Home » Eclipse Projects » Equinox » Can't start application with Eclipse 3.3
Can't start application with Eclipse 3.3 [message #98348] Wed, 26 September 2007 18:01 Go to next message
Originally posted by: stepper.sympedia.de
I'm trying to start an application with Eclipse 3.3 but I keep getting
this error:
osgi> !SESSION 2007-09-26 23:52:38.734
eclipse.buildId=unknown
java.version=1.5.0_12
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application org.eclipse.emf.cdo.server.app
Command-line arguments: -application org.eclipse.emf.cdo.server.app
-data C:\Dokumente und
Einstellungen\Stepper\Desktop\test\workspace.server -dev
file:C:/Dokumente und
Einstellungen/Stepper/Desktop/test/workspace/.metadata/.plug ins/org.eclipse.pde.core/CDO
Server/dev.properties -os win32 -ws win32 -arch x86 -consolelog
!ENTRY org.eclipse.osgi 4 0 2007-09-26 23:52:39.921
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:72)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
The plugin.xml markup is:
<extension
point="org.eclipse.core.runtime.applications"
id="app"
name="CDO Server">
<application cardinality="1" thread="any">
<run
class=" org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplicat ion "/>
</application>
</extension>
And the Java code:
public class CDOServerApplication implements IApplication
public CDOServerApplication()
public Object start(IApplicationContext context) throws Exception
return EXIT_OK;
public void stop()
try
((OSGiBundle)OM.BUNDLE).getBundleContext().getBundle().stop( );
catch (BundleException ex)
OM.LOG.error(ex);
Can you give me advice?
Cheers
/Eike
Re: Can't start application with Eclipse 3.3 [message #98365 is a reply to message #98348] Wed, 26 September 2007 19:54 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
Looks like you've not got org.eclipse.equinox.common and org.eclipse.equinox.app started in addition to yours.
Why is the IApplication#stop method calling the bundle#stop method? That's pretty unusual. Not that it's a cause of this problem (necessarily).
Have a read of http://www.eclipsezone.com/eclipse/forums/t99010.rhtml to see if any of that helps.
Alex.
Re: Can't start application with Eclipse 3.3 [message #98380 is a reply to message #98365] Thu, 27 September 2007 03:06 Go to previous messageGo to next message
--------------060503060603030203010201
But they're checked in the plugins tab of the launch config.
I've attached the launch config this time.
That is just to see what happens. I can comment it out if that would
make it work better. But as you say the problem seems to be before
stop() is being called.
Great! I'm going to go through it and come back...
Cheers
/Eike
Content-Type: text/xml;
name="CDOServer.launch"
Content-Disposition: inline;
filename="CDOServer.launch"
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.pde.ui.RuntimeWorkbench">
<booleanAttribute key="append.args" value="true"/>
<stringAttribute key="application" value="org.eclipse.emf.cdo.server.app"/>
<booleanAttribute key="askclear" value="true"/>
<booleanAttribute key="automaticAdd" value="false"/>
<booleanAttribute key="automaticValidate" value="false"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="false"/>
<booleanAttribute key="clearws" value="false"/>
<booleanAttribute key="clearwslog" value="false"/>
<stringAttribute key="configLocation" value=" ${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/CDO Server "/>
<booleanAttribute key="default" value="false"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="location" value="${workspace_loc}.server"/>
<booleanAttribute key="org.eclipse.debug.core.appendEnvironmentVariables" value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl}&#13;&#10;-consolelog"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS" value="-Dosgi.console"/>
<stringAttribute key="pde.version" value="3.3"/>
<stringAttribute key="product" value="org.eclipse.sdk.ide"/>
<stringAttribute key="selected_target_plugins" value=" javax.servlet,org.eclipse.core.contenttype,org.eclipse.core. jobs,org.eclipse.core.runtime,org.eclipse.core.runtime.compa tibility.auth,org.eclipse.core.runtime.compatibility.registr y,org.eclipse.emf.cdo.protocol,org.eclipse.emf.cdo.server,or g.eclipse.equinox.app,org.eclipse.equinox.common,org.eclipse .equinox.preferences,org.eclipse.equinox.registry,org.eclips e.net4j,org.eclipse.net4j.db,org.eclipse.net4j.db.derby,org. eclipse.net4j.tcp,org.eclipse.net4j.util,org.eclipse.osgi,or g.eclipse.osgi.services,org.eclipse.update.configurator "/>
<stringAttribute key="templateConfig" value="${target_home}\configuration\config.ini"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useDefaultConfig" value="true"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<booleanAttribute key="useProduct" value="false"/>
<booleanAttribute key="usefeatures" value="false"/>
</launchConfiguration>
--------------060503060603030203010201--
Re: Can't start application with Eclipse 3.3 [message #98395 is a reply to message #98365] Thu, 27 September 2007 03:27 Go to previous messageGo to next message
I've added -noExit to the launch config:
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070530
1 ACTIVE org.eclipse.equinox.common_3.3.0.v20070426
2 ACTIVE org.eclipse.core.runtime_3.3.100.v20070530
19 ACTIVE org.eclipse.update.configurator_3.2.100.v20070615
20 <<LAZY>> org.eclipse.net4j_0.8.0.v200709261640
21 <<LAZY>> org.eclipse.net4j.db_0.8.0.v200709261640
Fragments=22
22 RESOLVED org.eclipse.net4j.db.derby_0.8.0.v200709261640
Master=21
23 <<LAZY>> org.eclipse.net4j.tcp_0.8.0.v200709261640
24 ACTIVE org.eclipse.net4j.util_0.8.0.v200709261640
25 RESOLVED javax.servlet_2.4.0.v200706111738
26 <<LAZY>> org.eclipse.core.contenttype_3.2.100.v20070319
27 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
29 ACTIVE
org.eclipse.core.runtime.compatibility.auth_3.2.100.v2007050 2
30 RESOLVED
org.eclipse.core.runtime.compatibility.registry_3.2.100.v200 70316
Master=34
31 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
33 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
34 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
Fragments=30
36 RESOLVED org.eclipse.osgi.services_3.1.200.v20070605
38 <<LAZY>> org.eclipse.emf.cdo.protocol_0.8.0.v200709261705
39 ACTIVE org.eclipse.emf.cdo.server_0.8.0.v200709261705
Re: Can't start application with Eclipse 3.3 [message #98408 is a reply to message #98365] Thu, 27 September 2007 03:54 Go to previous messageGo to next message
Alex,
In debugging mode I've verified the actual order of startup events:
1) The exception appears on the console
2) The bundle containing the application is started (Activator.start()
is called)
3) The application. is started (IApplication.start() is called)
The only two obstacles are:
a) The exception appears
b) Eclipse exits if I don't specify -noExit
Regarding your interesting article on Eclipsezone I noticed that you
start like:
-- Every now and again, questions like "The application cannot be found"
are posted on the newsgroups...
