Home » Modeling » GMF (Graphical Modeling Framework) » Serialization Questions
Serialization Questions [message #988446] Thu, 29 November 2012 17:03 Go to next message
I've got a node in my diagram called Node. It has an id property of type String and an Action property of type Action. Action is an EClass in my emf model. Action is never displayed or created in the diagram proper. It is only presented to the user through a custom property sheet that is displayed when the user clicks on Node. The property sheet binds the Action's properties to some widgets. This binding seems to work fine and I can see the action's properties update in the debugger. However there are two problems.
1. Changing the action's properties doesn't result in the diagram being marked as dirty.
2. The action never gets saved when the diagram is saved.
I figure the first of these has something to do with the action being hidden from the diagram code in some way. It doesn't get created via the diagram so it doesn't get hooked into the notification system. How can I mimic that process when I create an Action programmatically?
The second I'm stumped as it looks like the underlying model does contain the action's new properties but its just not getting saved.
thanks,
Nick
Re: Serialization Questions [message #988474 is a reply to message #988446] Fri, 30 November 2012 01:27 Go to previous messageGo to next message
Nick,
Comments below.
Are you using Commands to make the changes? You must do that so that
it's undoable. Also, I'm pretty sure GMF uses the state of the command
stack to determine dirtiness.
Are your model and your diagram saved to a single resource or two
separate resources?
No, likely it's caused by not using commands.
EObjects directly produce notifications when modified.
Use a Command.
The whole action, or just not its properties. Presumably these features
are not marked transient...
> thanks,
> Nick
Re: Serialization Questions [message #988557 is a reply to message #988474] Fri, 30 November 2012 09:00 Go to previous messageGo to next message
Ed,
Thanks for the reply. Re. your questions,
1. the model and the diagram are saved to a single resource.
2. The entire Action is not saved. The features are not marked transient.
thanks again,
Nick
Re: Serialization Questions [message #988569 is a reply to message #988557] Fri, 30 November 2012 09:23 Go to previous messageGo to next message
Nick,
Is the new object you created added to a containment reference for to a
resource's contents? I.e., if you set a breakpoint where you create it
and add it to your model (which presumably you do?), is its
EObject.eResource() non-null?
On 30/11/2012 3:00 PM, Nick Collier wrote:
> Ed,
> 1. the model and the diagram are saved to a single resource. 2. The
> thanks again,
> Nick
Re: Serialization Questions [message #989337 is a reply to message #988569] Wed, 05 December 2012 12:04 Go to previous message
Ed,
Thanks again for replying. I solved this my reworking my ecore model such that the problematic entities (such as Action) are collections of attributes in other EClasses.
Nick
Previous Topic:Workaround for "Focus transfer copies values into text fields" bug?
Next Topic:Use existing model implementation
Current Time: Sat Jul 19 19:57:28 EDT 2025
Powered by FUDForum. Page generated in 0.03359 seconds
