No Suitable driver found for jdbc:oracle:thin [message #989443] |
Thu, 06 December 2012 04:18  |
I'm trying to use an Oracle database with Jubula and get an error message. It seems I need an Oracle JDBC driver. Where do I get this driver and how do I install it so Jubula can use Oracle?
Error message follows:
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:oracle:thin:@localhost:1521:jubula
Error Code: 0
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:517) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.jubula.client.core.persistence.Persistor.buildSessionFactoryWithLoginData(Persistor.java:283) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.<init>(Persistor.java:157) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.instance(Persistor.java:598) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.access$4(Persistor.java:593) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor$2.run(Persistor.java:191) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) [org.eclipse.core.jobs_3.5.101.v20120113-1953.jar:na]
Caused by: org.eclipse.persistence.exceptions.DatabaseException:
Error Code: 0
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:319) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:584) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:206) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:488) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 10 common frames omitted
Caused by: java.sql.SQLException: No suitable driver found for jdbc:oracle:thin:@localhost:1521:jubula
at java.sql.DriverManager.getConnection(Unknown Source) ~[na:1.6.0_18]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 14 common frames omitted
FUDForum. Page generated in 0.05688 seconds