But in the following hints you don't refer anymore to this particular
problem explicitely ;-)
Cheers
/Eike
> Alex.
Re: Can't start application with Eclipse 3.3 [message #98424 is a reply to message #98365] Thu, 27 September 2007 03:59 Go to previous messageGo to next message
A bit more info:
osgi> pt org.eclipse.core.runtime.applications
Extension point: org.eclipse.core.runtime.applications [from
org.eclipse.equinox.app]
Extension(s):
org.eclipse.equinox.app.error [from org.eclipse.equinox.app]
org.eclipse.emf.cdo.server.app [from org.eclipse.emf.cdo.server]
> Alex.
Re: Can't start application with Eclipse 3.3 [message #98439 is a reply to message #98365] Thu, 27 September 2007 04:38 Go to previous messageGo to next message
--------------080704060902080705030008
I've been debugging a bit and found this place in EclipseAppLauncher:
public Object start(Object defaultContext) throws Exception {
// here we assume that launch has been called by runtime before
we started
// TODO *this may be a bad assumption* but it works for now
because we register the app launcher as a service and runtime
synchronously calls launch on the service
if (failOnNoDefault && runnable == null)
throw new
IllegalStateException(EclipseAdaptorMsg.ECLIPSE_STARTUP_ERRO R_NO_APPLICATION);
When I start with -Declipse.application.launchDefault=false I get no
exception and Eclipse keeps running even w/o -noExit.
Everything works w/o probles as you can see:
osgi> ss
id State Bundle
2 ACTIVE org.eclipse.update.configurator_3.2.100.v20070615
3 ACTIVE org.eclipse.core.runtime_3.3.100.v20070530
4 RESOLVED javax.servlet_2.4.0.v200706111738
5 <<LAZY>> org.eclipse.core.contenttype_3.2.100.v20070319
6 ACTIVE org.eclipse.core.jobs_3.3.0.v20070423
8 ACTIVE
9 RESOLVED
Master=13
10 ACTIVE org.eclipse.equinox.app_1.0.0.v20070606
12 ACTIVE org.eclipse.equinox.preferences_3.2.100.v20070522
13 ACTIVE org.eclipse.equinox.registry_3.3.0.v20070522
Fragments=9
15 RESOLVED org.eclipse.osgi.services_3.1.200.v20070605
17 <<LAZY>> org.eclipse.emf.cdo.protocol_0.8.0.qualifier
18 <<LAZY>> org.eclipse.emf.cdo.server_0.8.0.qualifier
19 <<LAZY>> org.eclipse.net4j_0.8.0.qualifier
20 <<LAZY>> org.eclipse.net4j.util_0.8.0.qualifier
osgi> apps
org.eclipse.equinox.app.error [not launchable]
org.eclipse.emf.cdo.server.app [launchable]
osgi> activeApps
No active applications found
osgi> startApp org.eclipse.emf.cdo.server.app
Launched application instance: org.eclipse.emf.cdo.server.app.0
osgi> Bundle org.eclipse.emf.cdo.server started
Application org.eclipse.emf.cdo.server.app started
BUT, that's not what I want ;-(
I'd like to have the application started automatically even w/o
interactive console.
Cheers
/Eike
> Alex.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
I've been debugging a bit and found this place in EclipseAppLauncher:<br>
<br>
&nbsp;&nbsp;&nbsp; public Object start(Object defaultContext) throws Exception {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; // here we assume that launch has been called by runtime before
we started<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; // TODO <b>this may be a bad assumption</b> but it works for
now because we register the app launcher as a service and runtime
synchronously calls launch on the service<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (failOnNoDefault &amp;&amp; runnable == null)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; throw new
IllegalStateException(EclipseAdaptorMsg.ECLIPSE_STARTUP_ERRO R_NO_APPLICATION); <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; ....<br>
<br>
exception and Eclipse keeps running even w/o -noExit.<br>
Everything works w/o probles as you can see:<br>
<br>
<br>
osgi&gt; ss<br>
<br>
Framework is launched.<br>
<br>
id&nbsp;&nbsp;&nbsp; State&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& nbsp; Bundle<br>
0&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.osgi_3.3.0.v20070530<br>
1&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.equinox.common_3.3.0.v20070426<br>
2&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.update.configurator_3.2.100.v20070615<br>
3&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.core.runtime_3.3.100.v20070530<br>
4&nbsp;&nbsp;&nbsp; RESOLVED&nbsp;&nbsp;&nbsp; javax.servlet_2.4.0.v200706111738<br>
5&nbsp;&nbsp;&nbsp; &lt;&lt;LAZY&gt;&gt;&nbsp;&nbsp;& ;nbsp;
org.eclipse.core.contenttype_3.2.100.v20070319<br>
6&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.core.jobs_3.3.0.v20070423<br>
8&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
org.eclipse.core.runtime.compatibility.auth_3.2.100.v2007050 2 <br>
9&nbsp;&nbsp;&nbsp; RESOLVED&nbsp;&nbsp;&nbsp;
org.eclipse.core.runtime.compatibility.registry_3.2.100.v200 70316 <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Master=13<br>
10&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.equinox.app_1.0.0.v20070606<br>
12&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.equinox.preferences_3.2.100.v20070522<br>
13&nbsp;&nbsp;&nbsp; ACTIVE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; org.eclipse.equinox.registry_3.3.0.v20070522<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Fragments=9<br>
15&nbsp;&nbsp;&nbsp; RESOLVED&nbsp;&nbsp;&nbsp; org.eclipse.osgi.services_3.1.200.v20070605<br>
17&nbsp;&nbsp;&nbsp; &lt;&lt;LAZY&gt;&gt;&nbsp;&nbsp;& ;nbsp;
org.eclipse.emf.cdo.protocol_0.8.0.qualifier<br>
18&nbsp;&nbsp;&nbsp; &lt;&lt;LAZY&gt;&gt;&nbsp;&nbsp;& ;nbsp; org.eclipse.emf.cdo.server_0.8.0.qualifier<br>
19&nbsp;&nbsp;&nbsp; &lt;&lt;LAZY&gt;&gt;&nbsp;&nbsp;& ;nbsp; org.eclipse.net4j_0.8.0.qualifier<br>
20&nbsp;&nbsp;&nbsp; &lt;&lt;LAZY&gt;&gt;&nbsp;&nbsp;& ;nbsp; org.eclipse.net4j.util_0.8.0.qualifier<br>
<br>
osgi&gt; apps<br>
org.eclipse.equinox.app.error [not launchable]<br>
org.eclipse.emf.cdo.server.app [launchable]<br>
<br>
osgi&gt; activeApps<br>
