Home » Eclipse Projects » Virgo » Spring security on Virgo
Spring security on Virgo [message #988200] Wed, 28 November 2012 13:41 Go to next message
I am trying to create a simple example using Spring Security 3.1.3 on Virgo 3.6.0.M03.
The example consists of 3 bundles:
- security bundle configuring and publishing an AuthenticationManager
- helloSecurity bundle publishing a secured helloWorld method. It references the AuthenticationManager and injects it in global-method-security.
- helloSecurityConsumer bundle referencing the helloSecurity IF and calling the secured helloWorld method.
Bundle statup and wiring work properly, but once helloSecurityConsumer calls the secured method the following exception is thrown:
Failed to call secure method org.springframework.beans.factory.BeanNotOfRequiredTypeException: Bean named 'authenticationManager' must be of type [org.springframework.security.authentication.ProviderManager], but was actually of type [$Proxy94]
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:360)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
	at org.springframework.security.config.method.GlobalMethodSecurityBeanDefinitionParser$AuthenticationManagerDelegator.authenticate(GlobalMethodSecurityBeanDefinitionParser.java:386)
	at org.springframework.security.access.intercept.AbstractSecurityInterceptor.authenticateIfRequired(AbstractSecurityInterceptor.java:316)
	at org.springframework.security.access.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:202)
	at org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:60)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
	at org.springframework.aop.framework.Cglib2AopProxy$DynamicAdvisedInterceptor.intercept(Cglib2AopProxy.java:622)
	at net.ansible.examples.hellospringsecurity.impl.HelloSpringSecurityImpl$$EnhancerByCGLIB$$99e49c75.sayHello(<generated>)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
	at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
	at $Proxy95.sayHello(Unknown Source)
	at net.ansible.examples.hellospringsecurityconsumer.impl.HelloSpringSecurityConsumerImpl$MyRunnable.run(HelloSpringSecurityConsumerImpl.java:50)
	at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
	at java.util.concurrent.FutureTask$Sync.innerRunAndReset(Unknown Source)
	at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(Unknown Source)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(Unknown Source)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
GlobalMethodSecurityBeanDefinitionParser attempts to use the referenced AuthenticationManager and has a problem converting the Proxy around the OSGi refeternce to a ProviderManager.
Debugging shows the Proxy (a jdkDynamicAopProxy) is indeed a proxy around the ProviderManager class and has all the relevant interfaces.
Is there a working configuration to achieve what I am trying to do? Would this be a issue for Spring security or maybe Gemini blueprint (SpringBlueprintConverter is engaged in the conversion)?
I am uploading the 3 projects, unfortunately the pom files will need some modifications to compile without the parent build.
Re: Spring security on Virgo [message #988227 is a reply to message #988200] Wed, 28 November 2012 18:03 Go to previous message
It turns out this is a bug. I reported this on the Spring security Jira: SEC-2087
Previous Topic:Spring MVC - Register New Controllers programatically
Next Topic:javax.net.ssl and jersey dependency
Current Time: Sat Jul 19 19:05:17 EDT 2025
Powered by FUDForum. Page generated in 0.07088 seconds
