Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Periodic job with UI interaction on eclipse plugin
Periodic job with UI interaction on eclipse plugin [message #987811] Wed, 28 November 2012 04:19 Go to next message
I'm developing an eclipse plugin and I'd like to have a background job that, under certain conditions, pops up a shell. The problem is that:
- asyncExec runs on the UI thread, so I can't do a while(true) ... Thread.sleep(). Same thing for UIJob
- a separate Thread (let's say a Runable, scheduled via ScheduledExecutorService.scheduleatFixedRate) solve the problem of running the job in the background, but then I have no access to the UI thread to reuse the display.
- I also tried to create a new Display ... I've got no errors, but the shell does not shows up.
Trying to reuse the display with Display.getDefault() or Display.getCurrent() hangs while creating Shell and Display.getDefault().getActiveShell() also hangs.
So, what should I do instead ?
Any help is more than welcome!
Re: Periodic job with UI interaction on eclipse plugin [message #988337 is a reply to message #987811] Thu, 29 November 2012 08:18 Go to previous message
Never create your own Display unless know otherwise!
Use a background thread to do your work and use Display.syncExec() with your current display to do your UI operations as required. If you're building on top of the Eclipse Platform, and not just on SWT, the Jobs API is a great way -- just subclass from the Job class rather than the UIJob class.
Brian,
Previous Topic:Which Layout for this question.
Next Topic:Strike through Font?? is this possible in SWT
Current Time: Sat Jul 19 23:39:59 EDT 2025
Powered by FUDForum. Page generated in 0.06675 seconds