No active applications found<br>
<br>
osgi&gt; startApp org.eclipse.emf.cdo.server.app<br>
Launched application instance: org.eclipse.emf.cdo.server.app.0<br>
<br>
osgi&gt; Bundle org.eclipse.emf.cdo.server started<br>
Application org.eclipse.emf.cdo.server.app started<br>
<br>
BUT, that's not what I want ;-(<br>
interactive console.<br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
<blockquote
cite="mid:430420644.54041190850890130.JavaMail.root@cp9.dzone.com"
type="cite">
<pre wrap="">Looks like you've not got org.eclipse.equinox.common and org.eclipse.equinox.app started in addition to yours.
Have a read of <a class="moz-txt-link-freetext" href="http://www.eclipsezone.com/eclipse/forums/t99010.rhtml">http://www.eclipsezone.com/eclipse/forums/t99010.rhtml</a> to see if any of that helps.
Alex.
</pre>
</blockquote>
</body>
</html>
--------------080704060902080705030008--
Re: Can't start application with Eclipse 3.3 [message #98467 is a reply to message #98439] Thu, 27 September 2007 06:37 Go to previous messageGo to next message
Calling bundle.stop() means that the bundle's in a stopped state. This may be causing problems when you then re-start. I'd take it out, run it, and see if that makes any difference.
How are you launching it from Eclipse? Are you choosing 'run an application' or 'run a product'? I don't think it's possible to start up a product *and* run an application, if that's what you're trying to do.
Eclipse 3.3 has bugs (fixed for 3.3.1) that prevent 'main' threads starting from the console, and 'non-main' threads starting from the command line, so you need two extension points even if there's only one class if you want to do both. I can't recall what the default is for 'main' or 'any' in the plugin.xml if you don't specify it.
Alex.
Re: Can't start application with Eclipse 3.3 [message #98482 is a reply to message #98439] Thu, 27 September 2007 06:45 Go to previous messageGo to next message
Hi Eike
According to the Javadoc of IApplication, the start-method should not return until the application is finished (i.e., block in start). Can you add a sleep/loop to see if it changes anything?
BTW, how does your config.ini look like?
Cheers, Stephan
Re: Can't start application with Eclipse 3.3 [message #98506 is a reply to message #98482] Thu, 27 September 2007 07:56 Go to previous messageGo to next message
--------------090102010809050208060701
Content-Type: multipart/alternative;
boundary="------------090002040404080204050603"
--------------090002040404080204050603
Hi Stephan, Alex,
Thanks for your care ;-)
I've solved it with various changes and I not completely sure which
one(s) exactly solved the problem.
The most obvious candidates are:
1) Moved my startup logic from BundleActivator.start() to
2) Added -noExit (which is still needed!)
3) Blocking in IApplication.start() on a CountDownLatch which is
countDown() in IApplication.stop()
I've developed an abstract OSGiApplication base class (see attachment)
which does all the lifecycle mnagement/bookkeeping. Of course I should
have read the JavaDoc of IApplication more carefully but since the
IApplication API is very similar to the BundleActivator I really thought
that similar semantics apply ;-(
Anyway, now it seems to work perfectly (with the exception that I don't
understand why -noExit is needed). Starting, stopping and restarting
produces the following stdout (only if you're interested):
Configuration location:
file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/
Configuration file:
file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/config.ini
loaded
Install location:
file:/C:/develop/eclipse/
Framework located:
file:/C:/develop/eclipse/plugins/org.eclipse.osgi_3.3.0.v200 70530.jar
Framework classpath:
Debug options:
file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/.options
loaded
osgi> Time to load bundles: 78
app thread - org.eclipse.emf.cdo.server.app.0 [debug.om] Starting bundle
app thread - org.eclipse.emf.cdo.server.app.0 [debug] Configuring
repositories from
C:\ws\cdo\org.eclipse.emf.cdo.server-feature\rootfiles\net4j -config\cdo-server.xml
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle]
Activating ManagedContainer
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle.dump]
DUMP PluginContainer@1
ManagedContainer.factoryRegistry = null
ManagedContainer.postProcessors = null
ManagedContainer.elementRegistry =
ManagedContainer.maxElementID = 0
ManagedContainer.elementListener =
org.eclipse.net4j.internal.util.container.ManagedContainer$1@1fddc31
Activating {}
DUMP PluginFactoryRegistry@2
Registry.autoCommit = true
Registry.transaction = null
HashMapRegistry.map =
extensionRegistryListener =
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@f4f44a
Activating []
DUMP PluginElementProcessorList@3
processors =
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@1fa1bb6
org.eclipse.net4j
app thread - org.eclipse.emf.cdo.server.app.0 [debug.repository]
Configuring repositories from
Configuring repository repo1 (type=default)
app thread - org.eclipse.emf.cdo.server.app.0 [debug.model] Created
CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0, name=cdocore,
dynamic=false, metaIDRange=null)
CDOClass(ID=0, name=CDOObject)
app thread - org.eclipse.emf.cdo.server.app.0 [debug.model] Adding
class: CDOClass(ID=0, name=CDOObject)
app thread - org.eclipse.emf.cdo.server.app.0 [debug.model] Added
package: CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
name=cdocore, dynamic=false, metaIDRange=null)
CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
name=cdoresource, dynamic=false, metaIDRange=null)
CDOClass(ID=0, name=CDOResource)
CDOFeature(ID=8, name=path, type=STRING)
feature: CDOFeature(ID=8, name=path, type=STRING)
CDOFeature(ID=2, name=contents, type=OBJECT)
feature: CDOFeature(ID=2, name=contents, type=OBJECT)
