Home » Modeling » TMF (Xtext) » Refer the value of one feature inside the rule
Refer the value of one feature inside the rule [message #986207] Mon, 19 November 2012 08:20 Go to next message
Goodmorning everyone!
Is it possible to refer the value of one feature inside the same rule?
I want to realize something like this:
FUNCTION example
example:=1+1;
END_FUNCTION
So I use a code like this:
Function:
'FUNCTION' name=ID
??? ':=' Expression
'END_FUNCTION';
What can I put instead of ??? to force the name of function? (Or I have to realize it with the validator?)
Very thank you.
[Updated on: Mon, 19 November 2012 11:04] by Moderator
Re: Refer the value of one feature inside the rule [message #986291 is a reply to message #986207] Mon, 19 November 2012 13:28 Go to previous messageGo to next message
am not sure what your problem is. did you have a look at default cross references?
~Christian
Re: Refer the value of one feature inside the rule [message #986353 is a reply to message #986291] Tue, 20 November 2012 03:25 Go to previous messageGo to next message
I can use cross reference:
Function:
'FUNCTION' name=ID
output=[Function] ':=' expression=Expression
'END_FUNCTION';
but also something like this is accepted:
FUNCTION example
example:=1+1;
END_FUNCTION
FUNCTION otherExample
example:=1+1;
END_FUNCTION
Re: Refer the value of one feature inside the rule [message #986611 is a reply to message #986353] Wed, 21 November 2012 03:06 Go to previous messageGo to next message
up
Re: Refer the value of one feature inside the rule [message #987050 is a reply to message #986611] Fri, 23 November 2012 03:09 Go to previous messageGo to next message
ri-up
Re: Refer the value of one feature inside the rule [message #987109 is a reply to message #987050] Fri, 23 November 2012 09:46 Go to previous messageGo to next message
On 2012-23-11 9:09, Tommaso De Sica wrote:
> ri-up
Love to help, but it is not much use doing something like up, ri-up when
we don't understand what you are asking. If you need help please
elaborate on what it is you need help with in more concrete terms. Which
one of the Xtext features is it that you don't understand, or what is it
your are trying to acheive?
Can't just look at a code snippet in your DSl language and guess what it
is you need help with.
- henrik
Re: Refer the value of one feature inside the rule [message #987126 is a reply to message #987109] Fri, 23 November 2012 11:23 Go to previous messageGo to next message
Well, my problem is this:
I want to write a Rule for Functions. A Function, in my DSL, appears like these:
FUNCTION functionName
   {some instruction}
functionName:=expressionForOutput
END_FUNCTION
FUNCTION secondFunctionName
   {some instruction}
secondFunctionName:=expressionForOutput
END_FUNCTION
As you can see, the last instruction must be an assignment where the left member is the name of the function.
If I use something like this:
Function:
   'FUNCTION' name=ID
   instructions+=Instruction*
   output=[Function]':='expression=Expression';'
   'END_FUNCTION';
the cross reference
[Function]
accepts all Function's names, but I want only the function name of Function where output is in.
Very thanks.
Re: Refer the value of one feature inside the rule [message #987165 is a reply to message #987126] Fri, 23 November 2012 17:34 Go to previous messageGo to next message
Can output refer to anything else than the same function? If not why do
you need to have an actual reference to itself in the first place?
I.e. you could just use an ID and validate that same ID is being used.
You want to also add this ID when doing code completion.
If you keep it as a reference, you need to look at scoping to understand
how to limit what is visible; here, if the only thing that is selectable
is the function itself, then that is what you need to add in your scope.
Does that help?
- henrik
> like these:
> {some instruction}
> END_FUNCTION
> {some instruction}
> END_FUNCTION
> Function:
> 'FUNCTION' name=ID
> output=[Function]':='expression=Expression';' 'END_FUNCTION';
> the cross reference [Function] accepts all Function's names, but I want
> Very thanks.
Re: Refer the value of one feature inside the rule [message #987213 is a reply to message #987126] Sat, 24 November 2012 09:29 Go to previous message
> like these:
> {some instruction}
> END_FUNCTION
> {some instruction}
> END_FUNCTION
> Function:
> 'FUNCTION' name=ID
> Very thanks.
You have to implement a custom Scoping for that!
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Previous Topic:Question about @Pure annotation
Next Topic:Same optional Modifiers at multiple alternatives
Current Time: Sat Jul 19 23:25:49 EDT 2025
Powered by FUDForum. Page generated in 0.25056 seconds
