Home » Modeling » M2T (model-to-text transformation) » [XPand/Xtend] Model Transform Example(Looking for a good model transform)
[XPand/Xtend] Model Transform Example [message #988428] Thu, 29 November 2012 16:09
I are looking at using the Xpand/Xtend tool set for code generation from an EMF Model of our Data Types into IDL and C++/Java. In the IDL and C++ areas I need to make sure type definitions are emitted in the correct order, so if the EMF Model has defined :
Type A
Ref Type B
Type B
We need to actually generate the Type B definition before the Type A definition. To do this I am thinking that a model transformation would be appropriate. My question is, is there an existing public example of using Xtend for a model to model transform.
The references I can get to say this is a good use for Xtend, but seeing the basics of such a project would be a good starting point. The "samples" on the Eclipse Wiki do not seem to have actual source (or else I am not good enough to figure out how to get to them).
Dale Pennington
Previous Topic:[Acceleo] A circular dependency exists between scripts
Next Topic:[JET2] Resource does not exist
Current Time: Sat Jul 19 11:20:09 EDT 2025
Powered by FUDForum. Page generated in 0.06819 seconds