class: CDOClass(ID=0, name=CDOResource)
package: CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
org.eclipse.emf.cdo.server.db
Activating Repository[repo1, null]
DUMP Repository@4
name = repo1
store = DBStore@5
uuid = null
properties =
rememberingKnownTypes=false
supportingAudits=true
verifyingRevisions=false
overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f
supportingAudits = true
verifyingRevisions = null
rememberingKnownTypes = null
typeManager = TypeManager@6
packageManager = PackageManager@7
sessionManager = SessionManager@8
resourceManager = ResourceManager@9
revisionManager = RevisionManager@10
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@203c31
nextMetaIDValue = 1
Activating DBStore@5
DUMP DBStore@5
Store.type = db
Store.repository = Repository[repo1, null]
Store.nextOIDValue = 2
mappingStrategy = horizontal
dbAdapter = derby-10.2.2.0
connectionProvider = org.apache.derby.jdbc.ClientDataSource@105bd58
schema = null
nextPackageID = 0
nextClassID = 0
nextFeatureID = 0
app thread - org.eclipse.emf.cdo.server.app.0 [debug.sql] CREATE TABLE
cdo_classes (id INTEGER, package INTEGER, classifier INTEGER, name
VARCHAR(255), abstract SMALLINT)
cdo_supertypes (type_id INTEGER, supertype_package VARCHAR(255),
supertype_classifier INTEGER)
cdo_features (id INTEGER, class INTEGER, feature INTEGER, name
VARCHAR(255), type INTEGER, reference_package VARCHAR(255),
reference_classifier INTEGER, many SMALLINT, containment SMALLINT, idx
INTEGER)
cdo_repository (name VARCHAR(255), uuid VARCHAR(64), starts BIGINT,
started BIGINT, stopped BIGINT, next_cdoid BIGINT, next_metaid BIGINT)
cdo_packages (id INTEGER, uri VARCHAR(255), name VARCHAR(255), ecore
LONG VARCHAR, dynamic SMALLINT, range_lb BIGINT, range_ub BIGINT)
app thread - org.eclipse.emf.cdo.server.app.0 [debug.sql] INSERT IGNORE INTO
cdo_repository VALUES ('repo1', '1ff5d226-b1f0-40fb-aba2-0c31b38c764f',
1, 1190893492141, 0, 0, 0)
app thread - org.eclipse.emf.cdo.server.app.0 [debug.model] Setting
server info: CDOClass(ID=0, name=CDOResource) --> -2
CDOResource_contents_refs (cdo_source BIGINT, cdo_version INTEGER,
cdo_idx INTEGER, cdo_target BIGINT)
CDOResource (cdo_id BIGINT, cdo_version INTEGER, cdo_class INTEGER,
cdo_created BIGINT, cdo_revised BIGINT, cdo_resource BIGINT,
cdo_container BIGINT, cdo_feature INTEGER, path VARCHAR(32672))
app thread - org.eclipse.emf.cdo.server.app.0 [debug.sql] SELECT MAX(id)
FROM cdo_packages
FROM cdo_classes
FROM cdo_features
Activating TypeManager@6
DUMP TypeManager@6
Worker.daemon = false
Worker.activationTimeout = 2000
Worker.deactivationTimeout = 2000
Worker.activationLatch = null
Worker.workerThread = null
QueueWorker.queue = null
QueueWorker.pollMillis = 100
repository = Repository[repo1, 1ff5d226-b1f0-40fb-aba2-0c31b38c764f]
persistent = true
objectTypes =
packageURIMap = null
packageIDMap = null
objectTypeMap = null
metaObjectTypeMap = null
nextPackageID = 0
app thread - org.eclipse.emf.cdo.server.app.0 [debug.types] Repository
state location:
C:\ws\cdo.server\.metadata\.plugins\org.eclipse.emf.cdo.serv er\1ff5d226-b1f0-40fb-aba2-0c31b38c764f
Activating PackageManager@7
DUMP PackageManager@7
CDOPackageManagerImpl.packages =
http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
CDOPackageManagerImpl.cdoCorePackage =
CDOPackageManagerImpl.cdoResourcePackage =
app thread - org.eclipse.emf.cdo.server.app.0 [debug.sql] SELECT uri,
dynamic, range_lb, range_ub FROM cdo_packages
Activating SessionManager@8
DUMP SessionManager@8
sessions =
lastSessionID = 0
Activating ResourceManager@9
DUMP ResourceManager@9
idToPathMap =
pathToIDMap =
Activating RevisionManager@10
DUMP RevisionManager@10
CDORevisionResolverImpl.revisions =
cdoPathFeature = CDOFeature(ID=8, name=path, type=STRING)
Application Started: 9250
*apps
org.eclipse.emf.cdo.server.app [running] [not launchable]
osgi> stopApp org.eclipse.emf.cdo.server.app*
app thread - org.eclipse.emf.cdo.server.app.0 [debug.om] Stopping
Stopped application instance: org.eclipse.emf.cdo.server.app.0
Deactivating Repository[repo1, 1ff5d226-b1f0-40fb-aba2-0c31b38c764f]
osgi> app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle]
Deactivating RevisionManager@10
Deactivating ResourceManager@9
Deactivating SessionManager@8
Deactivating PackageManager@7
Deactivating TypeManager@6
Deactivating DBStore@5
app thread - org.eclipse.emf.cdo.server.app.0 [debug.sql] UPDATE
cdo_repository SET stopped=1190893510500, next_cdoid=2, next_metaid=1
*apps
osgi> startApp org.eclipse.emf.cdo.server.app*
Launched application instance: org.eclipse.emf.cdo.server.app.1
osgi> app thread - org.eclipse.emf.cdo.server.app.1 [debug.om] Starting
app thread - org.eclipse.emf.cdo.server.app.1 [debug] Configuring
repositories from
app thread - org.eclipse.emf.cdo.server.app.1 [debug.repository]
app thread - org.eclipse.emf.cdo.server.app.1 [debug.model] Created
app thread - org.eclipse.emf.cdo.server.app.1 [debug.model] Adding
app thread - org.eclipse.emf.cdo.server.app.1 [debug.model] Added
app thread - org.eclipse.emf.cdo.server.app.1 [debug.lifecycle]
app thread - org.eclipse.emf.cdo.server.app.1 [debug.lifecycle.dump]
DUMP Repository@11
name = repo1
store = DBStore@12
uuid = null
properties =
typeManager = TypeManager@13
packageManager = PackageManager@14
sessionManager = SessionManager@15
resourceManager = ResourceManager@16
revisionManager = RevisionManager@17
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@1e808ca
nextMetaIDValue = 1
Activating DBStore@12
DUMP DBStore@12
Store.type = db
connectionProvider = org.apache.derby.jdbc.ClientDataSource@992bae
schema = null
nextPackageID = 0
nextClassID = 0
nextFeatureID = 0
app thread - org.eclipse.emf.cdo.server.app.1 [debug.sql] CREATE TABLE
app thread - org.eclipse.emf.cdo.server.app.1 [debug.sql] -- Table/View
'CDO_CLASSES' ist bereits in Schema 'APP' vorhanden.
