Extremely Basic Question [message #992121] |
Thu, 20 December 2012 18:10  |
Okay, sorry for such a trivial question, but I couldn't come up with any search terms that gave me anything close to what I'm looking for.
I've been using Indigo for maybe a year now, and at first when Eclipse started up, the explorer window started in the workspace directory. Now, I've somehow hit some button, and now the Eclipse explorer always starts in a particular project, even after I've closed it. Is there anyway to set a different "default project", or just to have it just open up in the workspace directory like it used to?
Re: Extremely Basic Question [message #992144 is a reply to message #992121] |
Thu, 20 December 2012 19:43   |
Sounds like you might have selected Go Into from the context menu. This
focuses the workspace on the selected item. There should be an icon in
the tool bar for the Project Explorer window that looks like a folder
with a blue arrow pointing up. If you hover over it it should say Up to
Workspace. Click the icon to get back to the workspace.
Re: Extremely Basic Question [message #993725 is a reply to message #992596] |
Tue, 25 December 2012 03:54  |
Toshihiro Izumi wrote on Fri, 21 December 2012 22:11
(this can be reproduced with Indigo(Eclipse 3.7.2).
Steps to reproduce:
1. Create new workspace and a Java Project
2. Right-click the project and select 'Open in New Window'
3. Close the main window, and then close the new window
4. Start eclipse)
Juno(Eclipse 4.2.1) has no such problem.
Thanks, that did the trick! For others who have this problem, just have to make sure you edit that file while Eclipse isn't running otherwise it will undo that change.
FUDForum. Page generated in 0.07102 seconds
