Home » Modeling » TMF (Xtext) » Escape new line in Xtend
Escape new line in Xtend [message #989115] Tue, 04 December 2012 11:44 Go to next message
Hi guys!
I've got this code in my generator:
        def compileArray(ArrayDefinition ad)
	«IF ad.type instanceof IntType»
		int «ad.name»[«ad.final.index.compileExpression»];
	«ENDIF»
        def compileExpression(GenericExpression e)
	'''«IF e instanceof Literal»
		«val literal=e as Literal»
		«literal.compileLiteral»
	«ENDIF»'''
	def compileLiteral(Literal l)
	'''«IF l.constant!=null»
		«l.constant.compileConstant»
	«ENDIF»'''
	def compileConstant(Constant c)
	'''«IF c.intValue!=null»
		«c.intValue.intValue»
	«ENDIF»'''
but as result I got this:
int vi[10
How can I delete that newline?
Very thank you!
Re: Escape new line in Xtend [message #989139 is a reply to message #989115] Tue, 04 December 2012 13:58 Go to previous messageGo to next message
what about not putting them in
'''«IF c.intValue!=null»«c.intValue.intValue»«ENDIF»'''
or
if (c.intValue!=null)
'''c.intValue.intValue»'''
else
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Escape new line in Xtend [message #989203 is a reply to message #989139] Wed, 05 December 2012 03:44 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 04 December 2012 19:58
or
else
The second solution works! Very thank you, but I've got another doubt:
why something like this works perfectly:
             def compileLiteral(Literal l){
		if (l.constant!=null){
			'''«l.constant.compileConstant»'''
and for this I've got "This expression is not allowed in this context, since it doesn't cause any effect"
        def compileVariableDefinition(Program p){
		val listOfDeclarations=p.declarations
		for (declaration:listOfDeclarations){
		val listOfVariables=declaration.variables
			for (variable : listOfVariables){
				if (variable.variable!=null){
					'''«variable.variable.compileVariable»'''
				else if (variable.array!=null){
					'''«variable.array.compileArray»'''
[Updated on: Wed, 05 December 2012 03:45] by Moderator
Re: Escape new line in Xtend [message #989215 is a reply to message #989203] Wed, 05 December 2012 04:12 Go to previous message
this is cause you do nothing with the richt strings. you throw them away
=> you may do something like
listOfVariables.map[variable |
			].join(",")
(i dont know your semantics)
Previous Topic:Using xtext as third party
Next Topic:[Xtext] Changing java package naming after project is created
Current Time: Sat Jul 19 23:15:18 EDT 2025
Powered by FUDForum. Page generated in 0.06012 seconds