'CDO_SUPERTYPES' ist bereits in Schema 'APP' vorhanden.
INTEGER)
'CDO_FEATURES' ist bereits in Schema 'APP' vorhanden.
'CDO_REPOSITORY' ist bereits in Schema 'APP' vorhanden.
'CDO_PACKAGES' ist bereits in Schema 'APP' vorhanden.
app thread - org.eclipse.emf.cdo.server.app.1 [debug.sql] SELECT
MAX(next_cdoid) FROM cdo_repository
MAX(next_metaid) FROM cdo_repository
app thread - org.eclipse.emf.cdo.server.app.1 [debug.sql] UPDATE
cdo_repository SET starts=starts+1, started=1190893530813, stopped=0,
next_cdoid=0, next_metaid=0
app thread - org.eclipse.emf.cdo.server.app.1 [debug.sql] SELECT MAX(id)
FROM cdo_packages
FROM cdo_classes
FROM cdo_features
Activating TypeManager@13
DUMP TypeManager@13
persistent = true
objectTypes =
packageIDMap = null
nextPackageID = 0
app thread - org.eclipse.emf.cdo.server.app.1 [debug.types] Repository
state location:
Activating PackageManager@14
DUMP PackageManager@14
app thread - org.eclipse.emf.cdo.server.app.1 [debug.sql] SELECT uri,
Activating SessionManager@15
DUMP SessionManager@15
sessions =
lastSessionID = 0
Activating ResourceManager@16
DUMP ResourceManager@16
idToPathMap =
pathToIDMap =
Activating RevisionManager@17
DUMP RevisionManager@17
Application Started: 47438
THANKS AGAIN!!
/Eike
Stephan Sigrist schrieb:
> Hi Eike
> Cheers, Stephan
<html>
<head>
<title></title>
</head>
Hi Stephan, Alex,<br>
<br>
Thanks for your care ;-)<br>
<br>
one(s) exactly solved the problem.<br>
The most obvious candidates are:<br>
IApplication.start()<br>
2) Added -noExit (which is still needed!)<br>
countDown() in IApplication.stop()<br>
<br>
thought that similar semantics apply ;-( <br>
<br>
produces the following stdout (only if you're interested):<br>
<br>
Configuration location:<br>
&nbsp;&nbsp;&nbsp; <a class="moz-txt-link-freetext" href=" file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/ "> file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/ </a><br>
Configuration file:<br>
&nbsp;&nbsp;&nbsp;
<a class="moz-txt-link-freetext" href=" file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/config.ini "> file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/config.ini </a>
loaded<br>
Install location:<br>
&nbsp;&nbsp;&nbsp; <a class="moz-txt-link-freetext" href="file:/C:/develop/eclipse/">file:/C:/develop/eclipse/ </a><br>
Framework located:<br>
&nbsp;&nbsp;&nbsp;
<a class="moz-txt-link-freetext" href=" file:/C:/develop/eclipse/plugins/org.eclipse.osgi_3.3.0.v200 70530.jar "> file:/C:/develop/eclipse/plugins/org.eclipse.osgi_3.3.0.v200 70530.jar </a><br>
Framework classpath:<br>
&nbsp;&nbsp;&nbsp;
Debug options:<br>
&nbsp;&nbsp;&nbsp;
<a class="moz-txt-link-freetext" href=" file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/.options "> file:/C:/ws/cdo/.metadata/.plugins/org.eclipse.pde.core/CDOS erver/.options </a>
loaded<br>
<br>
osgi&gt; Time to load bundles: 78<br>
bundle org.eclipse.net4j.util<br>
bundle org.eclipse.emf.cdo.server<br>
application org.eclipse.emf.cdo.server.app<br>
repositories from
C:\ws\cdo\org.eclipse.emf.cdo.server-feature\rootfiles\net4j -config\cdo-server.xml <br>
Activating ManagedContainer<br>
DUMP PluginContainer@1<br>
&nbsp;ManagedContainer.factoryRegistry = null<br>
&nbsp;ManagedContainer.postProcessors = null<br>
&nbsp;ManagedContainer.elementRegistry = <br>
&nbsp;ManagedContainer.maxElementID = 0<br>
&nbsp;ManagedContainer.elementListener =
org.eclipse.net4j.internal.util.container.ManagedContainer$1@1fddc31<br>
<br>
Activating {}<br>
DUMP PluginFactoryRegistry@2<br>
&nbsp;Registry.autoCommit = true<br>
&nbsp;Registry.transaction = null<br>
&nbsp;HashMapRegistry.map = <br>
&nbsp;extensionRegistryListener =
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@f4f44a<br>
<br>
Activating []<br>
DUMP PluginElementProcessorList@3<br>
&nbsp;processors = <br>
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@1fa1bb6<br>
<br>
bundle org.eclipse.net4j<br>
Configuring repository repo1 (type=default)<br>
bundle org.eclipse.emf.cdo.protocol<br>
CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0</a>, name=cdocore,
dynamic=false, metaIDRange=null)<br>
CDOClass(ID=0, name=CDOObject)<br>
class: CDOClass(ID=0, name=CDOObject)<br>
package: CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0</a>,
name=cdocore, dynamic=false, metaIDRange=null)<br>
CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
name=cdoresource, dynamic=false, metaIDRange=null)<br>
CDOClass(ID=0, name=CDOResource)<br>
CDOFeature(ID=8, name=path, type=STRING)<br>
feature: CDOFeature(ID=8, name=path, type=STRING)<br>
