Home » Eclipse Projects » Plugin Development Environment (PDE) » Prevent archiving rcp application in headless build
Prevent archiving rcp application in headless build [message #603969] Tue, 05 January 2010 14:37 Go to next message
1) Is is possible to prevent the default headless build of PDE
(org.eclipse.pde.build_...\scripts\productBuild\productBuild .xml) of creating an archive
file at the end of the build process of my rcp application. Is there a property for that?
Or should I override the default assemble process?
What I would like to do instead, is to copy all files that the archive must contain to a
temporary directory. Our application already provide an installation software that will
grab these files and make the installer...
2) How could I customize part of my build process without changing the default PDE build
process?
Note that I'm using PDE to make an headless build of my RCP application as in the following:
java -jar c:\eclipse\plugins\org.eclipse.equinox.launcher_XXX.jar -application
org.eclipse.ant.core.antRunner -buildfile productBuild.xml -D... -D...
Thanks all,
Vincent
Re: Prevent archiving rcp application in headless build [message #982879 is a reply to message #603969] Tue, 13 November 2012 08:48 Go to previous messageGo to next message
Hi!
Thats interesting. I have to do something similar. Is there any solution?
Thanks!
-Danny Schimke
Re: Prevent archiving rcp application in headless build [message #986598 is a reply to message #982879] Wed, 21 November 2012 01:59 Go to previous message
Hi Vincent , Danny
There is definetely a way for that i believe.
You can try overwriting ant calls in customTargets.xml , allElements.xml , productBuild.xml and such files
These files are present in the 'eclipse\plugins\org.eclipse.pde.build_3.6.0.v20100603\templates\headless-build' directory in eclipse
Hope that helps.
Previous Topic:Simplify PDE Builds for similar projects
Next Topic:View descriptor not found exception in eclipse PDE
Current Time: Sat Jul 19 19:21:50 EDT 2025
Powered by FUDForum. Page generated in 0.03805 seconds
