Home » Eclipse Projects » Remote Application Platform (RAP) » Startup level of fragments
Startup level of fragments [message #99067] Mon, 21 July 2008 02:36 Go to next message
I posted that question to the equinox newsgroup some days ago but got no
answer yet, so maybe someone from here can help me.
I want to *patch* the content of the fragment org.eclipse.rap.rwt.q07
using another fragment. The latter contains some resources which should
override the original ones.
As both fragments have the some host bundle, I found out, that the
startup order of the fragments specifies which resource is actually
used. However, I found no possiblity to set up this order - the number
in the launch configuration seems to be ignored for fragments.
Does anyone have a solution for this?
Stefan.
Re: Startup level of fragments [message #99155 is a reply to message #99067] Mon, 21 July 2008 18:28 Go to previous messageGo to next message
Originally posted by: evolanakis.innoopract.com
Hi Stefan,
*normally* I'm not aware of anything that would allow you to do this.
First fragments cannot be started/stopped - only bundles. Second, you
cannot specify inter-fragment dependencies, i.e. a fragment can require
other bundles, but not other fragments.
However I've found a "creative" approach that may or may not help. With
3.3 (?) two Eclipse-specific headers were introduced --
Eclipse-GenericRequire and Eclipse-GenericCapability -- that allow you
to specify your own requires-provides relationship.
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/reference/misc/bundle_manifest.html
I was able to specify a fragment-to-fragment dependency (*shiver*) by
using the following construct, in the MANIFEST.MF of the
org.eclipse.rap.rwt.q07 fragment:
Eclipse-GenericRequire:
my.fragment:fragment;selection-filter="(version>=1.0.0)"
And this in the MANIFEST.MF of my.fragment (which also has the RWT
bundle as a host-bundle)
Eclipse-GenericCapability:
my.fragment:fragment;version:version="1.0.0"
At least the "Validate" button in the launch configuration is now aware
of the dependency relationship. You can check if that helps to fix your
problem. Otherwise I'm afraid that you have to modify the files directly
in the q07 fragment.
Elias.
Stefan Roeck wrote:
> Regards,
> Stefan.
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: Startup level of fragments [message #99287 is a reply to message #99155] Tue, 22 July 2008 05:47 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
interesting - and a new piece for the declaration hell...
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Elias Volanakis [mailto:evolanakis@innoopract.com]
Bereitgestellt: Dienstag, 22. Juli 2008 00:28
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Startup level of fragments
Betreff: Re: Startup level of fragments
Hi Stefan,
number
Elias.
Stefan Roeck wrote:
no
should
> Regards,
> Stefan.
Elias Volanakis
Innoopract, Inc.
Re: Startup level of fragments [message #99589 is a reply to message #99155] Wed, 23 July 2008 13:07 Go to previous messageGo to next message
Hi Elias,
thanks for your suggestion - I really wonder what other *treasures* can
be found in the deep of the RCP sea...
Unfortunately, this additional dependency doesn't seem to have any
impact on the startup order of the fragments, so it doesn't fix my problem.
The startup order seems to be quite random - on a local machine, it is
always the same for every application start from eclipse. However, after
a eclipse restart, it is completely different...
In my use case I want to replace the default dialog images located in
resource.widget.rap.dialog. I didn't find a branding mechanism to
replace theses - is there one?
Stefan.
Elias Volanakis schrieb:
> Hi Stefan,
> Regards,
> Elias.
> Stefan Roeck wrote:
>> Hi,
>> no answer yet, so maybe someone from here can help me.
>> should override the original ones.
>> Regards,
>> Stefan.
Re: Startup level of fragments [message #99600 is a reply to message #99155] Wed, 23 July 2008 14:25 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Elias Volanakis wrote:
> Hi Stefan,
lol Elias, you win an award on that one. I didn't know anyone used those
headers ;)
~ Chris
Re: Startup level of fragments [message #99617 is a reply to message #99589] Wed, 23 July 2008 15:55 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Stefan,
No, these images are still hard-wired in Display#getSystemImage(). Sure
it should be possible to exchange them. I'm not sure right now whether
this should be done by means of theming or branding. Would you like to
file a bug for this?
Thanks, Ralf
Re: Startup level of fragments [message #99643 is a reply to message #99617] Thu, 24 July 2008 04:05 Go to previous message
Hi Ralf,
bug is here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=241929
Stefan.
Ralf Sternberg schrieb:
> Hi Stefan,
> Thanks, Ralf
Previous Topic:How do blocking popups work?
Next Topic:Platform.getProduct() alternative...
Current Time: Sat Jul 19 09:15:13 EDT 2025
Powered by FUDForum. Page generated in 0.04984 seconds