CDOFeature(ID=2, name=contents, type=OBJECT)<br>
feature: CDOFeature(ID=2, name=contents, type=OBJECT)<br>
class: CDOClass(ID=0, name=CDOResource)<br>
package: CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
bundle org.eclipse.emf.cdo.server.db<br>
bundle org.eclipse.net4j.db<br>
Activating Repository[repo1, null]<br>
DUMP Repository@4<br>
&nbsp;name = repo1<br>
&nbsp;store = DBStore@5<br>
&nbsp;uuid = null<br>
&nbsp;properties = <br>
&nbsp;&nbsp;&nbsp; rememberingKnownTypes=false<br>
&nbsp;&nbsp;&nbsp; supportingAudits=true<br>
&nbsp;&nbsp;&nbsp; verifyingRevisions=false<br>
&nbsp;&nbsp;&nbsp; overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f<br>
&nbsp;supportingAudits = true<br>
&nbsp;verifyingRevisions = null<br>
&nbsp;rememberingKnownTypes = null<br>
&nbsp;typeManager = TypeManager@6<br>
&nbsp;packageManager = PackageManager@7<br>
&nbsp;sessionManager = SessionManager@8<br>
&nbsp;resourceManager = ResourceManager@9<br>
&nbsp;revisionManager = RevisionManager@10<br>
&nbsp;elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@203c31<br>
&nbsp;nextMetaIDValue = 1<br>
<br>
Activating DBStore@5<br>
DUMP DBStore@5<br>
&nbsp;Store.type = db<br>
&nbsp;Store.repository = Repository[repo1, null]<br>
&nbsp;Store.nextOIDValue = 2<br>
&nbsp;mappingStrategy = horizontal<br>
&nbsp;dbAdapter = derby-10.2.2.0<br>
&nbsp;connectionProvider = org.apache.derby.jdbc.ClientDataSource@105bd58<br>
&nbsp;schema = null<br>
&nbsp;nextPackageID = 0<br>
&nbsp;nextClassID = 0<br>
&nbsp;nextFeatureID = 0<br>
<br>
VARCHAR(255), abstract SMALLINT)<br>
supertype_classifier INTEGER)<br>
INTEGER)<br>
started BIGINT, stopped BIGINT, next_cdoid BIGINT, next_metaid BIGINT)<br>
LONG VARCHAR, dynamic SMALLINT, range_lb BIGINT, range_ub BIGINT)<br>
app thread - org.eclipse.emf.cdo.server.app.0 [debug.sql] INSERT INTO
1, 1190893492141, 0, 0, 0)<br>
server info: CDOClass(ID=0, name=CDOResource) --&gt; -2<br>
cdo_idx INTEGER, cdo_target BIGINT)<br>
cdo_container BIGINT, cdo_feature INTEGER, path VARCHAR(32672))<br>
MAX(id) FROM cdo_packages<br>
MAX(id) FROM cdo_classes<br>
MAX(id) FROM cdo_features<br>
Activating TypeManager@6<br>
DUMP TypeManager@6<br>
&nbsp;Worker.daemon = false<br>
&nbsp;Worker.activationTimeout = 2000<br>
&nbsp;Worker.deactivationTimeout = 2000<br>
&nbsp;Worker.activationLatch = null<br>
&nbsp;Worker.workerThread = null<br>
&nbsp;QueueWorker.queue = null<br>
&nbsp;QueueWorker.pollMillis = 100<br>
&nbsp;repository = Repository[repo1, 1ff5d226-b1f0-40fb-aba2-0c31b38c764f]<br>
&nbsp;persistent = true<br>
&nbsp;objectTypes = <br>
&nbsp;packageURIMap = null<br>
&nbsp;packageIDMap = null<br>
&nbsp;objectTypeMap = null<br>
&nbsp;metaObjectTypeMap = null<br>
<br>
state location:
C:\ws\cdo.server\.metadata\.plugins\org.eclipse.emf.cdo.serv er\1ff5d226-b1f0-40fb-aba2-0c31b38c764f <br>
Activating PackageManager@7<br>
DUMP PackageManager@7<br>
&nbsp;CDOPackageManagerImpl.packages = <br>
&nbsp;&nbsp;&nbsp;
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0</a>,
&nbsp;&nbsp;&nbsp;
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
&nbsp;CDOPackageManagerImpl.cdoCorePackage =
&nbsp;CDOPackageManagerImpl.cdoResourcePackage =
<br>
dynamic, range_lb, range_ub FROM cdo_packages<br>
Activating SessionManager@8<br>
DUMP SessionManager@8<br>
&nbsp;sessions = <br>
&nbsp;lastSessionID = 0<br>
<br>
Activating ResourceManager@9<br>
DUMP ResourceManager@9<br>
&nbsp;idToPathMap = <br>
&nbsp;pathToIDMap = <br>
<br>
Activating RevisionManager@10<br>
DUMP RevisionManager@10<br>
&nbsp;CDORevisionResolverImpl.revisions = <br>
&nbsp;cdoPathFeature = CDOFeature(ID=8, name=path, type=STRING)<br>
<br>
Application Started: 9250<br>
<font color="#330099"><b>apps<br>
org.eclipse.emf.cdo.server.app [running] [not launchable]<br>
<br>
osgi&gt; stopApp org.eclipse.emf.cdo.server.app</b></font><br>
Stopped application instance: org.eclipse.emf.cdo.server.app.0<br>
Deactivating Repository[repo1, 1ff5d226-b1f0-40fb-aba2-0c31b38c764f]<br>
<br>
osgi&gt; app thread - org.eclipse.emf.cdo.server.app.0
[debug.lifecycle] Deactivating RevisionManager@10<br>
Deactivating ResourceManager@9<br>
Deactivating SessionManager@8<br>
Deactivating PackageManager@7<br>
Deactivating TypeManager@6<br>
Deactivating DBStore@5<br>
cdo_repository SET stopped=1190893510500, next_cdoid=2, next_metaid=1<br>
<font color="#000099"><b>apps<br>
<br>
osgi&gt; startApp org.eclipse.emf.cdo.server.app</b></font><br>
Launched application instance: org.eclipse.emf.cdo.server.app.1<br>
<br>
osgi&gt; app thread - org.eclipse.emf.cdo.server.app.1 [debug.om]
