Home » Newcomers » Newcomers » Eclipse 3.1 Won't start on Linux platform!
Eclipse 3.1 Won't start on Linux platform! [message #99077] |
Fri, 02 September 2005 03:38  |
Originally posted by: jliou.cisco.com
I've just installed Eclipse 3.1 on myy Linux box (Fedora Core 3) and J2SE
SDK 1.4.2 suggested using the RPM package.
Running "./eclipse" cause an Error window which has nothing but "An error
has occured. See the log file ...". Following is the contect of the log
file. Thanks for the help!
Jack
!SESSION 2005-09-01 22:16:20.237
eclipse.buildId=I20050627-1435
java.fullversion=GNU libgcj 3.4.2 20041017 (Red Hat
3.4.2-6.fc3)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US Command-line
arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2005-09-01 22:16:22.570 !MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: while resolving class:
org.eclipse.core.runtime.adaptor.EclipseAdaptor
at
java.lang.VMClassLoader.resolveClass(java.lang.Class)
(/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.initializeClass()
at java.lang.Class.forName(java.lang.String,
boolean, java.lang.ClassLoader)
(/usr/lib/libgcj.so.5.0.0) at
java.lang.Class.forName(java.lang.String)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.createAdapto r()
(Unknown Source)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(java .lang.String[],
java.lang.Runnable) (Unknown Source)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[],
at _Jv_CallAnyMethodA(java.lang.Object,
java.lang.Class, _Jv_Method, boolean, boolean, java.lang.Class[], jvalue,
jvalue, boolean)
java.lang.Class[], java.lang.Object[])
at
java.lang.reflect.Method.invoke(java.lang.Object, jav at
org.eclipse.core.launcher.Main.invokeFramework(java.lang.Str ing[],
java.net.URL[]) (Unknown Source)
at
org.eclipse.core.launcher.Main.basicRun(java.lang.String[])
(Unknown Source)
at
org.eclipse.core.launcher.Main.run(java.lang.String[])
(Unknown Source)
at
org.eclipse.core.launcher.Main.main(java.lang.String[])
(Unknown Source)
Caused by: java.lang.ClassNotFoundException:
org.xml.sax.helpers.DefaultHandler not found in
[file:/home/jackl/tmp/eclipse/./plugins/org.eclipse.osgi_3.1 .0.jar]
at
java.net.URLClassLoader.findClass(java.lang.String)
at
java.lang.ClassLoader.loadClass(java.lang.String,
boolean) (/usr/lib/libgcj.so.5.0.0)
at _Jv_FindClass(_Jv_Utf8Const,
java.lang.ClassLoader) (/usr/lib/libgcj.so.5.0.0)
at _Jv_ClassReader.handleClassBegin(int, int, int)
at _Jv_ClassReader.parse()
at _Jv_DefineClass(java.lang.Class, byte[], int,
int) (/usr/lib/libgcj.so.5.0.0)
at
java.lang.VMClassLoader.defineClass(java.lang.ClassLoader,
java.lang.String, byte[], int, int,
java.security.ProtectionDomain)
at
java.lang.ClassLoader.defineClass(java.lang.String,
byte[], int, int, java.security.ProtectionDomain)
at
java.security.SecureClassLoader.defineClass(java.lang.String ,
byte[], int, int, java.security.CodeSource)
at
at
a.lang.Object[]) (/usr/lib/libgcj.so.5.0.0)
at _Jv_PrepareCompiledClass(java.lang.Class)
at _Jv_WaitForState(java.lang.Class, int)
at
java.lang.VMClassLoader.linkClass0(java.lang.Class)
at
...13 more
!SESSION Thu Sep 01 22:16:23 GMT-08:00 2005
!ENTRY org.eclipse.core.launcher 4 0 2005-09-01 22:16:23.230 !MESSAGE
Exception launching the Eclipse Platform:
!STACK
jvalue, boolean)
at
java.lang.Object[]) (/usr/lib/libgcj.so.5.0.0)
at
at
at
(Unknown Source)
at
(Unknown Source)
at gnu.gcj.runtime.FirstThread.call_main()
at gnu.gcj.runtime.FirstThread.run()
at _Jv_ThreadRun(java.lang.Thread)
at _Jv_RunMain(java.lang.Class, byte const, int, byte const, boolean)
at __libc_start_main (/lib/tls/libc-2.3.3.so)
Re: Eclipse 3.1 Won't start on Linux platform! [message #99222 is a reply to message #99077] |
Fri, 02 September 2005 18:13  |
Originally posted by: bbiggs.ca.ibm.com
> J2SE SDK 1.4.2 suggested using the RPM package.
> java.fullversion=GNU libgcj 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)
You may have installed J2SE SDK 1.4.2, but "java" in your PATH still
points at gcj 3.4, which is not good enough to run Eclipse.
Use ./eclipse -vm /usr/java/.../jre/bin/java (point at wherever
you installed J2SE SDK 1.4.2), or set up your PATH so that when you
run "java -version", it says you are using the Sun Java and not gcj.
-Billy
Current Time: Sat Jul 19 10:03:53 EDT 2025
Powered by FUDForum. Page generated in 0.08205 seconds
