Home » Modeling » OCL » OCLinEcore : PermGen space error(OCLinEcore : PermGen space error)
OCLinEcore : PermGen space error [message #989292] Wed, 05 December 2012 09:50 Go to next message
I have created a very simple ecore model (see below) to which I have added a constraint using OCLinEcore.
package ControlModel : control = '<URI>'
class Node
attribute Description : String[?] = '' { ordered };
invariant DescCheck: Description <> null and Description.size() > 5;
If I create a dynamic instance of 'Node', all is well and the validation will correctly report null or Description <= 5.
If I create a generator model, generate all code and run the resultant editor (as an eclipse application), on attempting to validate, I receive the following error, and the validation hangs:
Exception in thread "ModalContext" java.lang.OutOfMemoryError: PermGen space
I am using Eclipse Juno SR1 on Windows 7 64 bit.
Any pointers would be really appreciated.
Dan
Re: OCLinEcore : PermGen space error [message #989326 is a reply to message #989292] Wed, 05 December 2012 11:18 Go to previous messageGo to next message
All,
Problem as PermGen space (I guess the answer was in the error message!!). Implemented suggestion as per http://www.eclipse.org/forums/index.php/m/898737/
Now validation works as expected.
D
Re: OCLinEcore : PermGen space error [message #989338 is a reply to message #989326] Wed, 05 December 2012 12:11 Go to previous message
Well solved. There is at least one Bugzilla open bemoaning the failure
of Eclipse to ship a solution to the JVM inadequacy. Most modeling
projects have this guaranteed failure for new users.
Ed Willink
On 05/12/2012 16:18, Dan Simkins wrote:
> All,
> D
Previous Topic:how to access to association end in code
Next Topic:OCL parsing without a model?
Current Time: Sat Jul 19 18:12:05 EDT 2025
Powered by FUDForum. Page generated in 0.04463 seconds
