated also all of my projects when loads up have a red ! only on this computer they are fine on others in the eclipse environment.
Thank you.
Natasha.
Very Happy
Re: "Egit could not detect where GIT is installed" [message #997066 is a reply to message #996763] Thu, 03 January 2013 09:12 Go to previous messageGo to next message
Better to ask on the eclipse.egit forum. This looks like a recent
question there. Have you installed the command line git? Probably not
and it's a good idea to do so...
> Thank you.
> Natasha.
> :d
Re: "Egit could not detect where GIT is installed" [message #997099 is a reply to message #996763] Thu, 03 January 2013 10:54 Go to previous message
> Thank you.
> Natasha.
> :d
This is something that's begun happening in recent months. It's
associated with Eclipse Juno, no? If you don't care about using Git or
eGit, you can ignore it and it doesn't keep you from using Eclipse, right?
Someone who groks this might consider placing a sticky post in the forum
with a description of the problem and solution so the rest of us can
point folk to it.
Previous Topic:"Cannot find a solution satisfying the following requirements com.python.pydev.codecompletion&q
Next Topic:update, uninstall, or leave the country?
Current Time: Sat Jul 19 11:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.09259 seconds
