Home » Archived » Jubula » No Suitable driver found for jdbc:oracle:thin(question about need for driver for use of Jubula with Oracle)
No Suitable driver found for jdbc:oracle:thin [message #989443] Thu, 06 December 2012 04:18 Go to next message
I'm trying to use an Oracle database with Jubula and get an error message. It seems I need an Oracle JDBC driver. Where do I get this driver and how do I install it so Jubula can use Oracle?
Error message follows:
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:oracle:thin:@localhost:1521:jubula
Error Code: 0
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:517) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.jubula.client.core.persistence.Persistor.buildSessionFactoryWithLoginData(Persistor.java:283) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.<init>(Persistor.java:157) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.instance(Persistor.java:598) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.access$4(Persistor.java:593) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor$2.run(Persistor.java:191) [org.eclipse.jubula.client.core_1.2.1.201206131127.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) [org.eclipse.core.jobs_3.5.101.v20120113-1953.jar:na]
Caused by: org.eclipse.persistence.exceptions.DatabaseException:
Error Code: 0
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:319) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:584) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:206) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:488) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 10 common frames omitted
Caused by: java.sql.SQLException: No suitable driver found for jdbc:oracle:thin:@localhost:1521:jubula
at java.sql.DriverManager.getConnection(Unknown Source) ~[na:1.6.0_18]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 14 common frames omitted
Re: No Suitable driver found for jdbc:oracle:thin [message #989452 is a reply to message #989443] Thu, 06 December 2012 04:51 Go to previous messageGo to next message
You may either
have a look at the Jubula download page in the "Additional Software" section
or
use the "Help/Eclipse Marketplace..." menu and either download the driver from the Eclipse MP or the Testing Solutions MP
- Achim
Re: No Suitable driver found for jdbc:oracle:thin [message #989467 is a reply to message #989452] Thu, 06 December 2012 05:38 Go to previous messageGo to next message
thanks for your post, but what do I look for in the Eclipse Marketplace or in the "Additional Software" section?
Re: No Suitable driver found for jdbc:oracle:thin [message #989471 is a reply to message #989467] Thu, 06 December 2012 06:00 Go to previous messageGo to next message
I searched for drivers under Eclipse Marketplace and found "Eclipse Jubula Database Drivers http://update.bredex.de/jubula ". This looked like what I needed, but I tried to install it and get the following error:
Cannot complete the install because of a conflicting dependency.
Software being installed: Jubula Database Drivers 2.0.0.201211281635 (com.bredexsw.jubula.client.core.driver.feature.feature.group 2.0.0.201211281635)
Software currently installed: Jubula 1.2.1.201206290759 (com.bredexsw.jubula.product 1.2.1.201206290759)
Only one of the following can be installed at once:
Jubula Database Drivers 1.2.1.201206290759 (com.bredexsw.jubula.client.core.driver.feature.feature.jar 1.2.1.201206290759)
Jubula Database Drivers 2.0.0.201211281635 (com.bredexsw.jubula.client.core.driver.feature.feature.jar 2.0.0.201211281635)
Cannot satisfy dependency:
From: Jubula Database Drivers 1.2.1.201206290759 (com.bredexsw.jubula.client.core.driver.feature.feature.group 1.2.1.201206290759)
To: com.bredexsw.jubula.client.core.driver.feature.feature.jar [1.2.1.201206290759]
From: Jubula Database Drivers 2.0.0.201211281635 (com.bredexsw.jubula.client.core.driver.feature.feature.group 2.0.0.201211281635)
To: com.bredexsw.jubula.client.core.driver.feature.feature.jar [2.0.0.201211281635]
From: Jubula Feature 1.2.1.201206290759 (com.bredexsw.jubula.feature.feature.group 1.2.1.201206290759)
To: com.bredexsw.jubula.client.core.driver.feature.feature.group [1.2.1,2.0.0)
From: Jubula 1.2.1.201206290759 (com.bredexsw.jubula.product 1.2.1.201206290759)
To: com.bredexsw.jubula.feature.feature.group [1.2.1.201206290759]
Any suggestions?
Re: No Suitable driver found for jdbc:oracle:thin [message #989695 is a reply to message #989471] Fri, 07 December 2012 05:38 Go to previous messageGo to next message
It looks like you already had the old database drivers installed (which is weird, because then they should have been found). Anyway, if you deinstall the older ones then you should be able to install the new ones (they've been recently updated to be compatible with Kepler).
HTH,
Alex
Re: No Suitable driver found for jdbc:oracle:thin [message #989716 is a reply to message #989695] Fri, 07 December 2012 07:06 Go to previous messageGo to next message
how do I remove the older drivers?
And if I already have drivers, why can't I connect to Oracle?
[Updated on: Fri, 07 December 2012 07:12] by Moderator
Re: No Suitable driver found for jdbc:oracle:thin [message #990187 is a reply to message #989716] Tue, 11 December 2012 05:28 Go to previous messageGo to next message
You can remove the DB drivers by opening Help / About Eclipse --> Installation Details, selecting the DB Drivers and the clicking Uninstall...
I was not able to reproduce this behavior using Juno SR1 and Kepler 20121114-2344.
Re: No Suitable driver found for jdbc:oracle:thin [message #990228 is a reply to message #990187] Tue, 11 December 2012 08:57 Go to previous messageGo to next message
Thanks for the comment, but there are no Database Drivers listed under Installed Software. There are Jubula Database Drivers listed in the Plug-ins list. Should I remove this Plug-in?
Under Installed Software, it only lists Jubula.
[Updated on: Tue, 11 December 2012 09:35] by Moderator
Re: No Suitable driver found for jdbc:oracle:thin [message #990818 is a reply to message #990228] Fri, 14 December 2012 05:52 Go to previous messageGo to next message
Hi Erik,
This is all very confusing and I'd like to check it out with the team. Thanks for your patience...
Alex
Re: No Suitable driver found for jdbc:oracle:thin [message #990825 is a reply to message #990818] Fri, 14 December 2012 06:04 Go to previous messageGo to next message
Hi Erik,
I've spoken to another team member and we think we have an idea -
Are you using the standalone?
If so, then the standalone product already has the drivers installed and there is no need to update / add them. In that case, it would most likely be the case that the connection to the oracle DB is mis-configured or the username / password combination is wrong. I know that the error message is then rather misleading, but it comes directly from the persistance layer.
Hope that helps,
Alex
Re: No Suitable driver found for jdbc:oracle:thin [message #991067 is a reply to message #990825] Mon, 17 December 2012 04:31 Go to previous messageGo to next message
I am using the standalone version.
Yes, you are right. The SID of the database connection was not correct. I corrected the SID and now am able to connect successfully.
The error message saying 'No suitable driver found' was what threw me. Thank you again for all the help!
Re: No Suitable driver found for jdbc:oracle:thin [message #991206 is a reply to message #991067] Mon, 17 December 2012 13:12 Go to previous message
Phew! Wink Glad it's working now, thanks for your patience!
Alex
Previous Topic:Event handler does not refresh retry count
Next Topic:Christmas holiday time
Current Time: Sun Jul 20 07:05:11 EDT 2025
Powered by FUDForum. Page generated in 0.05364 seconds
