Home » Archived » Test and Performance Tools Platform (TPTP) » IAgentStateModifier & IProcessStateModifier issues...
IAgentStateModifier & IProcessStateModifier issues... [message #98177] |
Tue, 08 May 2007 00:06  |
Originally posted by: guyfromindia.gmail.com
This doubt is for the 'GUI' guys...
I have an agent running inside my Eclipse instance (plugin). I have also
implemented custom control providers for the process, agent and toolbar...
because want to have control over 'attach', 'detatch', 'start', 'pause',
'terminate', etc.
More specifically, I want to have control over 'terminate', because I cannot
allow the user to terminate the agent, which in turn kills my Eclipse (same
process).
By extending "AbstractProcessControlProvider", I can handle 'terminate' when
the user chooses the terminate item on the *process* context menu.
<problem>
But, 'terminate' on the *agent's* context menu is still handled by
" org.eclipse.tptp.trace.ui.provisional.control.provider.Proce ssControlProvider ",
even though I have implemented the
"org.eclipse.hyades.trace.ui.controllableEntity" extension point...
</problem>
Unfortunately,
org.eclipse.tptp.trace.ui.provisional.control.provider.IAgen tStateModifier
only allows me to implement attach, detatch, start, pause, etc... but NOT
terminate!
Please advice..
-Raj
Re: IAgentStateModifier & IProcessStateModifier issues... [message #98412 is a reply to message #98177] |
Thu, 10 May 2007 20:28   |
Hi Raj,
What does your extension point look like? Are you explicitly associating a
control provider with an agent entity? See below for an example:
<control associatedAgentId =
"org.eclipse.tptp.trace.ui.loggingAgentDiscoverer">
<entity type = "process" class =
" org.eclipse.tptp.trace.ui.provisional.control.provider.Proce ssControlProvider "/>
<entity type = "agent" class =
" org.eclipse.tptp.trace.ui.internal.control.provider.applicat ion.AgentDiscovererControlProvider "/>
</control>
The control provider that you associate with an agent should be an extension
of AbstractAgentControlProvider, which is an extension of
ProcessControlProvider. All you need to do is overwrite
getProcessStateModifier() and have it return an instance of the process
state modifier you're using for your process control provider. See the
snippet below:
class MyAgentControlProvider extends AbstractAgentControlProvider
//overwrite getProcessStateModifier()
public IProcessStateModifier getProcessStateModifier()
//return an instance of the process state modifier you're using for
// overwirte the agent state modifier()...
Ali Mehregani
"Raj" <guyfromindia@gmail.com> wrote in message
news:f1osv7$ti$1@build.eclipse.org...
> 'terminate', etc.
> cannot allow the user to terminate the agent, which in turn kills my
> Eclipse (same process).
> when the user chooses the terminate item on the *process* context menu.
> <problem>
> </problem>
> Unfortunately,
> terminate!
> Please advice..
> -Raj
Re: IAgentStateModifier & IProcessStateModifier issues... [message #98454 is a reply to message #98412] |
Fri, 11 May 2007 11:20  |
>>> All you need to do is overwrite getProcessStateModifier() and have it
>>> return an instance of the process state modifier you're using for your
Hello Ali,
I was doing everything mentioned below, except override
getProcessStateModifier...
That did it! Thanks for your valuable input...
Thx
Raj
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:f20dcd$jrl$1@build.eclipse.org...
> Hi Raj,
> a control provider with an agent entity? See below for an example:
> </control>
> extension of AbstractAgentControlProvider, which is an extension of
> snippet below:
> Ali Mehregani
>> toolbar...
>> 'terminate', etc.
>> <problem>
>> </problem>
>> Unfortunately,
>> terminate!
>> Please advice..
>> -Raj
Current Time: Sat Jul 19 13:34:00 EDT 2025
Powered by FUDForum. Page generated in 0.07681 seconds