Starting application org.eclipse.emf.cdo.server.app<br>
repositories from
DUMP Repository@11<br>
&nbsp;store = DBStore@12<br>
&nbsp;typeManager = TypeManager@13<br>
&nbsp;packageManager = PackageManager@14<br>
&nbsp;sessionManager = SessionManager@15<br>
&nbsp;resourceManager = ResourceManager@16<br>
&nbsp;revisionManager = RevisionManager@17<br>
&nbsp;elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@1e808ca<br >
<br>
Activating DBStore@12<br>
DUMP DBStore@12<br>
&nbsp;connectionProvider = org.apache.derby.jdbc.ClientDataSource@992bae<br>
<br>
'CDO_CLASSES' ist bereits in Schema 'APP' vorhanden.<br>
'CDO_SUPERTYPES' ist bereits in Schema 'APP' vorhanden.<br>
INTEGER)<br>
'CDO_FEATURES' ist bereits in Schema 'APP' vorhanden.<br>
'CDO_REPOSITORY' ist bereits in Schema 'APP' vorhanden.<br>
'CDO_PACKAGES' ist bereits in Schema 'APP' vorhanden.<br>
MAX(next_cdoid) FROM cdo_repository<br>
MAX(next_metaid) FROM cdo_repository<br>
next_cdoid=0, next_metaid=0<br>
Activating TypeManager@13<br>
DUMP TypeManager@13<br>
&nbsp;repository = Repository[repo1, null]<br>
<br>
state location:
Activating PackageManager@14<br>
DUMP PackageManager@14<br>
&nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp;
Re: Can't start application with Eclipse 3.3 [message #98638 is a reply to message #98467] Fri, 28 September 2007 13:11 Go to previous messageGo to next message
--------------070709080703080806060403
Hi Alex,
[stuff deleted]
My **application** is running correctly now when I use a launch config
from my IDE.
Then I thought it'd be nice to provide a **product** as well.
I'm not sure if this is the correct newgroup for products but it does
not work.
This is my markup:
<extension
id="app"
name="CDO Server">
<run
</application>
</extension>
<extension
point="org.eclipse.core.runtime.products">
id="product"
<product
name="CDO Server"
description="An example of a CDO server"
application="org.eclipse.emf.cdo.server.app">
<property
name="appName"
value="CDO Server">
</property>
</product>
</extension>
This is my product definition:
<?pde version="3.1"?>
<product name="CDO Server" id="org.eclipse.emf.cdo.server.product"
application="org.eclipse.emf.cdo.server.app" useFeatures="false">
<configIni use="default"/>
<launcherArgs>
<programArgs>-console
-debug
-noExit</programArgs>
<vmArgs>-Dnet4j.config=cdo-config</vmArgs>
<vmArgsMac>-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts</vmArgsMac>
</launcherArgs>
<launcher name="cdo-server.exe">
<solaris/>
<win useIco="false">
<bmp/>
</win>
</launcher>
<vm>
</vm>
<plugins>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.auth"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry"
fragment="true"/>
<plugin id="org.eclipse.emf.cdo.protocol"/>
<plugin id="org.eclipse.emf.cdo.server"/>
<plugin id="org.eclipse.emf.cdo.server.db"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.net4j"/>
<plugin id="org.eclipse.net4j.db"/>
<plugin id="org.eclipse.net4j.db.derby" fragment="true"/>
<plugin id="org.eclipse.net4j.tcp"/>
<plugin id="org.eclipse.net4j.util"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.osgi.util"/>
<plugin id="org.eclipse.update.configurator"/>
</plugins>
</product>
The product can be exported to a zip successfully but when I start the
executable, the log shows:
!SESSION 2007-09-28 18:50:19.906
java.version=1.6.0_02
Command-line arguments: -os win32 -ws win32 -arch x86 -console -debug
!ENTRY org.eclipse.equinox.app 2007-09-28 18:50:21.156
!MESSAGE Product org.eclipse.emf.cdo.server.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2007-09-28 18:50:21.156
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:229)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:92)
at
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:129)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
at
org.osgi.util.tracker.ServiceTracker$Tracked.track(ServiceTr acker.java:1042)
at
org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTracker.java:967)
at
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:94)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1224)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1603)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1578)
at
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl. <init>(ServiceRegistrationImpl.java:103)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:657)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:609)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:675)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:359)
at
Have I missed anything abvious?
