Home » Newcomers » Newcomers » Ocaml eclipse extensions(Compatibility issues with everything i try!)
Ocaml eclipse extensions [message #986111] Sun, 18 November 2012 18:17
Hoping someone can point me in the direction of a good eclipse plug in for Ocaml, that runs on windows. So far i have tried installing and failed using the ocalIDE. I have followed all the tutorial instructions and help pages i could find on the ocalIDE plug in
[Sorry it wont let me post links]
This advises using older versions of oCaml, which i have tried and older versions of Eclipse which i have also tried.
I have tried using the ODT Ocaml plug it's site.
which also doesn't work. The issues here is using the compiler from inside eclipse. I also tried running the ocaml code in cmd using the ocamlopt "c" command and this provides nothing but errors. I've searched online and followed up on both these plug ins, unable to find a way.
Any suggests as to what to try next? And if an eclipse extension maybe isn't the way forward do you know any other ocaml IDE's that will be useful
(I have tried and had much trouble with: cygwin, the default emacs, camelia to no avail!)
All help welcome
Mike
Previous Topic:Eclipse is too slow and uses too much memory
Next Topic:ECLIPSE HELIOS SR2 Download fails
Current Time: Sat Jul 19 14:31:06 EDT 2025
Powered by FUDForum. Page generated in 0.09113 seconds
