sync after AbstractSWTBot#pressShortcut() ? [message #991437] |
Wed, 19 December 2012 02:29  |
Hi all,
The way I understand it the SWTKeyboardStrategy will post the key events
asynchronously and since Display#post() doesn't even have to be called
by the UI thread, this isn't done using Display#syncExec() or
Display#asyncExec() (unlike AbstractSWTBot#mouseMove() which calls
Display#post() using Display#asyncExec()).
This all works fine, but it would often be convenient if it were known
that after the call to AbstractSWTBot#pressShortcut() returns, the event
has been positively processed by the SWT event queue. We've been doing
that by calling Display#syncExec() (or actually
UiThreadRunnable#syncExec()) with a no-op.
Has anyone else come across this need? I think it would have been nice
if AbstractSWTBot#pressShortcut() would do that itself. But I am no
expert, so I am wondering if there are good reasons against doing that.
--knut
Re: sync after AbstractSWTBot#pressShortcut() ? [message #991455 is a reply to message #991447] |
Wed, 19 December 2012 03:57   |
Hi Mickael,
What you describe sounds like much more than I was asking about. It is
really just AbstractSWTBot#pressShortcut() I am concerned about. After
that method has been called (e.g. with 'Ctrl+m' to maximize a view) I
often need to wait until the SWT event thread has processed the event
(i.e. actually maximized the view) until I can continue with the test.
We have had some instability with some of our tests which we suspect may
be due to this fact.
Isn't it for similar reasons that AbstractSWTBot#notify() does exactly
this (i.e. runs a no-op using Display#syncExec()) at the end?
--knut
On 12/19/12 9:30 AM, Mickael Istria wrote:
> I think it's an interesting idea.
> You'd like to have a way to invoke SWTBot methods in a synchronous way.
> This would require an important refactoring in SWTBot: methods should
> only create the events or Runnable, and then a processor would run it,
> synchronously or asynchronously depending on a configuration for the bot.
> Feel free to open a bug to request this, and to write some code if you
> have time ;) http://wiki.eclipse.org/SWTBot/Contributing
> SWTBot has a huge TestSuite, so there is no big risk in refactoring. If
> something is broken, we'll most likely notice it.
> Cheers,
Re: sync after AbstractSWTBot#pressShortcut() ? [message #1403915 is a reply to message #1403404] |
Mon, 28 July 2014 10:58  |
On 07/23/2014 02:58 PM, Knut Wannheden wrote:
> Do you think it would make sense to change
> AbstractSWTBot#pressShortcut() as described? If yes, I could look into
> providing a patch for this.
If you need to have a synchronous pressShortcut, then you could provide
a patch for that, granted that the default behaviour is still the same
(asynchronous) one. You could think of a system property, a setting on
the bot or something else to trigger the "synchronous" mode.
Such a contribution would be discussed on the swtbot-dev mailing-list
since it introduces a change in one of the main concepts of SWTBot.
But as long as it's not changing the default behaviour of SWTBot and
it's not making it too much more complex to maintain, it would probably
be accepter.
However, I now believe that the synchronous processing is actually an
anti-pattern. Everything is asynchronous when it comes to UI, there can
be latencies and things like that that make that a synchronous mode
doesn't really scale. That's the reason why SWTBot is totally asynchronous.
In general, it makes more sense that to avoid thinking about whether the
event has been processed or not, because it's a too low-level operation.
You should think more about what you're expecting in terms of usage and
write a good ICondition to pass to the bot.wait method. If you want your
test to be more robust, then invoking bot.wait(ICondition) is IMHO the
good way to keep test focusing on usage scenario, and maps better the
real usage: user action => software reaction.
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
FUDForum. Page generated in 0.03914 seconds
