Error after updating [message #97514] |
Thu, 25 August 2005 21:05  |
Originally posted by: c.frank.gmail.com
I tried to update Eclipse today, and there was a package available, so I
checked it and installed it. But when eclipse restarted, an error came
up. I imagine this is a simple problem to fix (uninstall the update), but
I don't recall the name of it and wouldn't know where to find it anyhow.
Perhaps the logfile will give some clue, because I can't tell what is
going on.
The following was in the log:
!SESSION 2005-08-25 20:57:09.736
eclipse.buildId=I20050627-1435
java.version=1.5.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 2005-08-25 20:57:15.814
!MESSAGE Product org.eclipse.sdk.ide could not be found.
!ENTRY org.eclipse.osgi 2005-08-25 20:57:15.846
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:204)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!MESSAGE Bundle update@plugins/org.eclipse.core.runtime_3.0.2/ [14] was
not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-08-25 20:57:15.846
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.core.runtime_3.1.0.jar/ was
picked instead.
!ENTRY org.eclipse.osgi 2005-08-25 20:57:15.861
!MESSAGE Bundle update@plugins/org.eclipse.osgi_3.0.1/ [73] was not
resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-08-25 20:57:15.861
!MESSAGE Missing imported package org.eclipse.osgi.framework.msg_1.0.0.
org.eclipse.osgi.service.systembundle_0.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.update.configurator_3.0.0/
[113] was not resolved.
!MESSAGE Bundle
initial@reference:file:plugins/org.eclipse.update.configurator_3.1.0.jar/
was picked instead.
!MESSAGE Bundle
update@plugins/org.tigris.subversion.subclipse.core_0.9.32/ [121] was not
resolved.
!MESSAGE Bundle
update@plugins/org.tigris.subversion.subclipse.core_0.9.32.1/ was picked
instead.
Re: Error after updating [message #98317 is a reply to message #97514] |
Mon, 29 August 2005 11:39   |
> but I don't recall the name of it and wouldn't know where to find it
> anyhow. Perhaps the logfile will give some clue, because I can't tell
> what is going on.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
How did you install the new version? Did you install it in the same
location as a previous version? (Hint - that will not work)
HTH,
Eric
Re: Error after updating [message #98436 is a reply to message #98317] |
Mon, 29 August 2005 23:31  |
> HTH,
> Eric
Well, it was an update from within eclipse, not a new version. Anyhow, I
managed to fix it by deleting the entire directory and re-extracting
eclipse.
FUDForum. Page generated in 0.08725 seconds
