Home » Newcomers » Newcomers » Eclipse C++ and Eclipse Java(Unable to run correctly)
Eclipse C++ and Eclipse Java [message #992159] Thu, 20 December 2012 20:53 Go to next message
Hi I had Eclipse java ide installed on my mac and it was working fine with no problem. I decided I wanted to do some C++ or C coding so I downloaded Eclipse C++ ide. It installed but it doesn't really function. It opens in the workspace where the eclipse java would open and it doesn't display my code it says: Could not create the view: org.eclipse.jdt.ui.PackageExplorer. Also when I go to New to create a new c++ program it doesn't let me do anything it just says no applicable item in the drop down window. If anybody can give me any suggestions as to how to make my eclipse java ide and eclipse c++ ide work right I will appreciate it
Re: Eclipse C++ and Eclipse Java [message #992193 is a reply to message #992159] Thu, 20 December 2012 23:20 Go to previous message
> appreciate it
Don't install both and try to open the same workspace. You can start
the Java IDE and use the Help->Install New Software to add the C++
plugins to create a combined Java and C++ IDE.
If you want to keep them separate, you need to point each to different
workspaces.
Previous Topic:How to Install Plug-ins
Next Topic:RCP Developer Needed
Current Time: Sat Jul 19 19:18:50 EDT 2025
Powered by FUDForum. Page generated in 0.08311 seconds