Cheers
/Eike
<html>
<head>
</head>
Hi Alex,<br>
<br>
[stuff deleted]<br>
<blockquote
cite="mid:520968436.55811190889459955.JavaMail.root@cp9.dzone.com"
type="cite">
<pre wrap="">
</pre>
</blockquote>
My *<b>application</b>* is running correctly now when I use a launch
config from my IDE.<br>
<br>
Then I thought it'd be nice to provide a *<b>product</b>* as well. <br>
not work.<br>
<br>
This is my markup:<br>
<br>
&nbsp;&nbsp;&nbsp; &lt;extension<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; point="org.eclipse.core.runtime.applications"<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; id="app"<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; name="CDO Server"&gt;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;application cardinality="1" thread="any"&gt;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;run
class=" org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplicat ion "/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;/application&gt;<br>
&nbsp;&nbsp;&nbsp; &lt;/extension&gt;<br>
&nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; point="org.eclipse.core.runtime.products"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; id="product"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;product<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; name="CDO Server"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; description="An example of a CDO server"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; application="org.eclipse.emf.cdo.server.app"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &lt;property<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; name="appName"<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; value="CDO Server"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &lt;/property&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/product&gt;<br>
<br>
This is my product definition:<br>
<br>
&lt;?xml version="1.0" encoding="UTF-8"?&gt;<br>
&lt;?pde version="3.1"?&gt;<br>
<br>
&lt;product name="CDO Server" id="org.eclipse.emf.cdo.server.product"
application="org.eclipse.emf.cdo.server.app" useFeatures="false"&gt;<br>
<br>
&nbsp;&nbsp; &lt;configIni use="default"/&gt;<br>
<br>
&nbsp;&nbsp; &lt;launcherArgs&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;programArgs&gt;-console<br>
-debug<br>
-noExit&lt;/programArgs&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;vmArgs&gt;-Dnet4j.config=cdo-config&lt;/vmAr gs&gt; <br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;vmArgsMac&gt;-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts&lt;/vmArgsM ac&gt; <br>
&nbsp;&nbsp; &lt;/launcherArgs&gt;<br>
<br>
&nbsp;&nbsp; &lt;launcher name="cdo-server.exe"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;solaris/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;win useIco="false"&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &lt;bmp/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/win&gt;<br>
&nbsp;&nbsp; &lt;/launcher&gt;<br>
<br>
&nbsp;&nbsp; &lt;vm&gt;<br>
&nbsp;&nbsp; &lt;/vm&gt;<br>
<br>
&nbsp;&nbsp; &lt;plugins&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.core.contenttype"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.core.jobs"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.core.runtime"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.core.runtime.compatibility.auth"/&gt;<br >
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.core.runtime.compatibility.registry"
fragment="true"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.emf.cdo.protocol"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.emf.cdo.server"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.emf.cdo.server.db"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.equinox.app"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.equinox.common"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.equinox.preferences"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.equinox.registry"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.net4j"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.net4j.db"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.net4j.db.derby" fragment="true"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.net4j.tcp"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.net4j.util"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.osgi"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.osgi.services"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.osgi.util"/&gt;<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;plugin id="org.eclipse.update.configurator"/&gt;<br>
&nbsp;&nbsp; &lt;/plugins&gt;<br>
<br>
<br>
executable, the log shows:<br>
<br>
-----------------------------------------------<br>
eclipse.buildId=unknown<br>
java.version=1.6.0_02<br>
java.vendor=Sun Microsystems Inc.<br>
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE<br>
Command-line arguments:&nbsp; -os win32 -ws win32 -arch x86 -console -debug<br>
<br>
!ENTRY org.eclipse.equinox.app 2007-09-28 18:50:21.156<br>
!MESSAGE Product org.eclipse.emf.cdo.server.product could not be found.<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2007-09-28 18:50:21.156<br>
!MESSAGE Application error<br>
!STACK 1<br>
java.lang.RuntimeException: No application id has been found.<br>
&nbsp;&nbsp;&nbsp; at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:229) <br>
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:92) <br>
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:129) <br>
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064) <br>
org.osgi.util.tracker.ServiceTracker$Tracked.track(ServiceTr acker.java:1042) <br>
org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTracker.java:967) <br>
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:94) <br>
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1224) <br>
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195) <br>
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141) <br>
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1603) <br>
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1578) <br>
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.&lt;init&gt;(ServiceRegistrationImpl.java:103) <br>
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:657) <br>
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:609) <br>
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:675) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:359) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176) <br>
&nbsp;&nbsp;&nbsp; at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br>
&nbsp;&nbsp;&nbsp; at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<br>
&nbsp;&nbsp;&nbsp; at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)<br>
&nbsp;&nbsp;&nbsp; at java.lang.reflect.Method.invoke(Unknown Source)<br>
&nbsp;&nbsp;&nbsp; at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504) <br>
&nbsp;&nbsp;&nbsp; at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)<br >
&nbsp;&nbsp;&nbsp; at org.eclipse.equinox.launcher.Main.run(Main.java:1169)<br>
<br>
Have I missed anything abvious?<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
<br>
</body>
</html>
--------------070709080703080806060403--
Re: Can't start application with Eclipse 3.3 [message #98699 is a reply to message #98506] Fri, 28 September 2007 13:47 Go to previous messageGo to next message
If your app is on the 'main' thread, you don't need -noExit. If it's on the 'any' thread (required in 3.3.0 to launch via the console) then it will automatically close.
Alex.
Re: Can't start application with Eclipse 3.3 (SOLVED) [message #98713 is a reply to message #98638] Fri, 28 September 2007 14:02 Go to previous message
I changed the product definition from plugin-based to feature-based and,
all of a sudden, it works ;-)
Thx
/Eike
Eike Stepper schrieb:
> Hi Alex,
> [stuff deleted]
> from my IDE.
> not work.
> This is my markup:
> <extension
> id="app"
> name="CDO Server">
> <run
> </application>
> </extension>
> <extension
> id="product"
> <product
> name="CDO Server"
> <property
> name="appName"
> value="CDO Server">
> </property>
> </product>
> </extension>
> <launcherArgs>
> -debug
> </launcherArgs>
> <solaris/>
> <bmp/>
> </win>
> </launcher>
> <vm>
> </vm>
> <plugins>
> fragment="true"/>
> </plugins>
> </product>
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Cheers
> /Eike
Previous Topic:Can a dependent bundle trigger activation of a bundle it depends on?
Next Topic:Error log file missing
Current Time: Sat Jul 19 14:27:32 EDT 2025
Powered by FUDForum. Page generated in 0.06687 seconds
