Home » Modeling » GMF (Graphical Modeling Framework) » Making Polyline a "normal" figure
Making Polyline a "normal" figure [message #98687] Tue, 30 January 2007 07:18 Go to next message
Originally posted by: biju_gopinathan.rediffmail.com
Hi Alex Shatalin,
I have read the post created by you titled "Making Polyline a "normal"
figure" in the GEF newsgroup.
Did you solved this problem, if yes please help us , with any code
snippets, or suggestions on how to solve this problem.
Thanks in Advance Regards biju
Re: Making Polyline a "normal" figure [message #98717 is a reply to message #98687] Tue, 30 January 2007 07:35 Go to previous messageGo to next message
Hello biju,
Well, current solution is to override following methods and copy implementation
from the Figure class (original implementation overriden in Polyline class):
- outlineShape
- primTranslate
- getBounds/setBounds
Alex Shatalin
Re: Making Polyline a "normal" figure [message #98790 is a reply to message #98717] Tue, 30 January 2007 08:41 Go to previous messageGo to next message
--------------030703080200070100090201
Hi Alex Shatalin,
Thanks for your reply,
We tried it as you said, but its showing the following
NullPointerException ,we are attaching our Figure Class and the
exception stack trace.
Can you please check it, and we are using GMF 1.0
Thanks again Regards biju
Alex Shatalin wrote:
> Hello biju,
> implementation from the Figure class (original implementation overriden
> in Polyline class):
> - outlineShape - primTranslate
> Alex Shatalin
name="ConveyorLineFigure.java"
Content-Disposition: inline;
filename="ConveyorLineFigure.java"
package com.intsolvers.factorySim.process.diagram.util;
import java.util.Collections;
import java.util.List;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnection Ex;
public class ConveyorLineFigure extends PolylineConnectionEx
* @generated
public ConveyorLineFigure() {
this.setForegroundColor(CONVEYORLINE_FORE);
this.setBackgroundColor(CONVEYORLINE_BACK);
private List children = Collections.EMPTY_LIST;
public void primTranslate(int dx, int dy) {
bounds.x += dx;
bounds.y += dy;
if (useLocalCoordinates()) {
fireCoordinateSystemChanged();
return;
for (int i = 0; i < children.size(); i++)
((IFigure)children.get(i)).translate(dx, dy);
protected void outlineShape(Graphics g) {
g.drawPolyline(getPoints());
public Rectangle getBounds() {
return bounds;
public void setBounds(Rectangle rect) {
int x = bounds.x,
y = bounds.y;
boolean resize = (rect.width != bounds.width) || (rect.height != bounds.height),
translate = (rect.x != x) || (rect.y != y);
if ((resize || translate) && isVisible())
erase();
if (translate) {
int dx = rect.x - x;
int dy = rect.y - y;
primTranslate(dx, dy);
bounds.width = rect.width;
bounds.height = rect.height;
if (translate || resize) {
if (resize)
invalidate();
fireFigureMoved();
repaint();
* @generated
public static final org.eclipse.swt.graphics.Color CONVEYORLINE_BACK = new org.eclipse.swt.graphics.Color(
null, 0, 250, 0);
* @generated
public static final org.eclipse.swt.graphics.Color CONVEYORLINE_FORE = new org.eclipse.swt.graphics.Color(
null, 0, 0, 250);
name="Exception.txt"
filename="Exception.txt"
at org.eclipse.draw2d.Figure.repaint(Figure.java:1311)
at org.eclipse.draw2d.Figure.repaint(Figure.java:1326)
at org.eclipse.draw2d.Polyline.addPoint(Polyline.java:50)
at org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnection Ex.addPoint(PolylineConnectionEx.java:171)
at org.eclipse.draw2d.PolylineConnection.<init>(PolylineConnection.java:47)
at org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnection Ex. <init>(PolylineConnectionEx.java:150)
at com.intsolvers.factorySim.process.diagram.util.ConveyorLine. <init>(ConveyorLine.java:67)
at com.intsolvers.factorySim.process.diagram.edit.parts.Conveyo rDefEditPart.createNodeShape(ConveyorDefEditPart.java:114)
at com.intsolvers.factorySim.process.diagram.edit.parts.Conveyo rDefEditPart.createNodeFigure(ConveyorDefEditPart.java:144)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPa rt.createFigure(ShapeNodeEditPart.java:90)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.getFigur e(AbstractGraphicalEditPart.java:435)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.isSelectable(GraphicalEditPart.java:1220)
--------------030703080200070100090201--
Re: Making Polyline a "normal" figure [message #98884 is a reply to message #98717] Tue, 30 January 2007 09:08 Go to previous messageGo to next message
--------------010401010408070102010301
Content-Type: text/plain; charset=UTF-7
Hi Alex Shatalin,
Earlier I tried to extend my Figure from PolylineConnectionEx , and now
I changed it to Polyline and the previous exception is not being shown.
But in the canvas the Poliline Figure is shown as in the following
attachment, and we cannot select the line specifically , and the
selection handles appear as for a normal Rectangle Figure.
Any Idea.. We are using GMF 1.0.
Please share any code snippets if you have done it before
> Hello biju,
> in Polyline class):
> Alex Shatalin
Content-Type: image/bmp;
name="diagram1.bmp"
filename="diagram1.bmp"
Qk1mDgcAAAAAADYAAAAoAAAAwgEAAFYBAAABABgAAAAAADAOBwAAAAAAAAAA AAAAAAAAAAAA
AAD///////////////////////////////////////////////////////// ////////////
//8AAP////////////////////////////////////////////////////// ////////////
/////wAA//////////////////////////////////////////////////// ////////////
////////AAD///////////////////////////////////////////////// ////////////
//////////8AAP////////////////////////////////////////////// ////////////
/////////////wAA//////////////////////////////////////////// ////////////
////////////////AAD///////////////////////////////////////// ////////////
//////////////////8AAP////////////////////////////////////// ////////////
/////////////////////wAA//////////////////////////////////// ////////////
////////////////////////AAD///////////////////////////////// ////////////
//////////////////////////8AAP////////////////////////////// ////////////
/////////////////////////////wAA//////////////////////////// ////////////
////////////////////////////////AAD///////////////////////// ////////////
//////////////////////////////////8AAP////////////////////// ////////////
/////////////////////////////////////wAA//////////////////// ////////////
////////////////////////////////////////AAD///////////////// ////////////
//////////////////////////////////////////8AAP////////////// ////////////
/////////////////////////////////////////////wAA//////////// ////////////
////////////////////////////////////////////////AAD///////// ////////////
//////////////////////////////////////////////////8AAP////// ////////////
/////////////////////////////////////////////////////wAA//// ////////////
////////////////////////////////////////////////////////AAD/ ////////////
//////////////////////////////////////////////////////////8A AP//////////
//////////////////////////////////////////////////////////// /wAA////////
//////////////////////////////////////////////////////////// ////AAD/////
//////////////////////////////////////////////////////////// //////8AAP//
//////////////////////////////////////////////////////////// /////////wAA
Re: Making Polyline a "normal" figure [message #98912 is a reply to message #98790] Tue, 30 January 2007 09:38 Go to previous message
Hello biju,
Looks like this excaption was thrown because getBounds() == null. I suggest
you to debug this code to see the reason.
Alex Shatalin
Previous Topic:Transformation definitions
Next Topic:Override a toolbar action
Current Time: Sat Jul 19 13:45:34 EDT 2025
Powered by FUDForum. Page generated in 0.34282 seconds
